Update problem, Keyrings problem, startup failed to execute eos_yad and more
Heya,
I think I have messed up and i would need your help if you are so kind to provide it! :slight_smile:
tl:dr I can’t use updates anymore. endeavouros-keyring gone by my mistake
  1. When i booted today i got this error
  2. I tried to search for it and didn’t find anything relevant so I started my morning routine by updating the system with eos-update --yay and it successfully updated alsa and pipewire.
  3. I got some problems with updating some packages though (anaconda,yacreader and dwarfs-bin), it wrote
    “error: failed to commit transaction (conflicting files)”.
    I checked the advice of https://wiki.archlinux.org/title/pacman
    and thought that was a conflict of same files so I WRONGLY used pacdiff & meld and overwrote 4-5 entries with ‘o’.
  4. Thats when my troubles began because when i re-run update I had the problem of “error: target not found: endeavouros-keyring”
I tried the solution provided here Keyring Issues , deleted (idiotic move from me) the gnupg folder in pacman.d, but then I could not use wget in the addresses provided because they were no longer existent :frowning:
Then i tried many things from here (including the populating keys and refreshing them
sudo pacman-key --init
sudo pacman-key --populate archlinux endeavouros
sudo pacman-key --refresh-keys
sudo pacman -Syy
but no luck!
Any suggestions or could you point me to the right urls to retry wget?
Thank you and sorry for the trouble!
Steve
I would work through the steps in this guide.
https://discovery.endeavouros.com/signature-and-keyring/pacman-keyring-issues/2021/03/
Thank you for replying!
Unfortunately it can’t find the endeavouros keyring at all
also yad is newer than extra and it seems that now I dont have the other databases besides core/extra :frowning:
  • I confirm that my system clock is correct.
  • I confirm that my folder /var/cache/pacman/pkg/ is empty
  • I confirm that i dont have incomplete downloads
  • I backed up the -newly created- gnupg folder
  • initialized the keys and repopulated them (both for endeavouros and arch)
  • again it doesnt find the endeavouros keyring
  • and it doesnt find the keyring packages
run
eos-rankmirrors
and try update again
Unfortunately no dice
the endeavouros repo does not sync
please post the output from:
cat /etc/pacman.conf
Sure thing!
(Sorry i am not familiar yet on how to post outputs in a better format than pntscn)
these lines are missing
[endeavouros]
SigLevel = PackageRequired
Include = /etc/pacman.d/endeavouros-mirrorlist
Edit:
insert them as in the following standard file
text blocks:
like this
or
[code]
like this
[/code]
use the code tags(</>) from the forum editor and insert the terminal output in it.
That was it!!!
Now I can at least update!
Thank you very much for your patience and thoughtful insight!
Btw do you guys have any idea for this error that still keeps popping up?
Also I still have the error of not being able to update anaconda and dwarfs-bin but I am now trying a cleanbuild. Fingers crossed
the error points to your home directory cache folder chances are it has been removed.as far as anaconda and dwarfs-bin i don’t use those so i couldn’t tell you what the issue is
Yeap! I thought the same, but I cannot understand what element of eos_yad is this and how it is related to my startup processes. :thinking:
Screenshot_20230716_113547
This looks like an error message you’d get on Windows! :thinking:
I dont know what to do with that information :sweat_smile:
