What happened to that max cpu 3.7? Is it hidden somewhere and I have dig it out or is that Lenovo info wrong? I have to admit I’m little bit confused about all these specs things, especially if it’s about cpu frequences etc. I have googled and googled and so far I haven’t found a clue what’s really going on under the hood of my laptop. So could somebody explain this matter to me in simple words: can I get that 3.7 GHz out from my machine and if yes, how do I do it? I have already checked BIOs and there wasn’t way to enable turbo boost or any such thing.
Funny, it says that boost is enabled but doesn’t give the frequency for it. I don’t know…
Perhaps you could run s-tui and try the stress option to see if you get the right boost frequency
It should shoot up the frequency right away. 10-15 sec should be more than enough. Or just play 8k video on youtube as was suggested on the thread I linked to before. Btw, I have mine set up to boost only when on AC.
In the BIOS for my Lenovo Yoga Slim 7 I’ve got three options under configuration tab:
Performance
Intelligent Cooling
Battery Save
I have it set to Battery Save so I can’t get the cpu boost when on battery. Plugin the machine to AC apparently overrides this setting and I get turbo boost.
If you want to see max boost frequency you have to run the stress test on a single core. the max frequency is never reachable when there is workload on all cores.
Also the max frequency will be reached before the 15 seconds mark. Afterwards it could go down because of thermals.
