It is odd that every app, VM, Virt Manager all copy & paste just fine. The terminals are butts. I use both Zsh (99%) and bash. I have looked at both configs and there is nothing there that I see would cause it. Just don’t know.
I have removed Zsh and reinstalled it with a stock RC file and still the same.
Hahaha. I was hoping to avoid the reinstall butttttt not out of the question…
I would like to know what is causing this before the nuke and pave… Lol
I do use a install script that installs all the same software on all the systems and copies my configs from my gitlab. that is why there all the same…
I just don’t get it…
I always get these ballbusters of a issue… Lol
Like I said, did not change anything, I just did a update of Endeavour… Lol
I use Window managers and have all my own keybindings set.
I will look that the 2nd link about the clipboard.
Also I don’t have a clipboard manager installed. Just whatever Endeavour & Cinnamon install that has worked up to 6 weeks ago before this awesome ride started… Lol
This says everything, and makes things simple.
Just compare folders and files
As a quick check you could try renaming/deleting selected dot files like Xresources (harmless), or other (not bashrc, xprofile, profile). Comparing should reveal the issue source IMHO.
Removed .Xresources & .xdefaults files along with .bashrc and .zshrc (one at a time for these) and still the same thing. I’m sure I have tried this before too.
I even logged in to both my user and the new user I added today per request.
Even though I have NOT changed any config files in 6 weeks I went through them over and over and I just don’t see anything…
I don’t get what is different in my user and the new one I added today that makes this double paste thing happen and not happen. I even added the new user to the Admin/wheel group just like me and NO double pasting.
I don’t use a .xinitrc, .xprofile, just a .profile and it is mostly empty, just pointing to my ~/bin folder. Well comparing has not helped yet… So I guess it doesn’t say enough… Lol
A, the internet… Lol No I did not make it.
It could be from Distro Tube, Old Tech Bloke, it’s hard to say. I have used it for 4 years with no issues. It does makes Xterm look better… Lol
Well the nuke and pave will most likely be what I will do.
I keep a separate /Home on its own drive and just mount it after a install in the fstab.
Yes I do and that’s what my XBT backup script and USB drive is for…
Will report back in a day or two. thanks for your help!
Well, I am the biggest dumb, idiot, old fart, dun ass that has ever laid hands on a keyboard.
I said that is was switching between Bash & Zsh when I was doing the testing for the double pasting in any terminal.
Well my dumb ass for got to logout when switching from Zsh to Bash when testing.
I found the issue and here is why the logout was a thing.
When switching from Zsh to Bash, some of the Zsh settings must still be in memory and effecting Bash’s output as well. The sad part I was doing this the hole time and never once thought about logging out!
I have had 5 hours of fun logging in and out just to find out the issue was my Zsh theme prompt. For some reason Powerlevel 10k Theme is broke! It is a old version and it was working so I did not bother to update it and NOW it is NOT working…
I have not really installed my .oh-my-zsh folder I just copy it to the new systems because of the custom themes I have made…
I went through my .zshrc file one section at a time and rewrote it and that is how I figured it out. My best guess is that something changed in Zsh that my old 10k theme did not like!
All 3 computers are copying and pasting as they should!
Thanks everyone for your help and thoughts! This is the best forum Ever!
if using oh-my I would recommend to use the git way not the package… as it will ask for updating on its own… and on users config… package will not do this I think…
I am using it that way for years without a little issue…
sorry … but i mentioned already that i like my personal bloat a lot!
I am working on a new OS BlackscreenOS Only TTY no bloat not even X no bootloader no mouse drivers.
but
issue here solved.
