Second monitor not working (but gets recognized in xrandr)
Hey guys,
I’m having problems again with my second monitor. I had a similar problem with the last kde plasma update which was eventually fixed. The problem was slightly different tho. Last time the second monitor was shown before login and a profile reset could solve the problem. This time the second monitor gets no input all the time.
I run a Lenovo Ideapad 5 Pro 14ACN6 plugged into a Lenovo Universal USB-C . To that dock is connected a LG UltraGear 34GN850-B and a ASUS MG279Q as a second external monitor. Both are connected via display port. The system is up to date.
The same setup works fine with a Thinkpad t14 (4850H Edition) with Windows 10 and also with my gaming rig with Windows 11.
xrandr
~ » xrandr
Screen 0: minimum 320 x 200, current 6000 x 1440, maximum 16384 x 16384
eDP connected (normal left inverted right x axis y axis)
   2880x1800     90.00 +
   1920x1200     90.00
   1920x1080     90.00
   1600x1200     90.00
   1680x1050     90.00
   1280x1024     90.00
   1440x900      90.00
   1280x800      90.00
   1280x720      90.00
   1024x768      90.00
   800x600       90.00
   640x480       90.00
HDMI-A-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
DisplayPort-3 connected primary 3440x1440+0+0 (normal left inverted right x axis y axis) 800mm x 335mm
   3440x1440    143.92*+  60.00 +  99.99
   1920x1080     74.98    60.00    60.00    50.00    59.94
   1680x1050     59.95
   1600x900      60.00
   1280x1024     75.02    60.02
   1280x800      59.81
   1152x864      59.97
   1280x720      60.00    50.00    59.94
   1024x768      60.00
   800x600       60.32
   720x576       50.00
   720x480       60.00    59.94
   640x480       60.00    59.94
DisplayPort-4 connected 2560x1440+3440+0 (normal left inverted right x axis y axis) 597mm x 336mm
   2560x1440    143.86*+ 119.88    59.95
   1920x1080     60.00    60.00    50.00    59.94
   1440x900      59.89
   1152x864      75.00
   1440x576      50.00
   1024x768      75.03    70.07    60.00
   1440x480      60.00    59.94
   832x624       74.55
   800x600       72.19    75.00    60.32    56.25
   720x576       50.00
   640x480       75.00    66.67    60.00    59.94
   720x400       70.08
journalctl -b -p3 --no-pager --no-hostname
~ » journalctl -b -p3 --no-pager --no-hostname
Jan 09 19:28:49 kernel: rtw89_8852ae 0000:01:00.0: failed to early request firmware: -2
Jan 09 19:28:50 kernel: Bluetooth: hci0: Failed to read codec capabilities (-22)
Jan 09 19:29:00 kernel: usb 1-1.1.2: 3:8: cannot get freq at ep 0x86
Jan 09 19:29:01 konsole[1974]: kf.xmlgui: Shortcut for action  "" "Show SSH Manager" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 09 19:29:01 konsole[1974]: kf.xmlgui: Shortcut for action  "" "Show Quick Commands" set with QAction::setShortcut()! Use KActionCollection::setDefaultShortcut(s) instead.
Jan 09 19:29:01 kernel: usb 1-1.1.2: 3:8: cannot get freq at ep 0x86
Jan 09 19:29:15 kernel: usb 1-1.1.3.1.4: device not accepting address 14, error -71
journalctl -b -u sddm --no-pager --no-hostname
~ » journalctl -b -u sddm --no-pager --no-hostname
Jan 09 19:28:49 systemd[1]: Started Simple Desktop Display Manager.
Jan 09 19:28:49 sddm[702]: Initializing...
Jan 09 19:28:49 sddm[702]: Starting...
Jan 09 19:28:49 sddm[702]: Logind interface found
Jan 09 19:28:51 sddm[702]: Adding new display on vt 1 ...
Jan 09 19:28:51 sddm[702]: Loading theme configuration from ""
Jan 09 19:28:51 sddm[702]: Display server starting...
Jan 09 19:28:51 sddm[702]: Adding cookie to "/var/run/sddm/{2a43baaf-ee96-434e-885a-7eaadf5dcd71}"
Jan 09 19:28:51 sddm[702]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{2a43baaf-ee96-434e-885a-7eaadf5dcd71} -noreset -displayfd 17
Jan 09 19:28:55 sddm[702]: Setting default cursor
Jan 09 19:28:55 sddm[702]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Jan 09 19:28:55 sddm[702]: Display server started.
Jan 09 19:28:55 sddm[702]: Reading from "/usr/share/xsessions/plasma.desktop"
Jan 09 19:28:55 sddm[702]: Session "/usr/share/xsessions/plasma.desktop" selected, command: "/usr/bin/startplasma-x11"
Jan 09 19:28:55 sddm-helper[828]: [PAM] Starting...
Jan 09 19:28:55 sddm-helper[828]: [PAM] Authenticating...
Jan 09 19:28:55 sddm-helper[828]: pam_kwallet5(sddm-autologin:auth): pam_kwallet5: pam_sm_authenticate
Jan 09 19:28:55 sddm-helper[828]: pam_kwallet5(sddm-autologin:auth): pam_kwallet5: Couldn't get password (it is empty)
Jan 09 19:28:55 sddm-helper[828]: [PAM] Preparing to converse...
Jan 09 19:28:55 sddm-helper[828]: [PAM] Conversation with 1 messages
Jan 09 19:28:55 sddm-helper[828]: [PAM] returning.
Jan 09 19:28:55 sddm-helper[828]: pam_systemd_home(sddm-autologin:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 09 19:28:55 sddm[702]: Authenticated successfully
Jan 09 19:28:55 sddm-helper[828]: pam_kwallet5(sddm-autologin:setcred): pam_kwallet5: pam_sm_setcred
Jan 09 19:28:55 sddm-helper[828]: pam_unix(sddm-autologin:session): session opened for user josh(uid=1000) by (uid=0)
Jan 09 19:28:55 sddm-helper[828]: pam_kwallet5(sddm-autologin:session): pam_kwallet5: pam_sm_open_session
Jan 09 19:28:55 sddm-helper[828]: Starting: "/usr/share/sddm/scripts/Xsession \"/usr/bin/startplasma-x11\""
Jan 09 19:28:55 sddm[702]: Session started
inxi -SMGaz
  Kernel: 6.1.4-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-linux
    root=UUID=aa88e6fb-3c34-4280-980b-613dedb1d315 rw
    resume=UUID=b4d68c30-8fe9-4d49-9847-1c27d066819d loglevel=3 nowatchdog
    nvme_load=YES
  Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 82L7 v: IdeaPad 5 Pro 14ACN6
    serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 Pro 14ACN6
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
    serial: <superuser required> UEFI: LENOVO v: GECN31WW(V1.15)
    date: 06/24/2022
  Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
    vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2
    process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s ports: active: DP-4,DP-5 off: eDP-1
    empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1638
    class-ID: 0300 temp: 47.0 C
  Device-2: Sunplus Innovation EKACOM-K50E type: USB
    driver: snd-usb-audio,uvcvideo bus-ID: 1-1.1.2:7 chip-ID: 1bcf:2cb4
    class-ID: 0102 serial: <filter>
  Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
    bus-ID: 1-3:3 chip-ID: 04f2:b6be class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 6000x1440 s-dpi: 96 s-size: 1586x380mm (62.44x14.96")
    s-diag: 1631mm (64.21")
  Monitor-1: DP-4 mapped: DisplayPort-3 pos: primary,left
    model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2020 res: 3440x1440
    hz: 144 dpi: 109 gamma: 1.2 size: 800x335mm (31.5x13.19")
    diag: 867mm (34.1") modes: max: 3440x1440 min: 640x480
  Monitor-2: DP-5 mapped: DisplayPort-4 pos: right model: Asus MG279
    serial: <filter> built: 2016 res: 2560x1440 hz: 144 dpi: 109 gamma: 1.2
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
    max: 2560x1440 min: 720x400
  Monitor-3: eDP-1 mapped: eDP note: disabled model-id: CSO 0x1402
    built: 2020 res: 2560x1440 dpi: 242 gamma: 1.2 size: 302x188mm (11.89x7.4")
    diag: 356mm (14") ratio: 16:10 modes: max: 2880x1800 min: 640x480
  API: OpenGL v: 4.6 Mesa 22.3.2 renderer: AMD Radeon Graphics (renoir LLVM
    14.0.6 DRM 3.49 6.1.4-arch1-1) direct render: Yes
Thanks for the help and have a nice day!
arandr helps you to make a proper xrandr command line
omit unneccessary lines or the whole if it’s irrelevant
makedir ~.screenlayout
touch ~.screenlayout/monitor
arandr
Output (select primary monitor)
Layout Apply (Ctrl/Return)
then Save as monitor
and it makes a monitor.sh script
chmod +x monitor.sh
Insert this monitor.sh (or xrandr line) wherever suits you.
EDIT1: arandr is a utility – a community package and can be installed by pacman as well – You will see what ports are detected, change resolutions etc. You’ll see the changes by pressing Ctrl+Return and the best version can be saved to a file containing the xrandr line with an extension .sh. Your problem is harder than that, unfortunately.
Have you rebooted after update?
Do you use autologin, and if so, what happens when you logout?
In case the kernel errors about some usb device are relevant, post
lsusb -tv
inxi -a --usb
Did you try a different kernel? (linux-lts)
@eso
Thanks! So I need to install arandr from the aur first right? And then create a monitor.sh with it?
@petsam
Yes I did reboot after the updates. I don’t use autologin. When I logout nothing happens (second monitor still not working). This is different from the last time I had this problem where the second monitor was working when I logged out.
** lsusb -tv**
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 10000M
    ID 1d6b:0003 Linux Foundation 3.0 root hub
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
    ID 1d6b:0002 Linux Foundation 2.0 root hub
    |__ Port 4: Dev 2, If 0, Class=Wireless, Driver=btusb, 12M
        ID 0bda:4852 Realtek Semiconductor Corp.
    |__ Port 4: Dev 2, If 1, Class=Wireless, Driver=btusb, 12M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 10000M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
        ID 17ef:30ab Lenovo
        |__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
            ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter
        |__ Port 3: Dev 4, If 0, Class=Hub, Driver=hub/4p, 5000M
            ID 17ef:30ad Lenovo
            |__ Port 1: Dev 5, If 0, Class=Hub, Driver=hub/4p, 5000M
                ID 05e3:0612 Genesys Logic, Inc. Hub
                |__ Port 2: Dev 6, If 0, Class=Hub, Driver=hub/4p, 5000M
                    ID 0451:8140 Texas Instruments, Inc. TUSB8041 4-Port Hub
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
    |__ Port 1: Dev 3, If 0, Class=Hub, Driver=hub/3p, 480M
        ID 17ef:30af Lenovo
        |__ Port 1: Dev 4, If 0, Class=Hub, Driver=hub/4p, 480M
            ID 17ef:30ac Lenovo
            |__ Port 2: Dev 6, If 0, Class=Video, Driver=uvcvideo, 480M
                ID 1bcf:2cb4 Sunplus Innovation Technology Inc.
            |__ Port 2: Dev 6, If 1, Class=Video, Driver=uvcvideo, 480M
            |__ Port 2: Dev 6, If 2, Class=Audio, Driver=snd-usb-audio, 480M
            |__ Port 2: Dev 6, If 3, Class=Audio, Driver=snd-usb-audio, 480M
            |__ Port 3: Dev 8, If 0, Class=Hub, Driver=hub/4p, 480M
                ID 17ef:30ae Lenovo
                |__ Port 1: Dev 9, If 0, Class=Hub, Driver=hub/4p, 480M
                    ID 05e3:0610 Genesys Logic, Inc. Hub
                    |__ Port 1: Dev 10, If 0, Class=Human Interface Device, Driver=usbhid, 12M
                        ID 046d:c539 Logitech, Inc. Cordless Mouse Receiver
                    |__ Port 1: Dev 10, If 1, Class=Human Interface Device, Driver=usbhid, 12M
                    |__ Port 1: Dev 10, If 2, Class=Human Interface Device, Driver=usbhid, 12M
                    |__ Port 2: Dev 11, If 0, Class=Hub, Driver=hub/4p, 480M
                        ID 0451:8142 Texas Instruments, Inc. TUSB8041 4-Port Hub
                        |__ Port 4: Dev 13, If 0, Class=Human Interface Device, Driver=usbhid, 12M
                            ID 043e:9a39 LG Electronics USA, Inc.
                    |__ Port 3: Dev 12, If 0, Class=Human Interface Device, Driver=usbhid, 12M
                        ID 0416:0123 Winbond Electronics Corp.
                    |__ Port 3: Dev 12, If 1, Class=Human Interface Device, Driver=usbhid, 12M
                    |__ Port 3: Dev 12, If 2, Class=Human Interface Device, Driver=usbhid, 12M
                    |__ Port 3: Dev 12, If 3, Class=Human Interface Device, Driver=usbhid, 12M
                    |__ Port 3: Dev 12, If 4, Class=Human Interface Device, Driver=usbhid, 12M
                    |__ Port 4: Dev 14, If 0, Class=Audio, Driver=snd-usb-audio, 12M
                        ID 1395:009a DSEA A/S
                    |__ Port 4: Dev 14, If 1, Class=Audio, Driver=snd-usb-audio, 12M
                    |__ Port 4: Dev 14, If 2, Class=Audio, Driver=snd-usb-audio, 12M
                    |__ Port 4: Dev 14, If 3, Class=Human Interface Device, Driver=usbhid, 12M
                    |__ Port 4: Dev 14, If 4, Class=Communications, Driver=cdc_acm, 12M
                    |__ Port 4: Dev 14, If 5, Class=CDC Data, Driver=cdc_acm, 12M
        |__ Port 2: Dev 5, If 0, Class=Audio, Driver=snd-usb-audio, 12M
            ID 17ef:30b0 Lenovo
        |__ Port 2: Dev 5, If 1, Class=Audio, Driver=snd-usb-audio, 12M
            ID 17ef:30b0 Lenovo
        |__ Port 2: Dev 5, If 2, Class=Audio, Driver=snd-usb-audio, 12M
            ID 17ef:30b0 Lenovo
        |__ Port 2: Dev 5, If 3, Class=Human Interface Device, Driver=usbhid, 12M
            ID 17ef:30b0 Lenovo
        |__ Port 3: Dev 7, If 0, Class=, Driver=, 12M
            ID 17ef:30a9 Lenovo
        |__ Port 3: Dev 7, If 1, Class=Vendor Specific Class, Driver=, 12M
            ID 17ef:30a9 Lenovo
    |__ Port 3: Dev 2, If 0, Class=Video, Driver=uvcvideo, 480M
        ID 04f2:b6be Chicony Electronics Co., Ltd
    |__ Port 3: Dev 2, If 1, Class=Video, Driver=uvcvideo, 480M
    |__ Port 3: Dev 2, If 2, Class=Video, Driver=uvcvideo, 480M
    |__ Port 3: Dev 2, If 3, Class=Video, Driver=uvcvideo, 480M
    |__ Port 3: Dev 2, If 4, Class=Application Specific Interface, Driver=, 480M
inxi -a --usb
USB:
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
    speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
  Hub-2: 1-1:3 info: Lenovo USB2.0 Hub ports: 3 rev: 2.0 speed: 480 Mb/s
    chip-ID: 17ef:30af class-ID: 0900
  Hub-3: 1-1.1:4 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 17ef:30ac class-ID: 0900
  Device-1: 1-1.1.2:6 info: Sunplus Innovation EKACOM-K50E type: Video,Audio
    driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s
    power: 500mA chip-ID: 1bcf:2cb4 class-ID: 0102 serial: 01.00.00
  Hub-4: 1-1.1.3:8 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 17ef:30ae class-ID: 0900
  Hub-5: 1-1.1.3.1:9 info: Genesys Logic Hub ports: 4 rev: 2.1
    speed: 480 Mb/s power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-1.1.3.1.1:10 info: Logitech Cordless Mouse Receiver
    type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c539 class-ID: 0300
  Hub-6: 1-1.1.3.1.2:11 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
    rev: 2.1 speed: 480 Mb/s chip-ID: 0451:8142 class-ID: 0900
  Device-1: 1-1.1.3.1.2.4:13 info: LG USA Monitor Controls type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
    chip-ID: 043e:9a39 class-ID: 0300 serial: 009NTRLLJ934
  Device-2: 1-1.1.3.1.3:12 info: Winbond Ducky One2 SF RGB
    type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 5 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 0416:0123 class-ID: 0300
    serial: DK-V1.01-190709
  Device-3: 1-1.1.3.1.4:14 info: DSEA A/S GSP 370
    type: Audio,Keyboard,Abstract (modem),CDC-Data
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 1395:009a class-ID: 0a00
  Device-4: 1-1.2:5 info: Lenovo ThinkPad USB-C Dock Audio type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s power: 30mA chip-ID: 17ef:30b0 class-ID: 0300
    serial: 000000000000
  Device-5: 1-1.3:7 info: Lenovo 40AY type: Billboard driver: N/A
    interfaces: 2 rev: 2.0 speed: 12 Mb/s chip-ID: 17ef:30a9 class-ID: 1100
    serial: 1SSD21B41469ZVW0232F
  Device-6: 1-3:2 info: Chicony Integrated Camera type: Video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
    chip-ID: 04f2:b6be class-ID: fe01 serial: 0001
  Hub-7: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
    chip-ID: 1d6b:0003 class-ID: 0900
  Hub-8: 2-1:2 info: Lenovo USB3.1 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
    chip-ID: 17ef:30ab class-ID: 0900
  Device-1: 2-1.1:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
    power: 288mA chip-ID: 0bda:8153 class-ID: 0000 serial: 321000001
  Hub-9: 2-1.3:4 info: Lenovo USB3.1 Hub ports: 4 rev: 3.2 speed: 5 Gb/s
    chip-ID: 17ef:30ad class-ID: 0900
  Hub-10: 2-1.3.1:5 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
    chip-ID: 05e3:0612 class-ID: 0900
  Hub-11: 2-1.3.1.2:6 info: Texas Instruments TUSB8041 4-Port Hub ports: 4
    rev: 3.0 speed: 5 Gb/s chip-ID: 0451:8140 class-ID: 0900
  Hub-12: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-4:2 info: Realtek Bluetooth Radio type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
    chip-ID: 0bda:4852 class-ID: e001 serial: 00e04c000001
  Hub-13: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
I didn’t try a different kernel so far, lts would probably be the best choice right.
I don’t see much difference.
Since xrandr sees the monitors properly, Plasma should as well.
You haven’t said if KDE system settings / Display can see the monitor. Look closely.
Did you delete kscreen folder?
SDDM is another story.
If nothing helps, post Xorg.0.conf and journal log from a clean boot and login (in a web pastebin service).
The last time both monitors worked fine at boot and login screen (and also when I logged out). This time the second monitor never worked/had input.
I deleted the kscreen folder (which also did the job last time).
Luckily some update from today fixed the problem :innocent:
[2023-01-13T19:42:00+0100] [ALPM] upgraded alsa-card-profiles (1:0.3.63-6 -> 1:0.3.64-1)
[2023-01-13T19:42:00+0100] [ALPM] upgraded eos-translations (1.22-1 -> 23-2)
[2023-01-13T19:42:00+0100] [ALPM] upgraded pipewire (1:0.3.63-6 -> 1:0.3.64-1)
[2023-01-13T19:42:01+0100] [ALPM] upgraded mesa (22.3.2-3 -> 22.3.3-1)
[2023-01-13T19:42:01+0100] [ALPM] upgraded gst-plugin-pipewire (1:0.3.63-6 -> 1:0.3.64-1)
[2023-01-13T19:42:01+0100] [ALPM] upgraded libwebp (1.2.4-2 -> 1.3.0-2)
[2023-01-13T19:42:01+0100] [ALPM] upgraded linux (6.1.4.arch1-1 -> 6.1.5.arch2-1)
[2023-01-13T19:42:02+0100] [ALPM] upgraded linux-headers (6.1.4.arch1-1 -> 6.1.5.arch2-1)
[2023-01-13T19:42:02+0100] [ALPM] upgraded pipewire-audio (1:0.3.63-6 -> 1:0.3.64-1)
[2023-01-13T19:42:02+0100] [ALPM] upgraded pipewire-alsa (1:0.3.63-6 -> 1:0.3.64-1)
[2023-01-13T19:42:02+0100] [ALPM] upgraded pipewire-jack (1:0.3.63-6 -> 1:0.3.64-1)
[2023-01-13T19:42:02+0100] [ALPM] upgraded pipewire-pulse (1:0.3.63-6 -> 1:0.3.64-1)
I suspect the Kernel upgrade from 6.1.4.arch1-1 to 6.1.5.arch2-1.
I guess going bleeding edge has it’s disadvantages. Next time something doesn’t work properly I will try an older kernel first.
Thanks for everyones help and have a good day :slight_smile:
