Settings crashes when opening
[phoenixcharm@phoenixcharm ~]$ gnome-control-center
(gnome-control-center:6356): cc-wwan-panel-WARNING **: 21:59:49.321: Error connecting to ModemManager: Error calling StartServiceByName for org.freedesktop.ModemManager1: Unit dbus-org.freedesktop.ModemManager1.service not found.
(gnome-control-center:6356): GLib-GIO-ERROR **: 21:59:49.353: Settings schema 'org.gnome.shell.app-switcher' is not installed
Trace/breakpoint trap (core dumped)
Check this thread first to see if any of those solutions are helpful to you:
If none of those solutions work, if you’re feeling a little “risky”, you could try this solution that seems to work for some users I found over on the Manjaro forums, but I can’t comment on it’s success since I’m not able to replicate this issue, so please be aware of that:
Also, welcome to the EndeavourOS forums :slight_smile:
