log for install is saved on the installed system also…
Yes, the locale is done in the installer, so when you pull the information from there you get the right info ![]()
I would go for this, so you have only one clock module, and you click it to get the calendar. You could consider switching format and format-alt
Ohhhhh sorry I didn’t know what it was for
Sorry
. I promise I’ll get that to.
Hey, don’t stress! Just, when you have the time! You have other things to do as well
By the way, maybe skip the seperator and control this in the style.css as well.
I’ve done the clock. Can you control that in css I did it in the config file
I’m not very confident in css, but i guess that the style.css is controling the spacing so i believe that you should be able to.
I’m confused to where this shows up? I’ve ran it where is the log?
Found it! Do I send it? It’s a big ass log.
(Freaking hell, online tests are annoying! Like let me check my answers man why? Why a time limit per question eee!!!
Anyway new bar pushed - with mended clock and better padding!)
How do I test Sway with the online installer? I’ve found where the netinstall.yaml goes, but what about setup.sh. Where should that be?
@joekamprad is doing that, I believe
. I know nothing about that
Welcome and Reflector work fine under xwayland without a env variable.
Also @morten-b please can we have two keys to close a window? Mod+Shift+Q is too much can we do just mod+q
Sure, no problem.
Regarding the power menu, I think that we have an solution. I can be included in wofi:
Credits to https://github.com/luispabon/sway-dotfiles/blob/master/scripts/wofi-power.sh
Have you added it to waybar ??
No, feel free!
Done!
BTW, It works perfectly! Very clever, morten!
