[SOLVED] NetworkManager fails to connect to ethernet and returns ip-config-unavailable
I’m trying to switch from Windows 10 to EndeavourOS, and i made a ventoy live usb with EndeavourOS on it. When i boot into it, though, it tries to connect to my ethernet connection but fails with ip-config-unavailable and gets stuck in a loop. The ethernet connection works fine on Windows. The same problem happens with Linux Mint live usb and presumably any distro that uses NetworkManager. I’m not sure where to start in fixing this; I’ve tried several other forum posts online and none have helped with my situation. I’m not terribly new with Linux as I’ve used Linux Lite and EndeavourOS for a few months now. It’s strange though, because I used to run Linux Lite on this PC and this problem never happened. Any help would be appreciated!
Welcome to the community @LukeMax :wave::sunglasses: :enos_flag:
Some system specs might help get the ball rolling. Understandably, without Internet on that system though, it might be a problem sharing some of the more detailed specs. Are you able to connect to WiFi, or tether with your phone, even if just temporary?
These sorts of details would be a good start (system, machine and network):
inxi -SMNxx --za
I’ve noticed a few problems with my wired connection over the last few days. If the command above shows you have a Realtek using the r8169 driver that may the issue.
[SOLVED] Wired Connection Problems - Arch Forum
no ethernet in a live environment?
the times (once) I shared a disk with WIN, WIN would shut down linux’s modem manager and network manager services after update just 'cause it could.
…but a live .iso? I don’t know if Windows has this kind of reach i.e. disabling services on an .iso.
If it’s a Ventoy do you have internet in other live environments (isos)?
I’m thinking if it’s Endeavour-only, it’s a place to start…
The Wi-Fi adapter i used to use doesn’t work with linux and i never bothered to install proprietary drivers for it so i wired an ethernet cable. I’ll run the inxi command and update shortly.
Update: heres the output of the command
Others who have encountered this issue with the Intel I217 ethernet adaptor on the live ISO, have had success disabling the Wake On LAN (WOL) feature under Windows.
I’m not sure specifically how that is done under Windows, but hopefully that’s a point in the right direction?
Sources:
Perhaps of help:
I’m not sure how I didn’t think of doing that since I’ve definitely disabled that to fix it before, thanks for reminding me!
