UMA Graphics and Switchable graphics
Hello,
For some time I experience that I can only install Linux distributions, when I have the UMA graphics, the problem is that my graphics 3050 ti does not appear, and if I get into Switchable mode automatically Linux distributions stop working. what can I do? My computer is the Gaming 3 15IAH7
As you can see, it only detects the integrated one, the 3050 ti, it only recognizes it when I am in switchable mode, and if I access with this mode, my linux system gets corrupted, it happened to me with all the distributions.
Could you run command
inxi -Fza | eos-sendlog
and show the resulting URL here?
could be you need the proprietary Nvidia Driver s to get the Nvidia to work properly the open-source driver may not fully support it.
But as it shows intel igpu could be also the issue about intel 12th gen CPU and Nvidia driver…
https://0x0.st/Hsxr.txt
Your Nvidia card does not show in the inxi output. Is it disabled in the BIOS?
You probably need to add kernel parameter ibt=off as @joekamprad mentions in the link.
