Guess the error message : NMI watchdog detected hard lockup on cpu 21. It’s basically what I was expecting. The only other post i’ve seen on reddit the guy literally had the same issue and no other linux distro worked either :
https://www.reddit.com/r/SoundBlasterOfficial/comments/10kmsv0/problem_with_creative_ae7_any_linux_doesnt_start/
The person ended up trading it’s AE-7 for an AE-5.
Yes here shows working but the motherboard is different hardware so i don’t know.
Indeed. I really don’t know what’s happening. The person seems to be fine on Kernel 6.x… I`m booting EOS on kernel 6.3.1 so it should not occur.
This is also this :
https://bbs.archlinux.org/viewtopic.php?id=284548
Might be related but they talk about Intel NUCs.
ok so I’ve made some kind of progress here. I was able to boot with the card in. This indeed seems to be a conflict with the snd_hda_intel module and my new card. I blacklisted the module by creating a conf file in /etc/modprobe.d folder named snd_hda_intel.conf and added the following inside :
blacklist snd_hda_intel
blacklist snd_hda_codec_hdmi
So this disable the intel sound mostlikely coming from one of the hdmi port on the video card or onboard. Right now If I do lspci I can see the new soundcard but it’s not available in the audio panel.
67:00.0 Audio device: Creative Labs Device 0010 (rev 01)
I’m not far from success I think.
EDIT: the snd_hda_intel might also manage creative sound card…
Maybe you should name it differently? Maybe it should be blacklist.conf with the two entries inside the file.
I also think then if the card is actually listed you may have to set the priority.
The black listing is working at the moment. I can load EOS but the sound card is not showing in the audio panel and alsa does not see it either. It might be that the snd_hda_intel is also managing creative sound card…
Can you list the cards with aplay -l
The only 2 devices appearing there are my SteelSeries Arctis 7 headphone that I use only when I’m gaming with friends.
**** List of PLAYBACK Hardware Devices ****
card 0: S7 [SteelSeries Arctis 7], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: S7 [SteelSeries Arctis 7], device 1: USB Audio [USB Audio #1]
Subdevices: 1/1
Basically I answered my own question : snd_hda_intel is used to handle creative soundcard. So If I blacklist it I won’t play audio from my card. So there is a conflict somewhere in the module between the audio from that sound card and something else :
Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK driver: N/A
bus-ID: 3-3.1:18 alternate: snd_hda_intel chip-ID: 046d:0892 pcie:
class-ID: 0102 gen: 1 serial: E84F15EF speed: 2.5 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-2: Creative Labs driver: N/A alternate: snd_hda_intel
bus-ID: 67:00.0 chip-ID: 1102:0010 class-ID: 0403
Device-3: Logitech C920 HD Pro Webcam type: USB
driver: snd-usb-audio,uvcvideo
Device-4: Valve VR Radio type: USB driver: cdc_acm,hid-generic,usbhid
bus-ID: 3-5.3.2:12 chip-ID: 28de:2102 class-ID: 0a00 serial: 82EA7C4F17-RYB
Device-5: Valve VR Radio & HMD Mic type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-5.3.3:13
chip-ID: 28de:2102 class-ID: 0102 serial: 86F92210F0-LYM
Device-6: SteelSeries ApS Arctis 7 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-9:5 chip-ID: 1038:12ad
class-ID: 0300
API: ALSA v: k6.3.1-arch1-1 status: kernel-api tools: alsamixer,amixer
Server-1: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
Did you use lspci -nnk to try to get the hardware id’s? Not sure if it will show?
67:00.0 Audio device [0403]: Creative Labs Device [1102:0010] (rev 01)
Subsystem: Creative Labs Device [1102:0081]
Kernel modules: snd_hda_intel
Are you confident that is the actual sound card in question?
Yes. There is no other Creative lab audio device in the computer. The onboard device which is disabled is a Realtek other than that there is the Nvidia Audio and Ati audio from the display ports and hdmi.
Maybe try in /etc/modprobe.d/alsa-base.conf
add
options snd-hda-intel position_fix=1
Edit: If it doesn’t work just remove it.
Nothing is helpful i take it.
