[SSD] A discussion of SSDs and HDDs
Well, not everyone has broken down. I have a lot of SSD/HDD so it happens every now and then.
Edit:
Some of my Blue SSD/HDD:
500GB-WD-Blue-SSD-HDD-Enclosure-01
1TB-WD-Blue-HDD-01
I have many more :wink:
Just a note about the quality erosion with SSDs. It undoubtedly happens, but not in all cases. EVO as a ‘brand’ has lost some of its high performance cachet, but the EVO Plus has not… nor has its price dropped particularly quickly. Someone who is familiar with chipsets and components has checked for those used in the 970EVO Plus, and they have remained of the highest quality (so far).
“sounds like” names are a great problem, even within a given manufacturers lines - and certainly in products built to a price - so do all the checking you can where possible :grin:
For the meantime, I would say the EVO Plus range are OK, and the Corsair MP600 range are pretty quick for gen 4 nvme drives as well - at least judging by the components and lab tests (and my unsophisticated ‘testing’ in use)…
I would beg to differ, any issues in recent years with Samsung EVO line SSD’s can almost always be traced back to an initial firmware release that was in instances defective. Samsung SSD’s get their reputation from their controllers which have been and conitnue to be the best. You may get lucky and have a mid grade SSD last, but every longevity test on SSD’s I have seen does not support your argument, and pretty much every review. Other manufacturers have caught up to a degree, but Samsung just showed its dominance again with the 980 Pro series. They continue to be the leader in SSD’s whether paying that 10-20% premium for a 5% performance edge is worth it is entirely a matter of personal choice. At this point, as with any brand, failure usually comes down to the quality of the controller chip, and for that alone I will continue to buy Samsung SSD’s for my personal systems. (Edited: for punctuation and clarity)
When we talk about SSD anyway. These are good stuff:
250GB-SAMSUNG-T3-SSD
250GB-SAMSUNG-T5-SSD-02
Buy a lot of them!
Funny, I was just looking at these a couple of days ago.
they very useful and easy in pocket … :+1: :+1:
You may want to blur those pictures.
I think these are 3500 Read and 3300 write on Pci-e 3.0 which is way faster than any SSD at 560 and 530 or less. The new ones m.2 drives Samsung 980 Pro on Pci-e 4.0 will do like 7000 read and 5300 write.
SPOT ON! I vave 3 USB 3.0 drives that I got cheaper than I could get the same drive without the housing. I have striped each out of their cases and they preform a good 25% better.
As for the SSD I bought to go with this build it’s a Patriot VPN100 M.2 2280 256GB PCIe Gen3 x4, NVMe 1.3 Internal Solid State Drive (SSD) VPN100-256GM28H
It is my understanding that western digital also has a new m.2 drive black SN850 on Pci-e 4.0
Sequential Read Performance
7000MB/s
Sequential Write Performance
4100MB/s
3000 Read
1000 Write
Yea It’s sweet in my book.
Scroll down for the specs.
I ran a speed test on my Lenovo:
Lenovo-ThinkCentre-M710q-Tiny-04
NVMe-SSD
I remember it as faster when it was new.
Yes, it’s way better than the fastest SSD and the new m.2 drives are even faster and now have even doubled that on Pci-e 4.0 if you have the hardware for it!
Mine’s OK for now :level_slider:
Scn-disk
This might be interesting to our Dutch readers…
https://tweakers.net/reviews/8206/vijftig-nvme-ssds-groter-sneller-goedkoper.html
was just about to post this too :smiley:
Only 10 times faster than mine… :sleepy:
I only get fast speed the first 10GB or so on my NVMe. For example, if I download a music folder of 50GB from another NVMe SSD. The first 10GB goes quickly, then my NVMe SSD goes down to around 400MB/s.
SSD cache getting full? Overheating? Think it is around 65-70 degrees. It’s just a small NVMe SSD of 256GB so is probably not that big cache on it.
I have a SanDisk SSD which is the worst I bought:
SanDisk-SSD-240GB-01
You have to look for slower. Fast 2GB, then it goes down to around 60-80MB/s. Cheap SSD!
The worst SSD I ever bought was made by Biostar. I bought it because I needed a cheap one to throw into a test build. It was stupid slow. Come to find out, it was one of the SSD’s that does not have any cache. I ended up throwing it in a drawer
Here is a link 690 baht is about 22 USD.
I found that Crucial, for SATA SSD’s, are pretty good on the price to performance metric. I have used them in several systems in the last couple of years, and they have been rock solid. Not the fastest, but still much faster than spinning rust.
