Interesting, you have two wireless drivers in use?
To make sure, could you show the output of
lspci -k | grep -A9 " Network controller: "
This is interesting? One is a Micron controller for SATA so it’s funny that it shows under Network?
[rick@xfce-pc ~]$ lspci -k | grep -A9 " Network controller: "
03:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4360 802.11ac Wireless Network Adapter (rev 03)
Subsystem: Broadcom Inc. and subsidiaries BCM4360 802.11ac Wireless Network Adapter
Kernel driver in use: wl
Kernel modules: bcma, wl
04:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 01)
Subsystem: DFI Inc RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Kernel driver in use: r8169
Kernel modules: r8169
05:00.0 SATA controller: JMicron Technology Corp. JMB360 AHCI Controller (rev 02)
Subsystem: JMicron Technology Corp. JMB360 AHCI Controller
[rick@xfce-pc ~]$
Edit: It’s an Advanced Host Controller Interface Chip! I think it’s for running Raid maybe?
I think the above command was too “liberal”.
Could you run this instead:
lspci -k | grep -A4 " Network controller: " | grep -P “Network cont|Kernel driver”
[rick@xfce-pc ~]$ lspci -k | grep -A4 " Network controller: " | grep -P “Network cont|Kernel driver”
bash: Kernel: command not found
grep: cont: No such file or directory
[rick@xfce-pc ~]$
Quotes again… sorry about that.
Simply replace the quote characters to be: "
There is a small difference.
Sorry, I don’t understand what you mean? It looks the same to me?
lspci -k | grep -A4 " Network controller: " | grep -P "Network cont|Kernel driver"
Hopefully they are right now.
If not, simply replace the double quotes with single quotes.
That’s better but i don’t see the difference?
[rick@xfce-pc ~]$ lspci -k | grep -A4 " Network controller: " | grep -P "Network cont|Kernel driver"
[rick@xfce-pc ~]$
I can’t see any difference in the command?
what is about usb-wlan adapters?
lsusb:
Bus 003 Device 007: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN Adapter
[rick@xfce-pc ~]$ lsusb:
bash: lsusb:: command not found
[rick@xfce-pc ~]$ Bus 003 Device 007: ID 0bda:8178 Realtek Semiconductor Corp. RTL8192CU 802.11n WLAN Adapter
bash: Bus: command not found
[rick@xfce-pc ~]$
It is a browser issue, sometimes copy/paste from a browser messes up certain special characters like quotes. They look almost the same, but not exactly. And they provide different ASCII codes…
The wireless card is Pci-e
I understand what your saying but it looks the same to me. ![]()
00:00.0 Host bridge: Intel Corporation 82975X Memory Controller Hub (rev c0)
Subsystem: Intel Corporation 82975X Memory Controller Hub
Kernel modules: i82975x_edac
00:01.0 PCI bridge: Intel Corporation 82975X PCI Express Root Port (rev c0)
Kernel driver in use: pcieport
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
Subsystem: Intel Corporation DeskTop Board D945GTP
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 1 (rev 01)
00:1c.1 PCI bridge: Intel Corporation NM10/ICH7 Family PCI Express Port 2 (rev 01)
00:1c.4 PCI bridge: Intel Corporation 82801GR/GH/GHM (ICH7 Family) PCI Express Port 5 (rev 01)
00:1c.5 PCI bridge: Intel Corporation 82801GR/GH/GHM (ICH7 Family) PCI Express Port 6 (rev 01)
00:1d.0 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #1 (rev 01)
Subsystem: Intel Corporation NM10/ICH7 Family USB UHCI Controller
Kernel driver in use: uhci_hcd
Kernel modules: uhci_hcd
00:1d.1 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #2 (rev 01)
00:1d.2 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #3 (rev 01)
00:1d.3 USB controller: Intel Corporation NM10/ICH7 Family USB UHCI Controller #4 (rev 01)
00:1d.7 USB controller: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller (rev 01)
Subsystem: Intel Corporation NM10/ICH7 Family USB2 EHCI Controller
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev e1)
00:1f.0 ISA bridge: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge (rev 01)
Subsystem: Intel Corporation 82801GB/GR (ICH7 Family) LPC Interface Bridge
Kernel driver in use: lpc_ich
Kernel modules: intel_rng, lpc_ich, leds_ss4200
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 01)
Subsystem: Intel Corporation 82801G (ICH7 Family) IDE Controller
Kernel driver in use: ata_piix
Kernel modules: ata_piix, pata_acpi, ata_generic
00:1f.2 SATA controller: Intel Corporation NM10/ICH7 Family SATA Controller [AHCI mode] (rev 01)
Subsystem: Intel Corporation NM10/ICH7 Family SATA Controller [AHCI mode]
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation NM10/ICH7 Family SMBus Controller (rev 01)
Subsystem: Intel Corporation NM10/ICH7 Family SMBus Controller
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] RV670 [Radeon HD 3870]
Subsystem: PC Partner Limited / Sapphire Technology Radeon HD 3870
Kernel driver in use: radeon
Kernel modules: radeon
01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] RV670/680 HDMI Audio [Radeon HD 3690/3800 Series]
Subsystem: PC Partner Limited / Sapphire Technology RV670/680 HDMI Audio [Radeon HD 3690/3800 Series]
06:03.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller (rev 80)
Subsystem: DFI Inc VT6306/7/8 [Fire II(M)] IEEE 1394 OHCI Controller
Kernel driver in use: firewire_ohci
Kernel modules: firewire_ohci
[rick@xfce-pc ~]$
Compare them with bash:
if [ '"' = '“' ] ; then
echo same
else
echo different
fi
is the command i use, second line was the output on my system;![]()
Thank you and you are welcome too. ![]()
Oh…sorry. ![]()
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 003: ID 0000:3825 USB OPTICAL MOUSE
Bus 004 Device 002: ID 1a2c:2d23 China Resource Semico Co., Ltd USB Keyboard
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
[rick@xfce-pc ~]$
[rick@xfce-pc ~]$ if [ '"' = '“' ] ; then
> echo same
> else
> echo different
> fi
different
[rick@xfce-pc ~]$
