After the last update, my system got stuck on reached target graphical interface after some screen splashes.
Xorg log just in case: https://pastebin.com/C7Y31aJe
Some time later I found the solution Cannot get Xorg to start after past days updates
So, I downgraded mesa from 23.3.2-1 to 22.3.1-3 and it works fine, but can cause broken update in future.
But I don’t use integrated intel GPU as a person in the previous topic, but nvidia GPU with the proprietary driver and have different address in Xorg log - Segmentation fault at address 0x0
Hardware: Ryzen 5800x3d, Nvidia GTX 1080ti
I have the some problem reaching the login screen after today’s update. The system keeps flashing but never enters the login screen. I have used both LTS and hardened kernel but the end result is same.
Thanks. I read somewhere in the forum to remove xf86-video-intel and it did the trick. I also do not seems to have modesetting installed. But it worked.
ajayc% sudo pacman -Syu modesetting
[sudo] password for ajayc:
endeavouros is up to date
core 128.0 KiB 233 KiB/s 00:01 [-----------------------------------------] 100%
extra is up to date
error: target not found: modesetting
