Hi,
I came accross this message
wpa_supplicant[897]: nl80211: kernel reports: Match already configured
`journalctl -p 4`
-- Journal begins at Tue 2021-08-10 17:57:05 CEST, ends at Tue 2021-08-10 18:19:07 CEST. --
août 10 17:57:05 lmm-hpebk840g7nbpc kernel: x86/cpu: SGX disabled by BIOS.
août 10 17:57:05 lmm-hpebk840g7nbpc kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
août 10 17:57:05 lmm-hpebk840g7nbpc kernel: nvme nvme0: missing or invalid SUBNQN field.
août 10 17:57:05 lmm-hpebk840g7nbpc kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
août 10 17:57:05 lmm-hpebk840g7nbpc kernel: usb: port power management may be unreliable
août 10 17:57:05 lmm-hpebk840g7nbpc kernel: tpm tpm0: [Firmware Bug]: TPM interrupt not working, polling instead
août 10 17:57:05 lmm-hpebk840g7nbpc kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
août 10 17:57:05 lmm-hpebk840g7nbpc kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
août 10 17:57:05 lmm-hpebk840g7nbpc kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
août 10 17:57:06 lmm-hpebk840g7nbpc kernel: thermal thermal_zone12: failed to read out thermal zone (-61)
août 10 17:57:06 lmm-hpebk840g7nbpc kernel: hp_wmi: query 0x4 returned error 0x5
août 10 17:57:06 lmm-hpebk840g7nbpc kernel: hp_wmi: query 0xd returned error 0x5
août 10 17:57:06 lmm-hpebk840g7nbpc kernel: hp_wmi: query 0x1b returned error 0x5
août 10 17:57:06 lmm-hpebk840g7nbpc systemd-udevd[336]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
août 10 17:57:06 lmm-hpebk840g7nbpc systemd-networkd[339]: wlan0: found matching network '/etc/systemd/network/20-wireless.network', based on potentially unpredictable interface name.
août 10 17:57:07 lmm-hpebk840g7nbpc wpa_supplicant[956]: nl80211: kernel reports: Match already configured
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: sof-audio-pci-intel-cnl 0000:00:1f.3: ASoC: Parent card not yet available, widget card binding deferred
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
août 10 17:57:07 lmm-hpebk840g7nbpc kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
août 10 17:57:08 lmm-hpebk840g7nbpc kernel: Bluetooth: hci0: MSFT filter_enable is already on
août 10 17:57:12 lmm-hpebk840g7nbpc kernel: kauditd_printk_skb: 60 callbacks suppressed
août 10 17:57:16 lmm-hpebk840g7nbpc pulseaudio[1783]: stat('/etc/pulse/default.pa.d'): Aucun fichier ou dossier de ce type
août 10 17:57:16 lmm-hpebk840g7nbpc pulseaudio[1783]: GetManagedObjects() failed: org.freedesktop.systemd1.NoSuchUnit: Unit dbus-org.bluez.service not found.
août 10 17:57:16 lmm-hpebk840g7nbpc tumblerd[1824]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.6.so.0: cannot open shared object file: No such file or directory
août 10 17:57:18 lmm-hpebk840g7nbpc kernel: kauditd_printk_skb: 74 callbacks suppressed
août 10 17:57:18 lmm-hpebk840g7nbpc NetworkManager[593]: <warn> [1628611038.5616] dns-sd-resolved[18b289f714ccffd7]: send-updates SetLinkDomains@3 failed: GDBus.Error:org.freedesktop.resolve1.LinkBusy: Link wlan0 is manag>
août 10 18:10:25 lmm-hpebk840g7nbpc upowerd[1769]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-4/1-4:1.2/0003:046D:C52B.0003/0003:046D:101A.0004/power_supply/hidpp_battery_0
Does that mean “too many” services are tying to manage the same function (controling wireless card)?
Or I am wrong?
Shall I be concern (and what could I do)?
