not sure if this is right place for this…installed EOS yesterday with no problems, but when attempting
System update I get the following errors…it looks like the 2 flagged pkgs installed, but still give errors
:: Retrieving packages...
exfatprogs-1.1.3-1-x86_64 39.6 KiB 160 KiB/s 00:00 [--------------------------------------------------------------------] 100%
pcsclite-1.9.4-1-x86_64 99.3 KiB 209 KiB/s 00:00 [--------------------------------------------------------------------] 100%
Total (2/2) 138.9 KiB 239 KiB/s 00:01 [--------------------------------------------------------------------] 100%
(298/298) checking keys in keyring [--------------------------------------------------------------------] 100%
(298/298) checking package integrity [--------------------------------------------------------------------] 100%
error: exfatprogs: signature from "Frederik Schwan <frederik.schwan@linux.com>" is unknown trust
:: File /var/cache/pacman/pkg/exfatprogs-1.1.3-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] n
error: pcsclite: signature from "Frederik Schwan <frederik.schwan@linux.com>" is unknown trust
:: File /var/cache/pacman/pkg/pcsclite-1.9.4-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
AUR update check:
:: Searching AUR for updates...
there is nothing to do~~~
machine info:
~~~System:
Host: THOTH-OPTOPLEX-9020 Kernel: 5.13.12-arch1-1 x86_64 bits: 64
Desktop: Xfce 4.16.0 Distro: EndeavourOS
Type: Desktop System: Dell product: OptiPlex 9020 v: 00
serial: <superuser required>
Mobo: Dell model: 00V62H v: A01 serial: <superuser required> BIOS: Dell
v: A15 date: 11/08/2015
Info: Quad Core model: Intel Core i5-4570 bits: 64 type: MCP cache:
L2: 6 MiB
Speed: 2252 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 2252 2: 2195
3: 1810 4: 3193
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
driver: i915 v: kernel
Display: x11 server: X.org 1.20.13 driver: loaded: intel
unloaded: fbdev,modesetting,vesa resolution: <missing: xdpyinfo>
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel
Device-2: Intel 8 Series/C220 Series High Definition Audio
Sound Server-1: ALSA v: k5.13.12-arch1-1 running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Device-1: Intel Ethernet I217-LM driver: e1000e
IF: eno1 state: down mac: 18:66:da:02:79:c1
Device-2: Edimax EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
type: USB driver: rtl8192cu
IF: wlan0 state: up mac: 80:1f:02:b6:d2:ce
RAID:
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci
Local Storage: total: 476.94 GiB used: 5.74 GiB (1.2%)
ID-1: /dev/sda model: 30TT253X2-512GB size: 476.94 GiB
ID-1: / size: 229.33 GiB used: 5.74 GiB (2.5%) fs: ext4 dev: /dev/sda3
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Fan Speeds (RPM): N/A
Processes: 183 Uptime: 10m Memory: 15.54 GiB used: 1.28 GiB (8.2%)
Shell: Bash inxi: 3.3.05~~~
