Hi,
I need help with my Wifi it isn’t working since the installation. I have recently switched from windows to linux and below are the details required
[kundan@EndeavourPC ~]$ lspci -k
00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
Subsystem: Hewlett-Packard Company Device 183e
Kernel driver in use: ivb_uncore
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port (rev 09)
Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
DeviceName: Intel(R) Graphics 4000
Kernel driver in use: i915
Kernel modules: i915
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:16.0 Communication controller: Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04)
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04)
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.1 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2 (rev c4)
00:1c.2 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 3 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation HM76 Express Chipset LPC Controller (rev 04)
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Thames [Radeon HD 7500M/7600M Series]
DeviceName: Radeon HD 7670M
Subsystem: Hewlett-Packard Company Radeon HD 7670M
Kernel driver in use: radeon
Kernel modules: radeon
07:00.0 Network controller: Ralink corp. RT3290 Wireless 802.11n 1T/1R PCIe
DeviceName: Ralink RT3290LE 802.11bgn 1x1 Wi-Fi and Bluetooth 4.0 Combo Ad
Subsystem: Hewlett-Packard Company Ralink RT3290LE 802.11bgn 1x1 Wi-Fi and Bluetooth 4.0 Combo Adapter
Kernel driver in use: rt2800pci
Kernel modules: rt2800pci
07:00.1 Bluetooth: Ralink corp. RT3290 Bluetooth
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 05)
DeviceName: Realtek PCIe FE Family Controller
Kernel driver in use: r8169
Kernel modules: r8169
09:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
Also
[kundan@EndeavourPC ~]$ iwconfig
lo no wireless extensions.
eno1 no wireless extensions.
wlan0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated Tx-Power=off
Retry short long limit:2 RTS thr:off Fragment thr:off
Power Management:off
[kundan@EndeavourPC ~]$ rfkill list all
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
Need help with this. Also have tried the Fn+F12/ F12 it pops up saying Hardware Airplane mode nothing happens
Firstly thank you for helping me out here, So I have tried the Physical keys so I have a HP pavilion g6 Laptop and the hardware switch is F12 but still wont work.
Also have gone through the article and have tried taping the pin 20 still no luck. I understand that OS has nothing to do with Hardware Blocked but If someone may have got a solution for this please help. Also its not that the hardware i.e WiFi Card is faulty coz it was working on Windows. Also you pointed out this article where the user switched to a live environment and somehow got it fixed but for me it doesnt work coz have tried multiple distros and it doesn’t work on an.
while installing the package I get the following error
Error! Bad return status for module build on kernel: 5.15.35-1-lts (x86_64)
Consult /var/lib/dkms/rt3290/2.6.0.0rev1/build/make.log for more information
==> Finished making: rt3290sta-dkms 2.6.0.0-5 (Thursday 28 April 2022 10:00:48 PM)
==> Installing package rt3290sta-dkms with pacman -U...
[sudo] password for kundan:
loading packages...
resolving dependencies...
Package (1) New Version Net Change
rt3290sta-dkms 2.6.0.0-5 4.14 MiB
Total Installed Size: 4.14 MiB
:: Proceed with installation? [Y/n] Y
(1/1) checking keys in keyring [------------------------------------------------------------] 100%
(1/1) checking package integrity [------------------------------------------------------------] 100%
(1/1) loading package files [------------------------------------------------------------] 100%
(1/1) checking for file conflicts [------------------------------------------------------------] 100%
:: Running pre-transaction hooks...
(1/1) Performing snapper pre snapshots for the following configurations...
==> root: 119
:: Processing package changes...
(1/1) installing rt3290sta-dkms [------------------------------------------------------------] 100%
Adding Module to DKMS build system
Deprecated feature: REMAKE_INITRD
Creating symlink /var/lib/dkms/rt3290/2.6.0.0rev1/source -> /usr/src/rt3290-2.6.0.0rev1
Doing initial module build
Building module:
cleaning build area...
make -j4 KERNELRELEASE=5.15.35-1-lts...(bad exit status: 2)
Consult /var/lib/dkms/rt3290/2.6.0.0rev1/build/make.log for more information.
Installing initial module
Building module:
Remember to enable DKMS at boot with "systemctl enable dkms"
(1/4) Arming ConditionNeedsUpdate...
(2/4) Install DKMS modules
==> dkms install --no-depmod rt3290/2.6.0.0rev1 -k 5.17.4-arch1-1
Error! Bad return status for module build on kernel: 5.17.4-arch1-1 (x86_64)
==> WARNING: `dkms install --no-depmod rt3290/2.6.0.0rev1 -k 5.17.4-arch1-1' exited 10
==> dkms install --no-depmod rt3290/2.6.0.0rev1 -k 5.15.35-1-lts
==> WARNING: `dkms install --no-depmod rt3290/2.6.0.0rev1 -k 5.15.35-1-lts' exited 10
==> dkms install --no-depmod rt3290/2.6.0.0rev1 -k 5.17.4-zen1-1-zen
Error! Bad return status for module build on kernel: 5.17.4-zen1-1-zen (x86_64)
==> WARNING: `dkms install --no-depmod rt3290/2.6.0.0rev1 -k 5.17.4-zen1-1-zen' exited 10
(3/4) Refreshing PackageKit...
(4/4) Performing snapper post snapshots for the following configurations...
==> root: 120
at first you can try to solve the fn key problem. look into your bios, maybe you can disable the fn key and have the same hardware function with only the f12 key(without fn). on my notebook i have this option.
Okay so unblock the rt2800pci and leave the other blacklist wmi and hopefully you uninstalled the rt390sta-dkms or maybe it didn’t install in the first place as i saw errors on the build.
So i’ll remove the line blacklist rt2800pci from blacklist.conf is that what you mean?
And also Yes I did uninstall the rt390sta-dkms as it gave errors.
Yes I completely agree with you but the thing is I have tried enabling the switch that toggles the WiFi Airplane Mode but nothing seems to happen. When I press F12(switch for toggling airplane mode) it still is amber= Airplane Mode is ON only and not white which means it is OFF now and one can turn on WiFi. So I don’t understand where the problem is because on Windows it was working so it doesn’t seem to be hardware issue also in BIOS everything is fine related to Network adapter is ON. Also just to be on safer side I reset the BIOS as well but nothing seems to work.
I completely understand that Hardware Blocked has nothing to with the OS but If you can help find me a workaround to get this fixed coz I so badly wanna switch to Linux and I’m very much liking the experience here unlike Windows. So the only issue is WiFi I’ve been searching through Internet for various solution have tried multiple even the one with blocking (taping Pin no.20 of the Wifi card ) but no luck.
Also I’m very thankful of you all helping me out here and Hopefully we find a solution
