I’ve had this problem on other systems, but it seems submitting this issue could draw attention to the forum and increase its popularity if it’s solved here, causing this topic to appear justified.
It’s technical more than anything, i’ve asked you specific questions above, start by answering them…
P.S. but if you want to just mine XMR on your home PC - my advice is to use xmrrig, because unless you have an AMD EPYC or something, it’s not about money, but about supporting Monero infrastructure, for almost 0 profit on your side - which is very noble.
I believe the place I said I got the binary from is the only place that an xmr-stak-nvidia release exists, the aur archive doesn’t show up in pacman -Ss xmr-stak and the only link in https://aur.archlinux.org/packages/xmr-stak-nvidia/ that seems to be working leads to fireice-uk’s xmr-stak.
As for xmrig, a guide to building it so that I can decide the fees and other aspects of the miner would be useful. I’ve tried using xmrig binaries before, but was still unable to use cuda.
This should be my final comment on this thread -
q1) There are many steps in the setting up of xmr-stak through yay. Might there be a definitive guide, or will the installation steps be specific to my system?
q2) If ETH is the most profitable cryptocurrency to currently mine, how could I start mining it quickly? I’m asking for steps to begin a ethereum miner and where/how I can keep track of when ETH mining is shut down(as I’ve heard it’s been bound to for quite some time).
