Trying to replicate Garuda Linux's KDE theming on EndeavourOS Plasma KDE
The prompt is the most seducing aspect. :wink:
Actually, which package includes the Sweetified Plasma theme? I started testing the garuda-dr460nized, I can say that it has a lot of stuff I needed…
Generally, does anybody know which package includes Sweetified Plasma?
This is where a garuda VM would help you. You could then just find the file and run pacman -Qo /path/to/file and find out what package it was part of.
And where are the KDE themes located in the files?
Check:
/usr/share/plasma/desktoptheme
and/or
/usr/share/plasma/look-and-feel
Yeah it was on /usr/share/plasma/look-and-feel and it’s from garuda-dr460nized (sadly :c)
From a practical standpoint, would it not be easier to just use your second most favorite theming and call it good?
I bring this up because even if you actually get this working, there is a very real chance that after a month or so of rolling updates, some update will break things and you will be right back in the situation you are now in.
Just saying.
Pudge
Fair point
I wouldn’t really mind using the Sweet theme since it’s pretty much same, but:
  1. The package providing the theme has a problem with signature recognizing and I can’t install it. (See my comment here) I installed the AUR version, but it still the theme itself didn’t work…
  2. I know, it’s available as a theme under the “Get more themes” section, but this would require me to check for updates and manually update, and, not gonna lie, I’m a bit lazy :sweat_smile:
    That’s what I’ll end up doing I think…
Either way I could close this post since I got most info, I’m only missing the konsole configuration, which I’ll find too, eventually…
Just search it out in get new blah blah in Konsole settings. Sweet has a downloadable konsole theme. It has basically a theme for everything including splash screens and SDDM. It is also why it is the most popular theme on KDE store.
:pray: 555555555
No problem, we can close it for you.
