I have installed the KDE distro. I normally use wifi connection but as wifi was not working that day so i plugged in he ethernet cable which is never detected. Can any one guide me how to resolve this issue
Welcome Aboard!
Is your internet provided by a university? Are you a student?
Thank you!
Not at university. At home.
I did have the same problem with linux-zen
kernel recently .
Network: Device-1: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
IF: wlan0 state: up mac: 54:27:1e:fd:f4:b0
Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: N/A
Thank you!
This thing helped
Edit /usr/lib/modprobe.d/r8168.conf and unblacklist r8169
sudo nano β/usr/lib/modprobe.d/r8168.confβ
Comment the line by adding a β#β, like
#blacklist r8169
Save and exit. -
Reboot or run
sudo modprobe r8169
and check if you have an ethernet connection.
If the above works, note that this is only a temporary fix that will be reverted when r8168 gets updated.
To fix permanantly, uninstall r8168:
sudo pacman -R r8168
