Tips and Tricks for i3
These are a few tips and tricks I have come up with for i3
Here is a cheat sheet for the different key combinations which comes in handy when learning i3
Here is the cheat sheet
To set it as your background:
copy the desired background image file to ~/Pictures
Ensure feh is installed, if not
# pacman -S feh
Then vi ~/.config/i3/config and add the following two lines
# Set background
exec_always --no-startup-id feh - -bg-scale /home/$USER/Pictures/CheatSheet.png
Then you have to reboot for it to take affect.
Now if you’re doing something and just can’t remember the key combination, press $mod+ any unused workspace, and there is our cheat sheet. Then switch back to the workspace you were in.
i3 doesn’t have any default key combinations that start with $mod+Ctrl. So we have a blank canvas here. I feel any modifications made by the user should be as a $mod+Ctrl+something combination just to keep things organized. So here goes:
Instead of Mod+Shift+e then get the nag bar and click on “Yes, exit i3” to logout, and these lines to ~/.config/i3/config for an instant log-out
# Instant log out
bindsym $mod+Crtl+l exec i3-msg exit
That’s $mod+Crtl+lower case letter L I chose the letter L for logout. Choose what you want.
dmenu ($mod+d) output is rather cluttered. i3-dmenu-desktop only lists applications that have a corresponding .desktop file. These are generally the most used apps. Add the following to ~.config/i3/conf
# enables i3-dmenu-desktop which only list apps with a .desktop file
bindsym $mod+Ctrl+d exec i3-dmenu-desktop
How to open a application (or more) in a specified window.
From the i3 guide https://i3wm.org/docs/layout-saving.html
Quote
Layout saving/restoring allows you to load a JSON layout file so that you can have a base layout to start working with after powering on your computer. Dynamic use-cases also come to mind: if you frequently need a grid layout of terminals with ping/traceroute commands to diagnose network issues, you can easily automate opening these windows in just the right layout.
i3-save-tree is a tool to save the layout. It will print a JSON representation of i3’s internal layout data structures to stdout. Typically, you may want to take a quick look at the output, then save it to a file and tweak it a little bit:
End quote
Just a reminder, json syntax requires a comma at the end of each statement, and anything after // is a comment.
To do this:
install the anyevent module
# pacman -S perl-anyevent-i3
First, launch the desired app (or apps) in the desired workspace. I’ll use FirefoxNightly in workspace 8 as an example. Once FirefoxNightly is opened in workspace 8
$ i3-save-tree - -workspace 8 > ~/.config/i3/workspace_8.json
This will give the following pseudo json file.
// vim:ts=4:sw=4:et
“border”: “normal”,
“current_border_width”: 2,
“floating”: “auto_off”,
“geometry”: {
“height”: 691,
“width”: 1224,
“x”: 0,
“y”: 0
“name”: “i3: Layout saving in i3 - Nightly”,
“percent”: 1,
“swallows”: [
// “class”: “^Nightly$”,
// “instance”: “^Navigator$”,
// “title”: “^i3\:\ Layout\ saving\ in\ i3\ \-\ Nightly$”,
// “window_role”: “^browser$”
“type”: “con”
We have to modify it into a syntax correct json file.
In your favorite text editor
delete line 1 // vim:ts=4:sw=4:et
delete the line “name”: “i3: Layout saving in i3 – Nightly”,
delete the line // “title”: “^i3\:\ Layout\ saving\ in\ i3\ \-\ Nightly$”,
remove the comment ( // ) from
You should end up with this
“border”: “normal”,
“geometry”: {
“height”: 691,
“width”: 1224,
“x”: 0,
“y”: 0
“percent”: 1,
“swallows”: [
“type”: “con”
Next create a script in ~/.config/i3
$ vi start_w8.sh
#!  /bin/bash
i3-msg -q "workspace 8; append_layout ~/.config/i3/workspace_8.json"
# and finally we fill the containers with the programs they had
(flatpak run org.mozilla.FirefoxNightly &)
save the start_w8.sh file and make it executable.
The above start_w8.sh file shows how to start FirefoxNightly, which is a flatpak.
To start regular Firefox that’s from the Arch repository, change to
(firefox &)
Use whatever you type in to run it from the terminal plus & to run it in the background
Now, edit the ~/.config/i3/config file, and add the following:
# bind App to a specific workspace
bindsym $mod+Ctrl+f  exec ~/.config/i3/start_w8.sh
and Firefox will start in workspace 8. I chose $mod+Ctrl+f so I can remember f for Firefox, you can choose whatever key you want.
I have also done $mod+Ctrl+v for VLC in workspace 7
and $mod+Ctrl+c for Visual Studio Code in workspace 9
and the json files were fairly similar, I had to play around with one of them but a little trial and error got it.
Enjoy playing with i3
Certain programs cannot be set to open to a specific workspace (they ignore the command). Instead, use the “catch and move” command for those.
I had to do that for Spotify when I ran i3, for example.
Aka use the “for_window” rule instead of the “assign” rule.
Install nitrogen $sudo pacman -S nitrogen
Use nitrogen to set a background image and in your i3 conf add the following line
exec --no-startup-id nitrogen --restore
awesome wm inspired auto layout script for i3wm
:pray: for share . That show wonder of linux ( you build what fit you ) i more simple and like control how + where window open ( that me ) That why i stay with i3 or sway :blush: simple ,easy + get job done . in past i use near all type WM + enjoy all ( there no best ) now day i just want get up + run fast + minimal setup.
EDit … @Pudge dark horse !! i shock see i3 post by you + long ago
What is the different between awesome-auto-layout and autotiling.
I am used to autotiling. Using xfce at the moment. Planning to configure i3 again.
Should i switch to awesome-auto-layout …
like awesomewm
awesome-auto-layout
Like bspwm
autotiling
ps: i use alternating_layouts instead of autotiling
if you like awesome layout then awesome-auto-layout
if you like bspwm layout then autotiling
but i like awesome so i choice awesome-auto-layout it is very cool :slightly_smiling_face:
It looks like I need to test them all for a while.
Although autotiling seems pretty ok for me.
:penguin:
Tiny script to show your i3wm keybindings with dmenu
#!/bin/bash
I3_CONFIG=$HOME/.config/i3/config
mod_key=$(sed -nre 's/^set \$mod (.*)/\1/p' ${I3_CONFIG})
grep "^bindsym" ${I3_CONFIG} \
    | sed "s/-\(-\w\+\)\+//g;s/\$mod/${mod_key}/g;s/Mod1/Alt/g;s/exec //;s/bindsym //;s/^\s\+//;s/^\([^ ]\+\) \(.\+\)$/\2: \1/;s/^\s\+//" \
    | tr -s ' ' \
    | dmenu
Tiny script to show your i3wm keybindings with rofi
    | tr -s ' ' \
    | rofi -dmenu -i -markup-rows -no-show-icons -width 1000 -lines 15 -yoffset 40
or mod +f1 ( think Endeavouros still use it ) again you make your system simple or complicated for your needs :+1: that the wonder of linux :vulcan_salute:
Still there.
are Endeavouros using yad to this???
If you mean the mod + F1 thing it’s in the config to exec a xed file.
2021-07-16-10:30:25-screenshot
not everyone uses Endeavouros
therefore I would put it on for those who can use it
and I’m not using Endeavouros right now
that’s the beauty of linux you can do almost anything you want
yes now i remember with xed
but I prefer with rofi or dmenu
since I do not have xed installed
I no using endeavour i3 for main just my own i3 arch but do same way :+1: no right or wrong way in linux
like this
2021-07-16-164317_1920x1080_scrot
perfect ! both way work ( if you need ) choice is good :vulcan_salute:
