Unneccesary driver
The lsusb command does not show the driver?
What does command
dmesg | grep usbcore
say?
It’s probably because it’s a Pci-e card!
[rick@xfce-pc ~]$ dmesg | grep usbcore
[    0.788395] usbcore: registered new interface driver usbfs
[    0.788404] usbcore: registered new interface driver hub
[    0.788427] usbcore: registered new device driver usb
[    1.055878] usbcore: registered new interface driver usbserial_generic
[    2.021421] usbcore: registered new interface driver usbhid
[rick@xfce-pc ~]$
It runs off the PCI Express bus!
Oh …you meant joe? Sorry.
lshw -class network
  *-network
       description: Ethernet interface
       product: 82567LM-3 Gigabit Network Connection
       vendor: Intel Corporation
       physical id: 19
       bus info: pci@0000:00:19.0
       logical name: enp0s25
       version: 02
       serial: XXX
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=3.2.6-k duplex=full firmware=0.5-3 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       resources: irq:35 memory:XXX ioport:ece0(size=32)
  *-network
       description: Wireless interface
       physical id: 1
       bus info: usb@3:6.3
       logical name: wlan0
       serial: XXX
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rtl8192cu driverversion=5.4.11-arch1-1 firmware=N/A ip=XXX link=yes multicast=yes wireless=IEEE 802.11
╭─joekamprad@empowered64 ~
╰─$ dmesg | grep usbcore
[    1.279605] usbcore: registered new interface driver usbfs
[    1.279605] usbcore: registered new interface driver hub
[    1.279605] usbcore: registered new device driver usb
[    1.616687] usbcore: registered new interface driver usbserial_generic
[    2.258842] usbcore: registered new interface driver usb-storage
[    2.264283] usbcore: registered new interface driver uas
[    6.430850] usbcore: registered new interface driver usblp
[    6.756895] usbcore: registered new interface driver btusb
[    7.229592] usbcore: registered new interface driver usbhid
[  741.929425] usbcore: registered new interface driver rtl8192cu
[  741.956826] usbcore: registered new interface driver rtl8xxxu
This is weird? I thought it was because i had both Ethernet and WiFi connected but WiFi wasn’t on. So i disconnected Ethernet and turned on WiFi
[rick@xfce-pc ~]$ lshw -class network
bash: lshw: command not found
[rick@xfce-pc ~]$
Is there a package for lshw command? I see two!
I installed it and still doesn’t show anything. :roll_eyes:
Edir: Off to work i go!
What does this say:
inxi -N
╰─$ inxi -N
Network:   Device-1: Intel 82567LM-3 Gigabit Network driver: e1000e
           Device-2: Realtek RTL8192CU 802.11n WLAN Adapter type: USB driver: rtl8192cu
[andreasdimo@andreasdimo ~]$ inxi -N
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet dr
iver: r8169``
04:00.0 Network controller: Intel Corporation Wireless 7265 (rev 59)
Kernel driver in use: iwlwifi
No extras
01:00.0 Network controller: Intel Corporation Wireless 3165 (rev 91)
I was even able to do an online installation with that one. :wink:
Hi all!
You may have already noticed the latest version of the welcome app, 2.2.27-1.
It includes a small improvement with the Detect system issues button:
it should be able to remove the Broadcom wifi driver if Broadcom wifi hardware is not present.
I thank you all for the valuable input you gave, without it this would have been much harder to implement! :smile:
Well, going to finally reinstall properly tonight so will give it a go :slight_smile:
This is my output
$ lspci -k | grep -A9 " Network controller: " | grep -P "Network cont|Kernel driver"
02:00.0 Network controller: Intel Corporation Wireless 7265 (rev 59)
Hello @ed0
Not sure what your issue is here? Could you please explain so someone could help you.
Apologies @ricklinux, not an issue :slight_smile:
I was just following up on manuel’s message
"Hi all, this is an interesting topic!
So I ask all of you EndeavourOS users to run the following command:
lspci -k | grep -A9 " Network controller: " | grep -P “Network cont|Kernel driver”
and show your results here!
This will help us avoid installing unnecessary drivers."
Currently this information is used in the welcome app, the “Detect system issues” button.
Later it could be used at install phase, but for now it is only in the welcome app.
Network controller: Realtek Semiconductor Co., Ltd. RTL8188EE Wireless Network Adapter (rev 01)
Kernel driver in use: rtl8188ee
Kernel driver in use: r8169
Device-1: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
           IF: wlan0
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
           IF: enp7s0
03:00.0 Network controller: Intel Corporation Centrino Advanced-N 6205 [Taylor Peak] (rev 34)
