[Solved] CPU max frequency
Did you remember to hit Apply after removing those marks?
I think I did. I try again when I get home today from work.
Ok, I tried again removing marks of those other cores, clicked apply and then ran again s-tui. This time it seems to have effect. lscpu | grep MHz gives now this:
[mardix@mardix-81x2 ~]$ lscpu | grep MHz
CPU MHz:                         3365.538
CPU max MHz:                     2700,0000
CPU min MHz:                     1400,0000
But if I run inxi -Cay I get this:
[mardix@mardix-81x2 ~]$ inxi -Cay
  Info: Quad Core model: AMD Ryzen 3 4300U with Radeon Graphics bits: 64
  type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600102 L2 cache: 2 MiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 21570
  Speed: 1397 MHz min/max: 1400/2700 MHz boost: enabled Core speeds (MHz):
  1: 1397 2: 1625 3: 1723 4: 2960
  Vulnerabilities: Type: itlb_multihit status: Not affected
  Type: spec_store_bypass
  mitigation: Speculative Store Bypass disabled via prctl and seccomp
  Type: spectre_v1
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  STIBP: disabled, RSB filling
[mardix@mardix-81x2 ~]$ cpupower frequency-info
analyzing CPU 0:
  driver: acpi-cpufreq
  CPUs which run at the same hardware frequency: 0
  CPUs which need to have their frequency coordinated by software: 0
  maximum transition latency:  Cannot determine or is not supported.
  hardware limits: 1.40 GHz - 2.70 GHz
  available frequency steps:  2.70 GHz, 1.70 GHz, 1.40 GHz
  available cpufreq governors: conservative ondemand userspace powersave performance schedutil
  current policy: frequency should be within 1.40 GHz and 2.70 GHz.
                  The governor "performance" may decide which speed to use
                  within this range.
  current CPU frequency: Unable to call hardware
  current CPU frequency: 2.83 GHz (asserted by call to kernel)
  boost state support:
    Supported: yes
    Active: no
When I run auto-cpufreq --monitor I get this:
Screenshot_20210116_155724
Oh well, I guess I have to believe turbo boost is on then… :grin:
Run it with sudo.
Yeah, we had some old threads here about the tools like inxi not reporting the right frequency of AMD cpus. I wouldn’t worry too much about it. If at least one of the tools managed to get a high frequency read, I’d say you’re golden.
Yeah, one would be my thread! And I got a “mild” RTFM admonition by the developer of the tool.
:sweat_smile:
(link further above)
Thanks all of you who helped me with this! This thread taught me a lot of new things about my laptop. I guess I can mark this problem solved now.
