I installed TLP, but soon found I could not access the internet anymore. So I uninstalled it again, and also did systemctl disable tlp.service
. However, I still cannot access.
The Wifi signal is strong and picked up by EnOS.
What can I do?
What can I do?
Usually it doesn’t do anything like that, but in cases like that with some specific devices, like your wi-fi module, you may need to whitelist it or disable it’s powersaving functionality, to make it easier install tlpui
and see those tabs:
P.S. To apply settings don’t forget to press Save button on top right
So, now that I have uninstalled TLP entirely, I should reinstall it, but the tlpui
instead of the tlp
unit. Correct?
Installing tlpui should automatically install dependencies of it.
Just install tlpui.
Like @mrvictory said, tlpui
is just a gui to easily control config file of tlp
and it will automatically pull tlp
as dependency when you install.
I only recommended tlpui
because sometimes it might be overwhelming, if you’re not very familiar with tlp
when searching for some options, but you can use it directly by changing /etc/tlp.conf
, you can read more about it’s options at https://linrunner.de/tlp/settings.
I am still not clear about this.
Since I uninstalled TLP, there should not be any more obstructions to the WiFi device. Am I wrong?
Oh wait, i misunderstood your post - if you have uninstalled tlp
and rebooted (just in case), and after that wi-fi still doesn’t work - then it’s certainly not tlp
that is causing your problem.
Can you give us
inxi -Faz
and
journalctl -p3 -xb
In this reply you’ll find inxi -Faz, in the next reply journalctl.
$ inxi -Faz
Kernel: 5.18.10-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=3a0684f9-871b-4c62-aa88-4418bb62d10b rw
resume=UUID=d1fd324d-93f6-460c-a015-f406df0168a3 loglevel=3 nowatchdog
nvme_load=YES
Desktop: Cinnamon v: 5.4.2 tk: GTK v: 3.24.34 vt: 7 dm: LightDM v: 1.30.0
Type: Laptop System: LENOVO product: 81FL v: Lenovo ideapad 330-17ICH
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 330-17ICH
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: 7ZCN29WW date: 10/24/2018
Battery:
ID-1: BAT0 charge: 29.9 Wh (80.8%) condition: 37.0/45.0 Wh (82.3%)
volts: 11.9 min: 11.3 model: SMP L17M3PB1 type: Li-poly serial: <filter>
status: discharging
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 1256 high: 1997 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 1475 2: 1475 3: 1841
4: 800 5: 1921 6: 800 7: 800 8: 1570 9: 800 10: 1997 11: 800 12: 800
bogomips: 52815
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf
mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl
Type: spectre_v1
STIBP: conditional, RSB filling
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: DP-1, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: Acer EasyCamera type: USB driver: uvcvideo bus-ID: 1-8:2
chip-ID: 5986:210e class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2 driver: X:
loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22")
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP1 model: LG Display 0x05b9 built: 2017
res: 1920x1080 hz: 60 dpi: 128 gamma: 1.2 size: 380x210mm (14.96x8.27")
diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:a348 class-ID: 0403
Sound Server-1: ALSA v: k5.18.10-arch1-1 running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.54 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: down mac: <filter>
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
Bluetooth:
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: down bt-service: disabled
Local Storage: total: 1.03 TiB used: 27.33 GiB (2.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo O.E.M.
model: RPFTJ128PDD2EWX size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: 11.82 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: LCM2
scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB model: USB NAND FLASH
size: 125 MiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0.30 scheme: MBR
SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
ID-1: / raw-size: 110.15 GiB size: 107.86 GiB (97.92%)
used: 27.3 GiB (25.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 39.0 C pch: 40.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 346 Uptime: 1h 41m wakeups: 1 Memory: 7.64 GiB
used: 2.05 GiB (26.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1079
lib: 239 Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.19
$ journalctl -p3 -xb
Jul 10 15:32:46 peter-81fl kernel: x86/cpu: SGX disabled by BIOS.
Jul 10 15:32:46 peter-81fl kernel: ACPI BIOS Error (bug): Failure creating name>
Jul 10 15:32:46 peter-81fl kernel: ACPI Error: AE_ALREADY_EXISTS, During name l>
Jul 10 15:32:46 peter-81fl kernel: ACPI BIOS Error (bug): Could not resolve sym>
Jul 10 15:32:46 peter-81fl kernel: ACPI Error: AE_NOT_FOUND, During name lookup>
Have you tried removing and re-adding the connection to Network Manager?
I just did that now, to no avail.
Now, there is 1 odd thing: in one of the browsers I have installed the Hide Me proxy. When it is disabled I cannot access internet, when I enable it, I can access internet!
However, with none of the other browsers, which don’t have Hide Me, I cannot access internet.
Sounds like a DNS issue. Check the contents of /etc/resolv.conf
, and whether you can ping an IP address, e.g.
ping -c3 8.8.8.8
This also sounds completely unrelated to TLP.
TLP-DOC, Note:
Power saving mode can cause an unstable Wi-Fi link.
Check your TLP config file, according to this site:
https://linrunner.de/tlp/settings/network.html
Here are my notes (protocol I wrote myself) of installing TLP / TLPUI, because I just wanted to be able to revert things correctly, in case I need to uninstall:
Installed TLP:
dnf install tlp tlp-rdw
Removed conflicting daemon:
dnf remove power-profiles-daemon
Enabled service:
systemctl enable tlp.service
Masked 2 conflicting units:
systemctl mask systemd-rfkill.service systemd-rfkill.socket
Installed TLPUI:
git clone https://github.com/d4nj1/TLPUI
cd TLPUI
To start TLPUI:
cd TLPUI
python3 -m tlpui
/etc/tlp.conf
Contents of /etc/resolv.conf
#Generated by NetworkManager
nameserver ::1
Yes, pinging that address worked.
If it is unrelated to TLP, how come I did not have this problem before TLP was installed?
So, this implies you are not getting a DNS resolver from your router via DHCP. Check your network settings, and check your router.
You may have changed something else at the same time.
Below is a screenshot of the settings. There was no DNS address, so I tried to add one. But even putting the numbers in the box, the Apply button remains greyed out.
My router is fine because I am having this conversation with you via my Mac that uses the same router.
As long as you have automatic DNS enabled, you cannot at the same time add another DNS address.
So, what does Jonathon mean by
and what should I check then, and how?
That’s not correct - the additional resolver will be used in addition to any received from DHCP.
Did you press the Plus icon to add the IP address?
Yes, I did. It just adds a 2nd box below for the next DNS address, but the Apply button remains greyed out.
