If the keyring installation fails, proceed as follows:
Add pacman key
sudo pacman-key --recv-keys AEE1E900
Let’s add the repository in pacman:
sudo nano /etc/pacman.conf
[codelinsoft-eos-repository]
SigLevel = Never
Server = https://repository.codelinsoft.it/eos-repository
Install keyring
sudo pacman -Syu codelinsoft-keyring
Yes I have done that with a tip from Librewish. That did the trick, thanks.
Added the eos-community-wallpapers package
sudo pacman -S eos-community-wallpapers
@specialworld83
update mhwd-db-garuda
and add optimus-manager and optimus-manager-qt to your repo
as i have added
an option to install optimus manager via mhwd
sudo mhwd -i pci video-intel-nvidia-optimus-manager
Hi, I try to install eos-settings-manager and it fails on beginning.
LANG=C sudo pacman-key --recv-keys AEE1E900
gpg: keyserver receive failed: General error
==> ERROR: Remote key not fetched correctly from keyserver.
Can I just install garuda-settings-manager-git from AUR?
Regards.
Use a specific keyserver, e.g. --keyserver hkps://keyserver.ubuntu.com
Yes.
