I have a brand new 32gb micro sd card.
Originally, when I first put it in the reader, it was not detected.
I used my wifi cam to format it, then I could see it in the pc.
That was/is problem 1 - Why couldn’t endeavour/arch/plasma see the card when inserted to format it?
Anyway, this card is for another device, a minicam recorder with a small lcd for my pellet gun nightvision setup.
Here is problem 2 - the device allows format of the card to record video and stills, but the only way to get the images and video off is to put the card in a PC.
Endeavour/arch/plasma cannot read the whatever filesystem it was formatted to to get the images off…I’m guessing that’s the issue.
I’ve tried a basic live boots of windows 10 (Hirens boot PE) even though it didn’t help,
I then realized I shouldn’t even have to try that at all since it defeats the purpose of switching over in the first place.
I tried opensc and a few other packages, but nothing seems to do the trick.
So, anyone been down this road with sd cards and figure out what endeavour needs to be able to read whatever filesystem the sd card was formatted to? if that is the issue.
Although, if I leave the card plugged in at boot the system halts as it thinks there is a boot device there, so the system knows there is something there, just not the os it would seem.
Not off hand. There is a lot of info on the internet about this issue. The problem is i don’t want to see you use some commands or something that might cause havoc on your installed system. Maybe some more experienced have some idea.
