Sway Edition - General Conversation!
the drivers will be needed (xf86-video-*) but all xorg stuff can be removed if you put the needed wayland packages they will fetch the dependencies needed…
I see also that lxappearance-gtk3 is not working you will need the older version lxappearance
arandr could be helpful, or lxrandr to set displays up, but I am not sure if they do work nicely under wayland…
The alterative for lxrandr is wdisplays but thats only in the AUR. I’LL check if lxrandr or arndar work
I don’t think that there is any gui tools, for managing screen. kanshi can help with managing multiscreen setups, bit it is configured via config files.
rofi is working under wayland? or zenity ?
rofi will use xwayland if i see right
Rofi is working. Xwayland I’m not necessarily keen on but if it is needed.
@joekamprad Lighdm did not install with the installer i3 edition. I had to both install and add the service. Is something wrong with the installer?
A very particular question but would be good to have seperators between the app launchers or not.
Not like that! But floating and thinner
FILENAME
I would say skip the text and just keep the icons. And are we missing a font? It look different on my VM. I would also skip the icon on the workspaces and just make a seperate color for the focused window.
We have a bug: When scrolling on the volume you can keep going up
Font, I’m not sure. Currently I’m using ubunutu-mono for everything there was bug in alacritty which I’ll push now.
Could you check if brightness if working. Mine’s not?
Nevermind another thing to add to install script
You mean the browser window is red and the terminal one is blue etc; ??
installer is not changing on the ISO … could be failing to install caused by mirrors syncing while in use…
if you would give the Calamares.log i would see it…
cat /var/log/Calamares.log | eos-sendlog
Do I have to go back onto the usb?
I’ll do in a sec
Eeeeeee!!! This annoys me so much why won’t they be the same size
FILENAME
Also new waybar pushed - only slightly changed still needs some work
All the work will payoff if others start using it with ease :wink:
You have different sizes in .config/waybar/style.css 13px vs. 20px
By the way check out this especially
%x The locale’s date representation. The modified command %Ex produces the locale’s alternate date representation
%X The locale’s time representation. The modified command %Ex produces the locale’s alternate time representation
The we follow the settings from the install process
No that’s was me trying to make them the same size. But clock time doesn’t do anything
Erm…I’ll read it but what is it for. To set the locale?? Buts that done in the installer?
