Uninstall programs and their configuration files on EOS
Hi friends, a long time ago you told me how to uninstall programs and their configuration files in EOS, so that everything would be new as default.
Unfortunately, I forgot to write it down in my mini-command guide for EOS, and I forgot how to do it correctly.
I want to uninstall wine-staging, lutris and bottles. Would the command be this?
yay -Rns wine-staging
yay -Rns lutris
yay -Rns bottles
(I don’t know if this is the right way to do a full uninstall)
But, later, I think that this command did not uninstall the configuration files, and some folders that contain these configuration files had to be deleted.
But I don’t remember what folders they were.
Thanks in advance for your help friends.
By the way, I think the configuration folders were around here:
Yeah pretty much.
Rest of the configs and bloat leftovers for programs (can) live in:
~/.cache
~/.config
~/.local/share
In case of wine there’s also default wineprefix at:
~/.wine
if you don’t need it anymore.
Thank you very much friend!
I deleted everything I found in those 3 folders that could not be deleted by -Rns.
But using the file search engine, I found more files (in this case from librewolf):
/usr/lib/debug/usr/lib/librewolf/librewolf.debug
/usr/src/debug/librewolf-bin
/var/lib/pacman/local/librewolf-bin-debug-123.0-1
I shouldn’t delete any of this, right?
You didn’t mention librewolf before…but if you need it removed - yes, every program store in those places.
However:
Those are system files (they’re not in /home).
You should remove package to get rid of them.
Oh wait, debug files…i think you’ve missed that.
Then check your system for -debug packages, like librewolf-bin-debug:
pacman -Qs "\-debug"
and remove unneded.
Yes, right, you’re right, sorry, I used Firefox and Tor more, so I decided to uninstall it too. xP
Thank you! It seems like this only happens with “-bin” packages?
I think any packages from AUR, just fix with !debug flag, remove the rest of those packages and you won’t have those anymore.
