No ethernet connection (Intel i217-V) USB live install
Based on the following post, I’m experiencing the same issue; https://forum.endeavouros.com/t/no-ethernet-connection-usb-live-install/
Using latest Endeavouros_Cassini_Nova-03-2023_R3 iso on USB stick for a ROG Asus motherboard with the intel i217-V network adapter.
Yes, I know I can install it and see if it works then, but I’m not hopeful if the installer is already giving me issues and I really want Plasma/KDE from the get-go, as Galileo was postponed. Hoping if anyone found a solution already.
Welcome! :smile:
Have you seen this?
https://bbs.archlinux.org/viewtopic.php?id=191981
You are amazing. This was driving me insane. For future generations; apparently the problem is that the LAN chipset has its own bios that remembers Wake-On-LAN and Power Management settings. Turning these off alone in your BIOS doesn’t help. So the solution was as follows;
  1. Download (possibly older) Intel drivers WITH the Intel PROset and the Intel Advanced Network Services from their site (look for Intel® Network Adapter Driver on https://www.intel.com/content/www/us/en/download-center/home.html) for Windows.
  2. Change the Adapter Settings → Ethernet Properties → Configure and go to Power Management. Disable all Power Saver Options and Wake on LAN checkmarks. Of course also in your BIOS.
  3. Done.
Thank you so much.
Great that you got it solved! :+1:
