System wont boot, stuck at ''Reached target graphical interface''
This started after i updated my system yesterday, when i reboot it started to get stuck in ''Reached target Graphical interface"
After following this guide i found out that the problem seems to be xorg.
here is the log
[    58.405]
X.Org X Server 1.21.1.4
X Protocol Version 11, Revision 0
[    58.405] Current Operating System: Linux system 5.19.3-arch1-1 #1 SMP PREEMPT_DYNAMIC Sun, 21 Aug 2022 18:55:22 +0000 x86_64
[    58.405] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=dc4fd39e-a2a4-47b3-99a3-03dab18f497c rw cryptdevice=UUID=1d44807d-2467-4564-9b5d-62b8c7830861:luks-1d44807d-2467-4564-9b5d-62b8c7830861 root=/dev/mapper/luks-1d44807d-2467-4564-9b5d-62b8c7830861 loglevel=3 nowatchdog nvme_load=YES nvidia-drm.modeset=1 pcie_aspm=off
[    58.406]
[    58.406] Current version of pixman: 0.40.0
[    58.406] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    58.406] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    58.406] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Aug 24 14:18:01 2022
[    58.477] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    58.477] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    58.538] (==) No Layout section.  Using the first Screen section.
[    58.538] (==) No screen section available. Using defaults.
[    58.538] (**) |-->Screen "Default Screen Section" (0)
[    58.538] (**) |   |-->Monitor "<default monitor>"
[    58.539] (==) No monitor specified for screen "Default Screen Section".
	Using a default monitor configuration.
[    58.539] (==) Automatically adding devices
[    58.539] (==) Automatically enabling devices
[    58.539] (==) Automatically adding GPU devices
[    58.539] (==) Automatically binding GPU devices
[    58.539] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    58.562] (WW) The directory "/usr/share/fonts/misc" does not exist.
[    58.562] 	Entry deleted from font path.
[    58.576] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[    58.576] 	Entry deleted from font path.
[    58.576] 	(Run 'mkfontdir' on "/usr/share/fonts/TTF").
[    58.576] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    58.576] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    58.576] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[    58.576] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[    58.576] (==) FontPath set to:
[    58.576] (==) ModulePath set to "/usr/lib/xorg/modules"
[    58.576] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    58.576] (II) Module ABI versions:
[    58.576] 	X.Org ANSI C Emulation: 0.4
[    58.577] 	X.Org Video Driver: 25.2
[    58.577] 	X.Org XInput driver : 24.4
[    58.577] 	X.Org Server Extension : 10.0
[    58.578] (++) using VT number 2
[    58.582] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[    58.587] (--) PCI:*(1@0:0:0) 10de:1f08:10de:12fd rev 161, Mem @ 0xa3000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/131072
[    58.587] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    58.587] (II) LoadModule: "glx"
[    58.602] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    58.632] (II) Module glx: vendor="X.Org Foundation"
[    58.632] 	compiled for 1.21.1.4, module version = 1.0.0
[    58.632] 	ABI class: X.Org Server Extension, version 10.0
[    58.633] (==) Matched nouveau as autoconfigured driver 0
[    58.633] (==) Matched nv as autoconfigured driver 1
[    58.633] (==) Matched modesetting as autoconfigured driver 2
[    58.633] (==) Matched fbdev as autoconfigured driver 3
[    58.633] (==) Matched vesa as autoconfigured driver 4
[    58.633] (==) Assigned the driver to the xf86ConfigLayout
[    58.633] (II) LoadModule: "nouveau"
[    58.633] (WW) Warning, couldn't open module nouveau
[    58.633] (EE) Failed to load module "nouveau" (module does not exist, 0)
[    58.633] (II) LoadModule: "nv"
[    58.633] (WW) Warning, couldn't open module nv
[    58.633] (EE) Failed to load module "nv" (module does not exist, 0)
[    58.633] (II) LoadModule: "modesetting"
[    58.634] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    58.656] (II) Module modesetting: vendor="X.Org Foundation"
[    58.656] 	compiled for 1.21.1.4, module version = 1.21.1
[    58.657] 	Module class: X.Org Video Driver
[    58.657] 	ABI class: X.Org Video Driver, version 25.2
[    58.657] (II) LoadModule: "fbdev"
[    58.657] (WW) Warning, couldn't open module fbdev
[    58.657] (EE) Failed to load module "fbdev" (module does not exist, 0)
[    58.657] (II) LoadModule: "vesa"
[    58.657] (WW) Warning, couldn't open module vesa
[    58.657] (EE) Failed to load module "vesa" (module does not exist, 0)
[    58.657] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    58.657] (EE) open /dev/dri/card0: No such file or directory
[    58.657] (WW) Falling back to old probe method for modesetting
[    58.657] (EE) Screen 0 deleted because of no matching config section.
[    58.657] (II) UnloadModule: "modesetting"
[    58.657] (EE) Device(s) detected, but none match those in the config file.
[    58.657] (EE)
Fatal server error:
[    58.658] (EE) no screens found(EE)
[    58.658] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[    58.658] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    58.658] (EE)
[    58.661] (EE) Server terminated with error (1). Closing log file.
Since you mention updating yesterday, you may want to start here to rule this problem out:
If needed, do Ctrl-Alt-F2 for a tty, then update, and reboot.
EDIT: corrected link to proper message, for clarity
The first thing i did was update the system with
sudo reflector -a6 -f5 --save /etc/pacman.d/mirrorlist
sudo pacman -Syyu
I tried it again and still the same error, maybe my mirrorlist has a problem?
Can you post the output of inxi -G here
and the same for journalctl -b -0 | eos-sendlog pleasel?
You have an AMD gpu as far as i can see, is that correct?
https://clbin.com/wxIE7
https://clbin.com/BFwdj
Weird, seems to be a driver issue? and no, my graphics card is a nvidia rtx 2060.
then your fix is probably written down in this post already.
sudo pacman -Syu
sudo pacman -S nvidia-dkms
reboot
Worked like a charm, thanks man you made my day.
