Can you share the output of cat /mnt/etc/fstab
of course
[liveuser@eos-2024.04.20 ~]$ cat /mnt/etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=2EB3-A4CA /boot/efi vfat fmask=0137,dmask=0027 0 2
/dev/mapper/luks-9a1b844b-9084-4124-ab92-c63ad10510dd / ext4 noatime 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
#UUID=30af7f66-0d22-4e09-9dc4-9d6ff927e892 /run/media/iam/storage ext4 defaults,relatime 0 2
#/dev/mapper/fast /run/media/iam/fast-storage ext4 defaults 0 2
Try this:
sudo cp /usr/lib/libncursesw.so.6 /mnt/usr/lib/.
sudo arch-chroot /mnt
If that works, add ncurses to the list of packages you reinstall after paccheck
Brilliant! (I am so dumb) ![]()
Iβll write about results when make what you advice to make
Thanks a lot!
iβve had this problem as well, pretty sure itβs the nvidia driver update that causes it, itβs happened to me like 3 times. the general solution is this (UNSAFE!!) command:
pacman -S --overwrite "*" $(pacman -Qqn)
What it does is forcefully reinstall all packages of your system, overwriting any pre-existing files with the default one, in a nutshell this means any system configs you had in /etc/ or other places where the config file is created by installing the package will be overwritten with their default values (hence unsafe)
You can probably get away with only reinstalling the packages that were being installed by your update at the time of the crash (i havenβt confirmed this but itβs what iβll try next time) which you can figure out from /var/log/pacman.log
If that on itβs own wonβt solve the problem you may also need to replace dbus-broker-units with dbus-daemon-units as I had to do that the first time around as well (the system dbus socket error you keep getting, it fixed that for me), the transition between the two is not painless and some packages will probably need to be reinstalled after switching them.
You donβt need to something this extreme. Instead, you can use the command I posted above to determine which packages are broken.
This isnβt how it works actually. Config files will usually be in the backup array.
That does look convenient, i will be trying that next time it happens, seems like this is gonna be a regular thing (thanks, nvidia).
There is a known issue in the 550 driver.
I tried and it helps! But not completely. System still stuck ![]()
at first I run
paccheck --list-broken --md5sum
and about 15 packages appear. I updated them with pacman -S then run pacman -S linux-lts. After that reboot.
The things was running pretty good, most of errors during startup are gone.
But few left.
journalctl -p3 -xb -1
[root@EndeavourOS /]# journalctl -p3 -xb -1
Apr 25 05:19:42 thevoid kernel: x86/cpu: SGX disabled by BIOS.
Apr 25 05:19:43 thevoid kernel:
Apr 25 05:19:53 thevoid kernel: nvidia-gpu 0000:01:00.3: i2c timeout error e0000000
Apr 25 05:19:53 thevoid kernel: ucsi_ccg 8-0008: i2c_transfer failed -110
Apr 25 05:19:53 thevoid kernel: ucsi_ccg 8-0008: ucsi_ccg_init failed - -110
Apr 25 05:20:00 thevoid systemd[1]: Failed to start D-Bus System Message Bus.
ββ Subject: A start job for unit dbus-broker.service has failed
ββ Defined-By: systemd
ββ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
ββ
ββ A start job for unit dbus-broker.service has finished with a failure.
ββ
ββ The job identifier is 287 and the job result is failed.
ββ
ββ
ββ The job identifier is 735 and the job result is failed.
ββ
ββ
ββ The job identifier is 850 and the job result is failed.
ββ
ββ
ββ The job identifier is 965 and the job result is failed.
ββ
ββ
ββ The job identifier is 1080 and the job result is failed.
ββ
ββ
ββ The job identifier is 1195 and the job result is failed.
Apr 25 05:20:00 thevoid systemd-logind[1400]: Failed to connect to system bus: Connection refused
Apr 25 05:20:00 thevoid systemd-logind[1400]: Failed to fully start up daemon: Connection refused
Apr 25 05:20:00 thevoid systemd[1]: Failed to start User Login Management.
ββ Subject: A start job for unit systemd-logind.service has failed
ββ
ββ A start job for unit systemd-logind.service has finished with a failure.
ββ
ββ The job identifier is 296 and the job result is failed.
ββ
ββ
ββ The job identifier is 1427 and the job result is failed.
Apr 25 05:20:00 thevoid avahi-daemon[1397]: dbus_bus_get_private(): Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Apr 25 05:20:00 thevoid firewalld[1399]: ERROR: Exception DBusException: org.freedesktop.DBus.Error.NoServer: Failed to connect to socket /run/dbus/system_bus_socket: Connection refused
Apr 25 05:20:00 thevoid systemd-logind[1410]: Failed to connect to system bus: Connection refused
Apr 25 05:20:00 thevoid systemd-logind[1410]: Failed to fully start up daemon: Connection refused
Apr 25 05:20:00 thevoid systemd[1]: Failed to start Avahi mDNS/DNS-SD Stack.
ββ Subject: A start job for unit avahi-daemon.service has failed
ββ
ββ A start job for unit avahi-daemon.service has finished with a failure.
ββ
ββ The job identifier is 295 and the job result is failed.
Apr 25 05:20:01 thevoid systemd[1]: Failed to start User Login Management.
ββ
ββ
ββ The job identifier is 1310 and the job result is failed.
Apr 25 05:20:01 thevoid systemd[1]: Failed to start D-Bus System Message Bus.
ββ
ββ
ββ The job identifier is 1659 and the job result is failed.
Login Manager starts. Good. And also problem starts. Login Screen except avatar and input field completely white. After credentials entered system and dm doesnβt boot, I can only see cursor on the black screen.
After that I run livecd again and try to repeat process. paccheck shows me only one line
lsb-release
I tried to update it and kernel package but situation with main system leaves the same and after reboot into livecd paccheck continues show this package.
I also noticed some strange lines during update
:: Processing package changes...
(1/1) reinstalling lsb-release [---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------] 100%
ldconfig: File /usr/lib/libfwupd.so is empty, not checked.
ldconfig: File /usr/lib/libnvidia-opencl.so.1 is empty, not checked.
ldconfig: File /usr/lib/libnvidia-opencl.so.550.76 is empty, not checked.
ldconfig: File /usr/lib/libfwupd.so.2 is empty, not checked.
ldconfig: File /usr/lib/libfwupd.so.2.0.0 is empty, not checked.
ldconfig: File /usr/lib/libnvidia-opencl.so is empty, not checked.
looks like some nvidia packages or libraries is broken and prepend to update this package. And they probbaly break system start.
I tried reinstall nvidia with pacman -S by two ways
Way1:
pacman -S nvidia nvidia-utils
I broke this installation because nvidia depends on non lts linux kernel package
Way2:
pacman -S nvidia-lts nvidia-utils
process ran and completed successfuly, but with the same lines those in this post above, like during install lsb-release
looks like i need somehow reinstall nvidia libs but ways tried didnβt help. May you advice something?
Thanks everyone for all your help.
Finally iβve been able to boot!
Hereβs what i did:
- Checked for broken packages by finding this on Arch Linux forum:
sudo LC_ALL=C pacman -Qkk | grep -v ', 0 altered files'
Output
warning: appstream: /usr/lib/appstreamcli-compose (Modification time mismatch)
warning: appstream: /usr/lib/appstreamcli-compose (SHA256 checksum mismatch)
warning: appstream: /usr/lib/libappstream-compose.so (Modification time mismatch)
warning: appstream: /usr/lib/libappstream-compose.so.0 (Symlink path mismatch)
warning: appstream: /usr/lib/libappstream-compose.so.0 (Modification time mismatch)
warning: appstream: /usr/lib/libappstream-compose.so.1.0.3 (No such file or directory)
warning: appstream: /usr/lib/libappstream.so (Modification time mismatch)
warning: appstream: /usr/lib/libappstream.so.1.0.3 (No such file or directory)
warning: appstream: /usr/lib/libappstream.so.5 (Symlink path mismatch)
warning: appstream: /usr/lib/libappstream.so.5 (Modification time mismatch)
warning: appstream: /usr/lib/girepository-1.0/AppStream-1.0.typelib (Modification time mismatch)
warning: appstream: /usr/lib/girepository-1.0/AppStream-1.0.typelib (SHA256 checksum mismatch)
warning: appstream: /usr/lib/girepository-1.0/AppStreamCompose-1.0.typelib (Modification time mismatch)
warning: appstream: /usr/lib/pkgconfig/appstream-compose.pc (Modification time mismatch)
warning: appstream: /usr/lib/pkgconfig/appstream-compose.pc (SHA256 checksum mismatch)
warning: appstream: /usr/lib/pkgconfig/appstream.pc (Modification time mismatch)
warning: appstream: /usr/lib/pkgconfig/appstream.pc (SHA256 checksum mismatch)
warning: appstream-qt: /usr/lib/libAppStreamQt.so (Modification time mismatch)
warning: appstream-qt: /usr/lib/libAppStreamQt.so.1.0.3 (No such file or directory)
warning: appstream-qt: /usr/lib/libAppStreamQt.so.3 (Symlink path mismatch)
warning: appstream-qt: /usr/lib/libAppStreamQt.so.3 (Modification time mismatch)
warning: appstream-qt: /usr/lib/cmake/AppStreamQt/AppStreamQtConfig.cmake (Modification time mismatch)
warning: appstream-qt: /usr/lib/cmake/AppStreamQt/AppStreamQtConfig.cmake (Size mismatch)
warning: appstream-qt: /usr/lib/cmake/AppStreamQt/AppStreamQtConfig.cmake (SHA256 checksum mismatch)
warning: appstream-qt: /usr/lib/cmake/AppStreamQt/AppStreamQtConfigVersion.cmake (Modification time mismatch)
warning: appstream-qt: /usr/lib/cmake/AppStreamQt/AppStreamQtConfigVersion.cmake (SHA256 checksum mismatch)
warning: appstream-qt5: /usr/lib/libAppStreamQt5.so (Modification time mismatch)
warning: appstream-qt5: /usr/lib/libAppStreamQt5.so.1.0.3 (No such file or directory)
warning: appstream-qt5: /usr/lib/libAppStreamQt5.so.3 (Symlink path mismatch)
warning: appstream-qt5: /usr/lib/libAppStreamQt5.so.3 (Modification time mismatch)
warning: appstream-qt5: /usr/lib/cmake/AppStreamQt5/AppStreamQt5Config.cmake (Modification time mismatch)
warning: appstream-qt5: /usr/lib/cmake/AppStreamQt5/AppStreamQt5Config.cmake (Size mismatch)
warning: appstream-qt5: /usr/lib/cmake/AppStreamQt5/AppStreamQt5Config.cmake (SHA256 checksum mismatch)
warning: appstream-qt5: /usr/lib/cmake/AppStreamQt5/AppStreamQt5ConfigVersion.cmake (Modification time mismatch)
warning: appstream-qt5: /usr/lib/cmake/AppStreamQt5/AppStreamQt5ConfigVersion.cmake (SHA256 checksum mismatch)
warning: filesystem: /etc/gshadow (Permissions mismatch)
warning: filesystem: /etc/shadow (Permissions mismatch)
warning: filesystem: /usr/lib/os-release (Modification time mismatch)
warning: filesystem: /usr/lib/os-release (Size mismatch)
warning: filesystem: /usr/lib/os-release (SHA256 checksum mismatch)
warning: filesystem: /usr/share/factory/etc/issue (Modification time mismatch)
warning: filesystem: /usr/share/factory/etc/issue (Size mismatch)
warning: filesystem: /usr/share/factory/etc/issue (SHA256 checksum mismatch)
warning: fwupd: /usr/bin/fwupd-dbxtool (Modification time mismatch)
warning: fwupd: /usr/bin/fwupd-dbxtool (Size mismatch)
warning: fwupd: /usr/bin/fwupd-dbxtool (SHA256 checksum mismatch)
warning: fwupd: /usr/bin/fwupdmgr (Modification time mismatch)
warning: fwupd: /usr/bin/fwupdmgr (Size mismatch)
warning: fwupd: /usr/bin/fwupdmgr (SHA256 checksum mismatch)
warning: fwupd: /usr/bin/fwupdtool (Modification time mismatch)
warning: fwupd: /usr/bin/fwupdtool (Size mismatch)
warning: fwupd: /usr/bin/fwupdtool (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/fwupd.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/fwupd.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/fwupd.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-bios-setting.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-bios-setting.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-bios-setting.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-build.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-build.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-build.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-client-sync.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-client-sync.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-client-sync.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-client.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-client.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-client.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-common.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-common.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-common.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-device.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-device.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-device.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-enums.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-enums.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-enums.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-error.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-error.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-error.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-plugin.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-plugin.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-plugin.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-release.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-release.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-release.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-remote.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-remote.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-remote.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-report.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-report.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-report.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-request.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-request.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-request.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-security-attr.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-security-attr.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-security-attr.h (SHA256 checksum mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-version.h (Modification time mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-version.h (Size mismatch)
warning: fwupd: /usr/include/fwupd-1/libfwupd/fwupd-version.h (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/libfwupd.so (Modification time mismatch)
warning: fwupd: /usr/lib/libfwupd.so.2 (Modification time mismatch)
warning: fwupd: /usr/lib/libfwupd.so.2.0.0 (Modification time mismatch)
warning: fwupd: /usr/lib/libfwupd.so.2.0.0 (Size mismatch)
warning: fwupd: /usr/lib/libfwupd.so.2.0.0 (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/fwupd/fwupd (Modification time mismatch)
warning: fwupd: /usr/lib/fwupd/fwupd (Size mismatch)
warning: fwupd: /usr/lib/fwupd/fwupd (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/fwupd/fwupd-detect-cet (Modification time mismatch)
warning: fwupd: /usr/lib/fwupd/fwupd-detect-cet (Size mismatch)
warning: fwupd: /usr/lib/fwupd/fwupd-detect-cet (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/fwupd/fwupdoffline (Modification time mismatch)
warning: fwupd: /usr/lib/fwupd/fwupdoffline (Size mismatch)
warning: fwupd: /usr/lib/fwupd/fwupdoffline (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfu_plugin_flashrom.so (Modification time mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfu_plugin_flashrom.so (Size mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfu_plugin_flashrom.so (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfu_plugin_modem_manager.so (Modification time mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfu_plugin_modem_manager.so (Size mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfu_plugin_modem_manager.so (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfwupdengine.so (Modification time mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfwupdengine.so (Size mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfwupdengine.so (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfwupdplugin.so (Modification time mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfwupdplugin.so (Size mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfwupdplugin.so (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfwupdutil.so (Modification time mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfwupdutil.so (Size mismatch)
warning: fwupd: /usr/lib/fwupd-1.9.18/libfwupdutil.so (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/girepository-1.0/Fwupd-2.0.typelib (Modification time mismatch)
warning: fwupd: /usr/lib/girepository-1.0/Fwupd-2.0.typelib (Size mismatch)
warning: fwupd: /usr/lib/girepository-1.0/Fwupd-2.0.typelib (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/pkgconfig/fwupd.pc (Modification time mismatch)
warning: fwupd: /usr/lib/pkgconfig/fwupd.pc (Size mismatch)
warning: fwupd: /usr/lib/pkgconfig/fwupd.pc (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/systemd/system/fwupd-offline-update.service (Modification time mismatch)
warning: fwupd: /usr/lib/systemd/system/fwupd-offline-update.service (Size mismatch)
warning: fwupd: /usr/lib/systemd/system/fwupd-offline-update.service (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/systemd/system/fwupd-refresh.service (Modification time mismatch)
warning: fwupd: /usr/lib/systemd/system/fwupd-refresh.service (Size mismatch)
warning: fwupd: /usr/lib/systemd/system/fwupd-refresh.service (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/systemd/system/fwupd-refresh.timer (Modification time mismatch)
warning: fwupd: /usr/lib/systemd/system/fwupd-refresh.timer (Size mismatch)
warning: fwupd: /usr/lib/systemd/system/fwupd-refresh.timer (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/systemd/system/fwupd.service (Modification time mismatch)
warning: fwupd: /usr/lib/systemd/system/fwupd.service (Size mismatch)
warning: fwupd: /usr/lib/systemd/system/fwupd.service (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/systemd/system/system-update.target.wants/fwupd-offline-update.service (Modification time mismatch)
warning: fwupd: /usr/lib/systemd/system-shutdown/fwupd.shutdown (Modification time mismatch)
warning: fwupd: /usr/lib/systemd/system-shutdown/fwupd.shutdown (Size mismatch)
warning: fwupd: /usr/lib/systemd/system-shutdown/fwupd.shutdown (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/sysusers.d/fwupd.conf (Modification time mismatch)
warning: fwupd: /usr/lib/sysusers.d/fwupd.conf (Size mismatch)
warning: fwupd: /usr/lib/sysusers.d/fwupd.conf (SHA256 checksum mismatch)
warning: fwupd: /usr/lib/udev/rules.d/90-fwupd-devices.rules (Modification time mismatch)
warning: fwupd: /usr/lib/udev/rules.d/90-fwupd-devices.rules (Size mismatch)
warning: fwupd: /usr/lib/udev/rules.d/90-fwupd-devices.rules (SHA256 checksum mismatch)
warning: fwupd: /usr/share/bash-completion/completions/fwupdmgr (Modification time mismatch)
warning: fwupd: /usr/share/bash-completion/completions/fwupdmgr (Size mismatch)
warning: fwupd: /usr/share/bash-completion/completions/fwupdmgr (SHA256 checksum mismatch)
warning: fwupd: /usr/share/bash-completion/completions/fwupdtool (Modification time mismatch)
warning: fwupd: /usr/share/bash-completion/completions/fwupdtool (Size mismatch)
warning: fwupd: /usr/share/bash-completion/completions/fwupdtool (SHA256 checksum mismatch)
warning: fwupd: /usr/share/dbus-1/interfaces/org.freedesktop.fwupd.xml (Modification time mismatch)
warning: fwupd: /usr/share/dbus-1/interfaces/org.freedesktop.fwupd.xml (Size mismatch)
warning: fwupd: /usr/share/dbus-1/interfaces/org.freedesktop.fwupd.xml (SHA256 checksum mismatch)
warning: fwupd: /usr/share/dbus-1/system-services/org.freedesktop.fwupd.service (Modification time mismatch)
warning: fwupd: /usr/share/dbus-1/system-services/org.freedesktop.fwupd.service (Size mismatch)
warning: fwupd: /usr/share/dbus-1/system-services/org.freedesktop.fwupd.service (SHA256 checksum mismatch)
warning: fwupd: /usr/share/dbus-1/system.d/org.freedesktop.fwupd.conf (Modification time mismatch)
warning: fwupd: /usr/share/dbus-1/system.d/org.freedesktop.fwupd.conf (Size mismatch)
warning: fwupd: /usr/share/dbus-1/system.d/org.freedesktop.fwupd.conf (SHA256 checksum mismatch)
warning: fwupd: /usr/share/doc/fwupd/hsi.html (Modification time mismatch)
warning: fwupd: /usr/share/doc/fwupd/hsi.html (Size mismatch)
warning: fwupd: /usr/share/doc/fwupd/hsi.html (SHA256 checksum mismatch)
warning: fwupd: /usr/share/doc/fwupd/index.html (Modification time mismatch)
warning: fwupd: /usr/share/doc/fwupd/index.html (Size mismatch)
warning: fwupd: /usr/share/doc/fwupd/index.html (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fish/vendor_completions.d/fwupdmgr.fish (Modification time mismatch)
warning: fwupd: /usr/share/fish/vendor_completions.d/fwupdmgr.fish (Size mismatch)
warning: fwupd: /usr/share/fish/vendor_completions.d/fwupdmgr.fish (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/add_capsule_header.py (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/add_capsule_header.py (Size mismatch)
warning: fwupd: /usr/share/fwupd/add_capsule_header.py (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/firmware_packager.py (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/firmware_packager.py (Size mismatch)
warning: fwupd: /usr/share/fwupd/firmware_packager.py (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/install_dell_bios_exe.py (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/install_dell_bios_exe.py (Size mismatch)
warning: fwupd: /usr/share/fwupd/install_dell_bios_exe.py (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/simple_client.py (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/simple_client.py (Size mismatch)
warning: fwupd: /usr/share/fwupd/simple_client.py (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/uefi-capsule-ux.tar.xz (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/uefi-capsule-ux.tar.xz (Size mismatch)
warning: fwupd: /usr/share/fwupd/uefi-capsule-ux.tar.xz (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/8bitdo-nes30pro.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/8bitdo-nes30pro.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/8bitdo-nes30pro.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/8bitdo-sf30pro.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/8bitdo-sf30pro.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/8bitdo-sf30pro.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/8bitdo-sfc30.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/8bitdo-sfc30.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/8bitdo-sfc30.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/aiaiai-h05.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/aiaiai-h05.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/aiaiai-h05.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/bizlink-no-sku-vli.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/bizlink-no-sku-vli.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/bizlink-no-sku-vli.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/corsair-katar-pro-xt.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/corsair-katar-pro-xt.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/corsair-katar-pro-xt.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/corsair-sabre-pro.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/corsair-sabre-pro.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/corsair-sabre-pro.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/corsair-sabre-rgb-pro.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/corsair-sabre-rgb-pro.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/corsair-sabre-rgb-pro.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/dell-kh08p.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/dell-kh08p.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/dell-kh08p.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/dell-wd19tb.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/dell-wd19tb.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/dell-wd19tb.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/fwupd-a3bu-xplained.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/fwupd-a3bu-xplained.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/fwupd-a3bu-xplained.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/fwupd-at90usbkey.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/fwupd-at90usbkey.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/fwupd-at90usbkey.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hp-dock-g5.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hp-dock-g5.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hp-dock-g5.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hughski-colorhug-plus.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hughski-colorhug-plus.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hughski-colorhug-plus.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hughski-colorhug.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hughski-colorhug.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hughski-colorhug.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hughski-colorhug2.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hughski-colorhug2.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hughski-colorhug2.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hyper-no-sku-vli.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hyper-no-sku-vli.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/hyper-no-sku-vli.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/jabra-speak-410.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/jabra-speak-410.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/jabra-speak-410.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/jabra-speak-510.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/jabra-speak-510.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/jabra-speak-510.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/jabra-speak-710.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/jabra-speak-710.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/jabra-speak-710.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-03x7168.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-03x7168.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-03x7168.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-03x7605.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-03x7605.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-03x7605.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-03x7608-vli.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-03x7608-vli.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-03x7608-vli.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-03x7609-cxaudio.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-03x7609-cxaudio.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-03x7609-cxaudio.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-40au0065-vli.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-40au0065-vli.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-40au0065-vli.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-GX90T33021-vli.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-GX90T33021-vli.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/lenovo-GX90T33021-vli.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-bolt-receiver.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-bolt-receiver.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-bolt-receiver.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-k780.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-k780.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-k780.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-m650.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-m650.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-m650.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-m750.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-m750.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-m750.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-mr0077.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-mr0077.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-mr0077.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-rqr12-signed.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-rqr12-signed.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-rqr12-signed.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-rqr12.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-rqr12.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-rqr12.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-rqr24-signed.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-rqr24-signed.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-rqr24-signed.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-rqr24.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-rqr24.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/logitech-rqr24.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/nordic-hid-nrf52840-mcuboot.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/nordic-hid-nrf52840-mcuboot.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/nordic-hid-nrf52840-mcuboot.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/realtek-rts5423.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/realtek-rts5423.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/realtek-rts5423.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/realtek-rts5855.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/realtek-rts5855.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/realtek-rts5855.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/synaptics-prometheus.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/synaptics-prometheus.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/synaptics-prometheus.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/ugreen-cm260.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/ugreen-cm260.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/ugreen-cm260.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/wacom-intuos-bt-m.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/wacom-intuos-bt-m.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/wacom-intuos-bt-m.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/wacom-intuos-bt-s.json (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/wacom-intuos-bt-s.json (Size mismatch)
warning: fwupd: /usr/share/fwupd/device-tests/wacom-intuos-bt-s.json (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/host-emulate.d/thinkpad-p1-iommu.json.gz (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/host-emulate.d/thinkpad-p1-iommu.json.gz (Size mismatch)
warning: fwupd: /usr/share/fwupd/host-emulate.d/thinkpad-p1-iommu.json.gz (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/metainfo/org.freedesktop.fwupd.remotes.lvfs-testing.metainfo.xml (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/metainfo/org.freedesktop.fwupd.remotes.lvfs-testing.metainfo.xml (Size mismatch)
warning: fwupd: /usr/share/fwupd/metainfo/org.freedesktop.fwupd.remotes.lvfs-testing.metainfo.xml (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/metainfo/org.freedesktop.fwupd.remotes.lvfs.metainfo.xml (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/metainfo/org.freedesktop.fwupd.remotes.lvfs.metainfo.xml (Size mismatch)
warning: fwupd: /usr/share/fwupd/metainfo/org.freedesktop.fwupd.remotes.lvfs.metainfo.xml (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/quirks.d/builtin.quirk.gz (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/quirks.d/builtin.quirk.gz (Size mismatch)
warning: fwupd: /usr/share/fwupd/quirks.d/builtin.quirk.gz (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/remotes.d/fwupd-tests.conf (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/remotes.d/fwupd-tests.conf (Size mismatch)
warning: fwupd: /usr/share/fwupd/remotes.d/fwupd-tests.conf (SHA256 checksum mismatch)
warning: fwupd: /usr/share/fwupd/remotes.d/vendor/firmware/README.md (Modification time mismatch)
warning: fwupd: /usr/share/fwupd/remotes.d/vendor/firmware/README.md (Size mismatch)
warning: fwupd: /usr/share/fwupd/remotes.d/vendor/firmware/README.md (SHA256 checksum mismatch)
warning: fwupd: /usr/share/gir-1.0/Fwupd-2.0.gir (Modification time mismatch)
warning: fwupd: /usr/share/gir-1.0/Fwupd-2.0.gir (Size mismatch)
warning: fwupd: /usr/share/gir-1.0/Fwupd-2.0.gir (SHA256 checksum mismatch)
warning: fwupd: /usr/share/icons/hicolor/scalable/apps/org.freedesktop.fwupd.svg (Modification time mismatch)
warning: fwupd: /usr/share/icons/hicolor/scalable/apps/org.freedesktop.fwupd.svg (Size mismatch)
warning: fwupd: /usr/share/icons/hicolor/scalable/apps/org.freedesktop.fwupd.svg (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/af/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/af/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/af/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/ast/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/ast/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/ast/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/ca/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/ca/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/ca/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/cs/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/cs/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/cs/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/da/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/da/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/da/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/de/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/de/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/de/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/en_GB/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/en_GB/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/en_GB/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/eo/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/eo/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/eo/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/es/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/es/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/es/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/eu/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/eu/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/eu/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/fi/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/fi/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/fi/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/fr/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/fr/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/fr/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/fur/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/fur/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/fur/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/gl/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/gl/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/gl/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/he/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/he/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/he/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/hi/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/hi/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/hi/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/hr/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/hr/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/hr/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/hu/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/hu/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/hu/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/id/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/id/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/id/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/it/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/it/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/it/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/ja/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/ja/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/ja/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/ka/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/ka/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/ka/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/kk/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/kk/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/kk/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/ko/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/ko/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/ko/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/ky/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/ky/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/ky/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/lt/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/lt/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/lt/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/nl/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/nl/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/nl/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/oc/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/oc/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/oc/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/pa/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/pa/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/pa/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/pl/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/pl/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/pl/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/pt/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/pt/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/pt/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/pt_BR/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/pt_BR/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/pt_BR/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/ru/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/ru/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/ru/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/si/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/si/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/si/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/sk/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/sk/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/sk/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/sr/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/sr/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/sr/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/sv/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/sv/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/sv/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/tr/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/tr/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/tr/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/uk/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/uk/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/uk/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/zh_CN/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/zh_CN/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/zh_CN/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/locale/zh_TW/LC_MESSAGES/fwupd.mo (Modification time mismatch)
warning: fwupd: /usr/share/locale/zh_TW/LC_MESSAGES/fwupd.mo (Size mismatch)
warning: fwupd: /usr/share/locale/zh_TW/LC_MESSAGES/fwupd.mo (SHA256 checksum mismatch)
warning: fwupd: /usr/share/man/man1/fwupd-dbxtool.1.gz (Modification time mismatch)
warning: fwupd: /usr/share/man/man1/fwupd-dbxtool.1.gz (Size mismatch)
warning: fwupd: /usr/share/man/man1/fwupd-dbxtool.1.gz (SHA256 checksum mismatch)
warning: fwupd: /usr/share/man/man1/fwupdmgr.1.gz (Modification time mismatch)
warning: fwupd: /usr/share/man/man1/fwupdmgr.1.gz (Size mismatch)
warning: fwupd: /usr/share/man/man1/fwupdmgr.1.gz (SHA256 checksum mismatch)
warning: fwupd: /usr/share/man/man1/fwupdtool.1.gz (Modification time mismatch)
warning: fwupd: /usr/share/man/man1/fwupdtool.1.gz (Size mismatch)
warning: fwupd: /usr/share/man/man1/fwupdtool.1.gz (SHA256 checksum mismatch)
warning: fwupd: /usr/share/man/man5/fwupd-remotes.d.5.gz (Modification time mismatch)
warning: fwupd: /usr/share/man/man5/fwupd-remotes.d.5.gz (Size mismatch)
warning: fwupd: /usr/share/man/man5/fwupd-remotes.d.5.gz (SHA256 checksum mismatch)
warning: fwupd: /usr/share/man/man5/fwupd.conf.5.gz (Modification time mismatch)
warning: fwupd: /usr/share/man/man5/fwupd.conf.5.gz (Size mismatch)
warning: fwupd: /usr/share/man/man5/fwupd.conf.5.gz (SHA256 checksum mismatch)
warning: fwupd: /usr/share/man/man8/fwupd-refresh.service.8.gz (Modification time mismatch)
warning: fwupd: /usr/share/man/man8/fwupd-refresh.service.8.gz (Size mismatch)
warning: fwupd: /usr/share/man/man8/fwupd-refresh.service.8.gz (SHA256 checksum mismatch)
warning: fwupd: /usr/share/metainfo/org.freedesktop.fwupd.metainfo.xml (Modification time mismatch)
warning: fwupd: /usr/share/metainfo/org.freedesktop.fwupd.metainfo.xml (Size mismatch)
warning: fwupd: /usr/share/metainfo/org.freedesktop.fwupd.metainfo.xml (SHA256 checksum mismatch)
warning: fwupd: /usr/share/polkit-1/actions/org.freedesktop.fwupd.policy (Modification time mismatch)
warning: fwupd: /usr/share/polkit-1/actions/org.freedesktop.fwupd.policy (Size mismatch)
warning: fwupd: /usr/share/polkit-1/actions/org.freedesktop.fwupd.policy (SHA256 checksum mismatch)
warning: fwupd: /usr/share/polkit-1/rules.d/org.freedesktop.fwupd.rules (Modification time mismatch)
warning: fwupd: /usr/share/polkit-1/rules.d/org.freedesktop.fwupd.rules (Size mismatch)
warning: fwupd: /usr/share/polkit-1/rules.d/org.freedesktop.fwupd.rules (SHA256 checksum mismatch)
warning: fwupd: /usr/share/vala/vapi/fwupd.deps (Modification time mismatch)
warning: fwupd: /usr/share/vala/vapi/fwupd.deps (Size mismatch)
warning: fwupd: /usr/share/vala/vapi/fwupd.deps (SHA256 checksum mismatch)
warning: fwupd: /usr/share/vala/vapi/fwupd.vapi (Modification time mismatch)
warning: fwupd: /usr/share/vala/vapi/fwupd.vapi (Size mismatch)
warning: fwupd: /usr/share/vala/vapi/fwupd.vapi (SHA256 checksum mismatch)
warning: java-runtime-common: /usr/lib/jvm/default (Symlink path mismatch)
warning: java-runtime-common: /usr/lib/jvm/default (Modification time mismatch)
warning: java-runtime-common: /usr/lib/jvm/default-runtime (Symlink path mismatch)
warning: java-runtime-common: /usr/lib/jvm/default-runtime (Modification time mismatch)
warning: libutempter: /usr/lib/utempter/utempter (GID mismatch)
warning: libutempter: /usr/lib/utempter/utempter (Permissions mismatch)
warning: lsb-release: /etc/lsb-release (Modification time mismatch)
warning: lsb-release: /etc/lsb-release (Size mismatch)
warning: lsb-release: /etc/lsb-release (SHA256 checksum mismatch)
warning: opencl-nvidia: /usr/lib/libnvidia-opencl.so (Modification time mismatch)
warning: opencl-nvidia: /usr/lib/libnvidia-opencl.so.1 (Modification time mismatch)
warning: opencl-nvidia: /usr/lib/libnvidia-opencl.so.550.76 (Modification time mismatch)
warning: opencl-nvidia: /usr/lib/libnvidia-opencl.so.550.76 (Size mismatch)
warning: opencl-nvidia: /usr/lib/libnvidia-opencl.so.550.76 (SHA256 checksum mismatch)
warning: passim: /var/lib/passim (UID mismatch)
warning: passim: /var/lib/passim (GID mismatch)
warning: passim: /var/lib/passim/data (UID mismatch)
warning: passim: /var/lib/passim/data (GID mismatch)
warning: shadow: /usr/bin/groupmems (GID mismatch)
warning: shadow: /usr/bin/groupmems (Permissions mismatch)
warning: systemd: /var/log/journal (GID mismatch)
warning: tracker3: /usr/bin/tracker3 (Modification time mismatch)
warning: tracker3: /usr/bin/tracker3 (SHA256 checksum mismatch)
warning: tracker3: /usr/bin/tracker3-endpoint (Modification time mismatch)
warning: tracker3: /usr/bin/tracker3-export (Modification time mismatch)
warning: tracker3: /usr/bin/tracker3-export (SHA256 checksum mismatch)
warning: tracker3: /usr/bin/tracker3-help (Modification time mismatch)
warning: tracker3: /usr/bin/tracker3-import (Modification time mismatch)
warning: tracker3: /usr/bin/tracker3-sparql (Modification time mismatch)
warning: tracker3: /usr/bin/tracker3-sql (Modification time mismatch)
warning: tracker3: /usr/bin/tracker3-sql (SHA256 checksum mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-batch.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-connection.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-cursor.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-endpoint-dbus.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-endpoint-http.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-endpoint.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-enums.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-error.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-namespace-manager.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-notifier.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-ontologies.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-resource.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-sparql-enum-types.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-sparql.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-statement.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-utils.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-version-generated.h (Modification time mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-version-generated.h (SHA256 checksum mismatch)
warning: tracker3: /usr/include/tracker-3.0/libtracker-sparql/tracker-version.h (Modification time mismatch)
warning: tracker3: /usr/lib/libtracker-sparql-3.0.so (Modification time mismatch)
warning: tracker3: /usr/lib/libtracker-sparql-3.0.so.0 (Symlink path mismatch)
warning: tracker3: /usr/lib/libtracker-sparql-3.0.so.0 (Modification time mismatch)
warning: tracker3: /usr/lib/libtracker-sparql-3.0.so.0.702.0 (No such file or directory)
warning: tracker3: /usr/lib/tracker-xdg-portal-3 (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-xdg-portal-3 (SHA256 checksum mismatch)
warning: tracker3: /usr/lib/girepository-1.0/Tracker-3.0.typelib (Modification time mismatch)
warning: tracker3: /usr/lib/girepository-1.0/Tracker-3.0.typelib (SHA256 checksum mismatch)
warning: tracker3: /usr/lib/pkgconfig/tracker-sparql-3.0.pc (Modification time mismatch)
warning: tracker3: /usr/lib/pkgconfig/tracker-sparql-3.0.pc (SHA256 checksum mismatch)
warning: tracker3: /usr/lib/pkgconfig/tracker-testutils-3.0.pc (Modification time mismatch)
warning: tracker3: /usr/lib/pkgconfig/tracker-testutils-3.0.pc (SHA256 checksum mismatch)
warning: tracker3: /usr/lib/systemd/user/tracker-xdg-portal-3.service (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/libtracker-http-soup2.so (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/libtracker-http-soup2.so (SHA256 checksum mismatch)
warning: tracker3: /usr/lib/tracker-3.0/libtracker-http-soup3.so (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/libtracker-http-soup3.so (SHA256 checksum mismatch)
warning: tracker3: /usr/lib/tracker-3.0/libtracker-parser-libicu.so (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/trackertestutils/__init__.py (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/trackertestutils/__main__.py (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/trackertestutils/dbusdaemon.py (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/trackertestutils/dconf.py (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/trackertestutils/helpers.py (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/trackertestutils/mainloop.py (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/trackertestutils/psutil_mini.py (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/trackertestutils/sandbox.py (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/trackertestutils/storehelper.py (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/trackertestutils/tracker-await-file (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/trackertestutils/tracker-sandbox (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/trackertestutils/await_file/__init__.py (Modification time mismatch)
warning: tracker3: /usr/lib/tracker-3.0/trackertestutils/await_file/__main__.py (Modification time mismatch)
warning: tracker3: /usr/share/bash-completion/completions/tracker3 (Modification time mismatch)
warning: tracker3: /usr/share/dbus-1/services/org.freedesktop.portal.Tracker.service (Modification time mismatch)
warning: tracker3: /usr/share/gir-1.0/Tracker-3.0.gir (Modification time mismatch)
warning: tracker3: /usr/share/gir-1.0/Tracker-3.0.gir (SHA256 checksum mismatch)
warning: tracker3: /usr/share/locale/ab/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/ar/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/as/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/be/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/be@latin/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/bg/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/bs/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/ca/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/ca/LC_MESSAGES/tracker3.mo (Size mismatch)
warning: tracker3: /usr/share/locale/ca/LC_MESSAGES/tracker3.mo (SHA256 checksum mismatch)
warning: tracker3: /usr/share/locale/ca@valencia/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/cs/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/da/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/de/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/dz/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/el/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/en_GB/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/eo/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/es/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/et/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/eu/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/fa/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/fi/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/fr/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/fur/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/fur/LC_MESSAGES/tracker3.mo (Size mismatch)
warning: tracker3: /usr/share/locale/fur/LC_MESSAGES/tracker3.mo (SHA256 checksum mismatch)
warning: tracker3: /usr/share/locale/gl/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/he/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/hr/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/hu/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/id/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/is/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/it/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/ja/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/ka/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/kab/LC_MESSAGES/tracker3.mo (No such file or directory)
warning: tracker3: /usr/share/locale/kk/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/ko/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/lt/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/lv/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/mk/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/ml/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/ms/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/nb/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/nds/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/ne/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/nl/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/oc/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/pa/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/pl/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/pt/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/pt_BR/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/pt_BR/LC_MESSAGES/tracker3.mo (Size mismatch)
warning: tracker3: /usr/share/locale/pt_BR/LC_MESSAGES/tracker3.mo (SHA256 checksum mismatch)
warning: tracker3: /usr/share/locale/ro/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/ru/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/sk/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/sl/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/sr/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/sr@latin/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/sv/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/te/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/tg/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/th/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/tr/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/uk/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/vi/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/zh_CN/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/zh_HK/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/locale/zh_TW/LC_MESSAGES/tracker3.mo (Modification time mismatch)
warning: tracker3: /usr/share/man/man1/tracker-xdg-portal-3.1.gz (Modification time mismatch)
warning: tracker3: /usr/share/man/man1/tracker-xdg-portal-3.1.gz (SHA256 checksum mismatch)
warning: tracker3: /usr/share/man/man1/tracker3-endpoint.1.gz (Modification time mismatch)
warning: tracker3: /usr/share/man/man1/tracker3-endpoint.1.gz (SHA256 checksum mismatch)
warning: tracker3: /usr/share/man/man1/tracker3-export.1.gz (Modification time mismatch)
warning: tracker3: /usr/share/man/man1/tracker3-export.1.gz (SHA256 checksum mismatch)
warning: tracker3: /usr/share/man/man1/tracker3-import.1.gz (Modification time mismatch)
warning: tracker3: /usr/share/man/man1/tracker3-import.1.gz (SHA256 checksum mismatch)
warning: tracker3: /usr/share/man/man1/tracker3-sparql.1.gz (Modification time mismatch)
warning: tracker3: /usr/share/man/man1/tracker3-sparql.1.gz (Size mismatch)
warning: tracker3: /usr/share/man/man1/tracker3-sparql.1.gz (SHA256 checksum mismatch)
warning: tracker3: /usr/share/man/man1/tracker3-sql.1.gz (Modification time mismatch)
warning: tracker3: /usr/share/man/man1/tracker3-sql.1.gz (Size mismatch)
warning: tracker3: /usr/share/man/man1/tracker3-sql.1.gz (SHA256 checksum mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-endpoint.desktop (Modification time mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-endpoint.desktop (Size mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-endpoint.desktop (SHA256 checksum mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-export.desktop (Modification time mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-export.desktop (Size mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-export.desktop (SHA256 checksum mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-help.desktop (Modification time mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-help.desktop (Size mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-help.desktop (SHA256 checksum mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-import.desktop (Modification time mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-import.desktop (Size mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-import.desktop (SHA256 checksum mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-sparql.desktop (Modification time mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-sparql.desktop (Size mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-sparql.desktop (SHA256 checksum mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-sql.desktop (Modification time mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-sql.desktop (Size mismatch)
warning: tracker3: /usr/share/tracker3/commands/tracker-sql.desktop (SHA256 checksum mismatch)
warning: tracker3: /usr/share/vala/vapi/tracker-sparql-3.0.deps (Modification time mismatch)
warning: tracker3: /usr/share/vala/vapi/tracker-sparql-3.0.vapi (Modification time mismatch)
warning: vlc: /usr/lib/vlc/plugins/plugins.dat (Modification time mismatch)
warning: vlc: /usr/lib/vlc/plugins/plugins.dat (Size mismatch)
warning: vlc: /usr/lib/vlc/plugins/plugins.dat (SHA256 checksum mismatch)
- Reinstalled those broken packages:
sudo pacman -Syu appstream appstream-qt appstream-qt5 filesystem fwupd java-runtime-common libutempter lsb-release opencl-nvidia systemd vlc tracker3 passim shadow
- Reboot
I still have few question about that whole dealβ¦
- How can i avoid this in future to not disrupt my work?
- Is there any way to follow that nvidia bug mentioned before?
