Right click menu flickers and gone
If i change the compositor now, do i need to log out or restart or suspend or anything to see the effect ? or is it when i clicked “apply” it is effective straight away ?
If memory serves me, I think just hitting ‘Apply’ changes it. you will see a flicker.
Use a USB2 port on the motherboard. It will be black if you look at it not blue. Same applies for a laptop. You make so many posts I can’t keep up :sweat_smile:
Also, are you using Nvidia by chance, and/or, proprietary drivers?
Sorry, not that i want to post… I just want to get my work done… but when my computer is so annoying to use, i can’t help it but ask for help
Btw, i am using usb with black color in it (USB2.0) for my mouse.
Did you try the blue one?
Sorry, took so long to reply (i need to read up to know what command to enter to get what you want to know).
May i know what does this output of this command shows ?
Am i using Nvidia or Integrated Graphic controller ?
$ lspci -k | grep -A 2 -E "(VGA|3D)"
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06)
        DeviceName:  Onboard IGD
        Subsystem: Micro-Star International Co., Ltd. [MSI] Device 1113
01:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 940M] (rev a2)
        Kernel driver in use: nvidia
$inxi
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Micro-Star MSI driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:0416
           Device-2: NVIDIA GM108M [GeForce 940M] vendor: Micro-Star MSI driver: nvidia v: 450.66 bus ID: 01:00.0
           chip ID: 10de:1347
           Device-3: Acer MSI Integrated Webcam type: USB driver: uvcvideo bus ID: 1-1.4:5 chip ID: 5986:014c
           Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel,nvidia unloaded: fbdev,modesetting,vesa
           alternate: nouveau,nv resolution: 1: 1920x1080 2: 1920x1080~60Hz s-dpi: 96
Yes, just tried. Same, in fact it looks worst , i have to click more time to get it.
As a person posted on internet regarding this issue:
" Some time after right clicked, hold the right button do not let go, the menu will be there ; but if click and let go the button, the menu will be gone. "
Also, after several times of right click menu flicker and gone, eventually, the menu will be there, not “appears and gone” anymore, until i click on something else…
That’s why it is hard to describe, because it is totally random.
You have a hybrid system, both Intel and Nvidia GPUs. I am not really familiar with the hybrid setup, I always run pure Nivida with proprietary graphics, but one option to try is toggling off ‘Sync to VBlank’. Usually I find this in the Nvidia Settings app which you would have if running proprietary graphics. See if you have it and look for that option under the OpenGL Settings tab.
The above is if you are using Nivida, but if you are using your Intel GPU and getting screen tearing, then this might be a solution;
Screenshot_20200917_142030
I don’t know if this will provide you any info or not.
here it goes:
$ vulkaninfo
VULKANINFO
Vulkan Instance Version: 1.2.151
Instance Extensions: count = 17
        VK_EXT_acquire_xlib_display            : extension revision 1
        VK_EXT_debug_report                    : extension revision 9
        VK_EXT_debug_utils                     : extension revision 1
        VK_EXT_direct_mode_display             : extension revision 1
        VK_EXT_display_surface_counter         : extension revision 1
        VK_KHR_device_group_creation           : extension revision 1
        VK_KHR_display                         : extension revision 23
        VK_KHR_external_fence_capabilities     : extension revision 1
        VK_KHR_external_memory_capabilities    : extension revision 1
        VK_KHR_external_semaphore_capabilities : extension revision 1
        VK_KHR_get_display_properties2         : extension revision 1
        VK_KHR_get_physical_device_properties2 : extension revision 2
        VK_KHR_get_surface_capabilities2       : extension revision 1
        VK_KHR_surface                         : extension revision 25
        VK_KHR_surface_protected_capabilities  : extension revision 1
        VK_KHR_xcb_surface                     : extension revision 6
        VK_KHR_xlib_surface                    : extension revision 6
Layers: count = 1
VK_LAYER_NV_optimus (NVIDIA Optimus layer) Vulkan version 1.2.133, layer version 1:
        Layer Extensions: count = 0
        Devices: count = 1
                GPU id = 0 (GeForce 940M)
                Layer-Device Extensions: count = 0
Presentable Surfaces:
GPU id : 0 (GeForce 940M):
        Surface types: count = 2
                VK_KHR_xcb_surface
                VK_KHR_xlib_surface
        Formats: count = 2
                SurfaceFormat[0]:
                        format = FORMAT_B8G8R8A8_UNORM
                        colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
                SurfaceFormat[1]:
                        format = FORMAT_B8G8R8A8_SRGB
        Present Modes: count = 3
                PRESENT_MODE_FIFO_KHR
                PRESENT_MODE_FIFO_RELAXED_KHR
                PRESENT_MODE_IMMEDIATE_KHR
        VkSurfaceCapabilitiesKHR:
                minImageCount       = 2
                maxImageCount       = 8
                currentExtent:
                        width  = 256
                        height = 256
                minImageExtent:
                        width  = 256
                        height = 256
                maxImageExtent:
                        width  = 256
                        height = 256
                maxImageArrayLayers = 1
                supportedTransforms: count = 1
                        SURFACE_TRANSFORM_IDENTITY_BIT_KHR
                currentTransform    = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
                supportedCompositeAlpha: count = 1
                        COMPOSITE_ALPHA_OPAQUE_BIT_KHR
                supportedUsageFlags: count = 6
                        IMAGE_USAGE_TRANSFER_SRC_BIT
                        IMAGE_USAGE_TRANSFER_DST_BIT
                        IMAGE_USAGE_SAMPLED_BIT
                        IMAGE_USAGE_STORAGE_BIT
                        IMAGE_USAGE_COLOR_ATTACHMENT_BIT
                        IMAGE_USAGE_INPUT_ATTACHMENT_BIT
        VkSurfaceCapabilities2EXT:
                supportedSurfaceCounters: count = 0
                        None
        VkSurfaceProtectedCapabilitiesKHR:
                supportsProtected = false
Device Groups:
Group 0:
        Properties:
                physicalDevices: count = 1
                        GeForce 940M (ID: 0)
                subsetAllocation = 0
        Present Capabilities:
                GeForce 940M (ID: 0):
                        Can present images from the following devices: count = 1
                Present modes: count = 1
                        DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
        apiVersion     = 4202629 (1.2.133)
        driverVersion  = 1888518144 (0x70908000)
        vendorID       = 0x10de
        deviceID       = 0x1347
        deviceType     = PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
        deviceName     = GeForce 940M
VkPhysicalDeviceLimits:
        maxImageDimension1D                             = 16384
        maxImageDimension2D                             = 16384
        maxImageDimension3D                             = 2048
        maxImageDimensionCube                           = 16384
        maxImageArrayLayers                             = 2048
        maxTexelBufferElements                          = 134217728
        maxUniformBufferRange                           = 65536
        maxStorageBufferRange                           = 4294967295
        maxPushConstantsSize                            = 256
        maxMemoryAllocationCount                        = 4294967295
        maxSamplerAllocationCount                       = 4000
        bufferImageGranularity                          = 0x00010000
        sparseAddressSpaceSize                          = 0xffffffffff
        maxBoundDescriptorSets                          = 32
        maxPerStageDescriptorSamplers                   = 1048576
        maxPerStageDescriptorUniformBuffers             = 15
        maxPerStageDescriptorStorageBuffers             = 1048576
        maxPerStageDescriptorSampledImages              = 1048576
        maxPerStageDescriptorStorageImages              = 1048576
        maxPerStageDescriptorInputAttachments           = 1048576
        maxPerStageResources                            = 4294967295
        maxDescriptorSetSamplers                        = 1048576
        maxDescriptorSetUniformBuffers                  = 90
        maxDescriptorSetUniformBuffersDynamic           = 15
        maxDescriptorSetStorageBuffers                  = 1048576
        maxDescriptorSetStorageBuffersDynamic           = 16
        maxDescriptorSetSampledImages                   = 1048576
        maxDescriptorSetStorageImages                   = 1048576
        maxDescriptorSetInputAttachments                = 1048576
        maxVertexInputAttributes                        = 32
        maxVertexInputBindings                          = 32
        maxVertexInputAttributeOffset                   = 2047
        maxVertexInputBindingStride                     = 2048
        maxVertexOutputComponents                       = 128
        maxTessellationGenerationLevel                  = 64
        maxTessellationPatchSize                        = 32
        maxTessellationControlPerVertexInputComponents  = 128
        maxTessellationControlPerVertexOutputComponents = 128
        maxTessellationControlPerPatchOutputComponents  = 120
        maxTessellationControlTotalOutputComponents     = 4216
        maxTessellationEvaluationInputComponents        = 128
        maxTessellationEvaluationOutputComponents       = 128
        maxGeometryShaderInvocations                    = 32
        maxGeometryInputComponents                      = 128
        maxGeometryOutputComponents                     = 128
        maxGeometryOutputVertices                       = 1024
        maxGeometryTotalOutputComponents                = 1024
        maxFragmentInputComponents                      = 128
        maxFragmentOutputAttachments                    = 8
        maxFragmentDualSrcAttachments                   = 1
        maxFragmentCombinedOutputResources              = 16
        maxComputeSharedMemorySize                      = 49152
        maxComputeWorkGroupCount: count = 3
                2147483647
                65535
                65535
        maxComputeWorkGroupInvocations                  = 1536
        maxComputeWorkGroupSize: count = 3
                1536
                1024
                64
        subPixelPrecisionBits                           = 8
        subTexelPrecisionBits                           = 8
        mipmapPrecisionBits                             = 8
        maxDrawIndexedIndexValue                        = 4294967295
        maxDrawIndirectCount                            = 4294967295
        maxSamplerLodBias                               = 15
        maxSamplerAnisotropy                            = 16
        maxViewports                                    = 16
        maxViewportDimensions: count = 2
                16384
                16384
        viewportBoundsRange: count = 2
                -32768
                32768
        viewportSubPixelBits                            = 8
        minMemoryMapAlignment                           = 64
        minTexelBufferOffsetAlignment                   = 0x00000010
        minUniformBufferOffsetAlignment                 = 0x00000100
        minStorageBufferOffsetAlignment                 = 0x00000010
        minTexelOffset                                  = -8
        maxTexelOffset                                  = 7
        minTexelGatherOffset                            = -32
        maxTexelGatherOffset                            = 31
        minInterpolationOffset                          = -0.5
        maxInterpolationOffset                          = 0.4375
        subPixelInterpolationOffsetBits                 = 4
        maxFramebufferWidth                             = 16384
        maxFramebufferHeight                            = 16384
        maxFramebufferLayers                            = 2048
        framebufferColorSampleCounts: count = 4
                SAMPLE_COUNT_1_BIT
                SAMPLE_COUNT_2_BIT
                SAMPLE_COUNT_4_BIT
                SAMPLE_COUNT_8_BIT
        framebufferDepthSampleCounts: count = 4
                SAMPLE_COUNT_1_BIT
                SAMPLE_COUNT_2_BIT
                SAMPLE_COUNT_4_BIT
                SAMPLE_COUNT_8_BIT
        framebufferStencilSampleCounts: count = 4
                SAMPLE_COUNT_1_BIT
                SAMPLE_COUNT_2_BIT
                SAMPLE_COUNT_4_BIT
                SAMPLE_COUNT_8_BIT
        framebufferNoAttachmentsSampleCounts: count = 4
                SAMPLE_COUNT_1_BIT
                SAMPLE_COUNT_2_BIT
                SAMPLE_COUNT_4_BIT
                SAMPLE_COUNT_8_BIT
        maxColorAttachments                             = 8
        sampledImageColorSampleCounts: count = 4
                SAMPLE_COUNT_1_BIT
                SAMPLE_COUNT_2_BIT
                SAMPLE_COUNT_4_BIT
                SAMPLE_COUNT_8_BIT
        sampledImageIntegerSampleCounts: count = 4
                SAMPLE_COUNT_1_BIT
                SAMPLE_COUNT_2_BIT
                SAMPLE_COUNT_4_BIT
                SAMPLE_COUNT_8_BIT
        sampledImageDepthSampleCounts: count = 4
                SAMPLE_COUNT_1_BIT
                SAMPLE_COUNT_2_BIT
                SAMPLE_COUNT_4_BIT
                SAMPLE_COUNT_8_BIT
        sampledImageStencilSampleCounts: count = 4
                SAMPLE_COUNT_1_BIT
                SAMPLE_COUNT_2_BIT
                SAMPLE_COUNT_4_BIT
                SAMPLE_COUNT_8_BIT
        storageImageSampleCounts: count = 4
                SAMPLE_COUNT_1_BIT
                SAMPLE_COUNT_2_BIT
                SAMPLE_COUNT_4_BIT
                SAMPLE_COUNT_8_BIT
        maxSampleMaskWords                              = 1
        timestampComputeAndGraphics                     = true
        timestampPeriod                                 = 1
        maxClipDistances                                = 8
        maxCullDistances                                = 8
        maxCombinedClipAndCullDistances                 = 8
        discreteQueuePriorities                         = 2
        pointSizeRange: count = 2
                1
                2047.94
        lineWidthRange: count = 2
                1
                64
        pointSizeGranularity                            = 0.0625
        lineWidthGranularity                            = 0.0625
        strictLines                                     = true
        standardSampleLocations                         = true
        optimalBufferCopyOffsetAlignment                = 0x00000001
        optimalBufferCopyRowPitchAlignment              = 0x00000001
        nonCoherentAtomSize                             = 0x00000040
VkPhysicalDeviceSparseProperties:
        residencyStandard2DBlockShape            = true
        residencyStandard2DMultisampleBlockShape = true
        residencyStandard3DBlockShape            = true
        residencyAlignedMipSize                  = true
        residencyNonResidentStrict               = false
VkPhysicalDeviceBlendOperationAdvancedPropertiesEXT:
        advancedBlendMaxColorAttachments      = 1
        advancedBlendIndependentBlend         = false
        advancedBlendNonPremultipliedSrcColor = true
        advancedBlendNonPremultipliedDstColor = true
        advancedBlendCorrelatedOverlap        = true
        advancedBlendAllOperations            = true
VkPhysicalDeviceCustomBorderColorPropertiesEXT:
        maxCustomBorderColorSamplers = 4000
VkPhysicalDeviceDepthStencilResolveProperties:
        supportedDepthResolveModes: count = 2
                RESOLVE_MODE_SAMPLE_ZERO_BIT
                RESOLVE_MODE_AVERAGE_BIT
        supportedStencilResolveModes: count = 1
        independentResolveNone = true
        independentResolve     = true
VkPhysicalDeviceDescriptorIndexingProperties:
        maxUpdateAfterBindDescriptorsInAllPools              = 4294967295
        shaderUniformBufferArrayNonUniformIndexingNative     = true
        shaderSampledImageArrayNonUniformIndexingNative      = true
        shaderStorageBufferArrayNonUniformIndexingNative     = true
        shaderStorageImageArrayNonUniformIndexingNative      = true
        shaderInputAttachmentArrayNonUniformIndexingNative   = true
        robustBufferAccessUpdateAfterBind                    = true
        quadDivergentImplicitLod                             = true
        maxPerStageDescriptorUpdateAfterBindSamplers         = 1048576
        maxPerStageDescriptorUpdateAfterBindUniformBuffers   = 15
        maxPerStageDescriptorUpdateAfterBindStorageBuffers   = 1048576
        maxPerStageDescriptorUpdateAfterBindSampledImages    = 1048576
        maxPerStageDescriptorUpdateAfterBindStorageImages    = 1048576
        maxPerStageDescriptorUpdateAfterBindInputAttachments = 1048576
        maxPerStageUpdateAfterBindResources                  = 4294967295
        maxDescriptorSetUpdateAfterBindSamplers              = 1048576
        maxDescriptorSetUpdateAfterBindUniformBuffers        = 90
        maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 15
        maxDescriptorSetUpdateAfterBindStorageBuffers        = 1048576
        maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 16
        maxDescriptorSetUpdateAfterBindSampledImages         = 1048576
        maxDescriptorSetUpdateAfterBindStorageImages         = 1048576
        maxDescriptorSetUpdateAfterBindInputAttachments      = 1048576
VkPhysicalDeviceDiscardRectanglePropertiesEXT:
        maxDiscardRectangles = 8
VkPhysicalDeviceDriverProperties:
        driverID           = DRIVER_ID_NVIDIA_PROPRIETARY
        driverName         = NVIDIA
        driverInfo         = 450.66
        conformanceVersion = 1.2.2.0
VkPhysicalDeviceFloatControlsProperties:
        denormBehaviorIndependence            = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
        roundingModeIndependence              = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
        shaderSignedZeroInfNanPreserveFloat16 = true
        shaderSignedZeroInfNanPreserveFloat32 = true
        shaderSignedZeroInfNanPreserveFloat64 = true
        shaderDenormPreserveFloat16           = false
        shaderDenormPreserveFloat32           = false
        shaderDenormPreserveFloat64           = false
        shaderDenormFlushToZeroFloat16        = false
        shaderDenormFlushToZeroFloat32        = false
        shaderDenormFlushToZeroFloat64        = false
        shaderRoundingModeRTEFloat16          = true
        shaderRoundingModeRTEFloat32          = true
        shaderRoundingModeRTEFloat64          = true
        shaderRoundingModeRTZFloat16          = false
        shaderRoundingModeRTZFloat32          = true
        shaderRoundingModeRTZFloat64          = true
VkPhysicalDeviceIDProperties:
        deviceUUID      = 0ad65b07-d308-b39a-5b13-37a7773a13df
        driverUUID      = 9a8207c5-fc0f-47a3-d29d-8830ae9778e8
        deviceNodeMask  = 1
        deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockPropertiesEXT:
        maxInlineUniformBlockSize                               = 256
        maxPerStageDescriptorInlineUniformBlocks                = 32
        maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 32
        maxDescriptorSetInlineUniformBlocks                     = 32
        maxDescriptorSetUpdateAfterBindInlineUniformBlocks      = 32
VkPhysicalDeviceLineRasterizationPropertiesEXT:
        lineSubPixelPrecisionBits = 8
VkPhysicalDeviceMaintenance3Properties:
        maxPerSetDescriptors    = 4294967295
        maxMemoryAllocationSize = 0xffe00000
VkPhysicalDeviceMultiviewProperties:
        maxMultiviewViewCount     = 32
        maxMultiviewInstanceIndex = 134217727
VkPhysicalDevicePCIBusInfoPropertiesEXT:
        pciDomain   = 0
        pciBus      = 1
        pciDevice   = 0
        pciFunction = 0
VkPhysicalDevicePointClippingProperties:
        pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_USER_CLIP_PLANES_ONLY
VkPhysicalDeviceProtectedMemoryProperties:
        protectedNoFault = false
VkPhysicalDevicePushDescriptorPropertiesKHR:
        maxPushDescriptors = 32
VkPhysicalDeviceSamplerFilterMinmaxProperties:
        filterMinmaxSingleComponentFormats = false
        filterMinmaxImageComponentMapping  = false
VkPhysicalDeviceSubgroupProperties:
        subgroupSize              = 32
        supportedStages: count = 8
                SHADER_STAGE_VERTEX_BIT
                SHADER_STAGE_TESSELLATION_CONTROL_BIT
                SHADER_STAGE_TESSELLATION_EVALUATION_BIT
                SHADER_STAGE_GEOMETRY_BIT
                SHADER_STAGE_FRAGMENT_BIT
                SHADER_STAGE_COMPUTE_BIT
                SHADER_STAGE_ALL_GRAPHICS
                SHADER_STAGE_ALL
        supportedOperations: count = 9
                SUBGROUP_FEATURE_BASIC_BIT
                SUBGROUP_FEATURE_VOTE_BIT
                SUBGROUP_FEATURE_ARITHMETIC_BIT
                SUBGROUP_FEATURE_BALLOT_BIT
                SUBGROUP_FEATURE_SHUFFLE_BIT
                SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
                SUBGROUP_FEATURE_CLUSTERED_BIT
                SUBGROUP_FEATURE_QUAD_BIT
                SUBGROUP_FEATURE_PARTITIONED_BIT_NV
        quadOperationsInAllStages = true
VkPhysicalDeviceSubgroupSizeControlPropertiesEXT:
        minSubgroupSize              = 32
        maxSubgroupSize              = 32
        maxComputeWorkgroupSubgroups = 3145728
        requiredSubgroupSizeStages: count = 8
                SHADER_STAGE_ALL
VkPhysicalDeviceTexelBufferAlignmentPropertiesEXT:
        storageTexelBufferOffsetAlignmentBytes       = 0x00000010
        storageTexelBufferOffsetSingleTexelAlignment = true
        uniformTexelBufferOffsetAlignmentBytes       = 0x00000010
        uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphoreProperties:
        maxTimelineSemaphoreValueDifference = 2147483647
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
        maxTransformFeedbackStreams                = 4
        maxTransformFeedbackBuffers                = 4
        maxTransformFeedbackBufferSize             = 0xffffffffffffffff
        maxTransformFeedbackStreamDataSize         = 2048
        maxTransformFeedbackBufferDataSize         = 512
        maxTransformFeedbackBufferDataStride       = 2048
        transformFeedbackQueries                   = true
        transformFeedbackStreamsLinesTriangles     = false
        transformFeedbackRasterizationStreamSelect = true
        transformFeedbackDraw                      = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
        maxVertexAttribDivisor = 4294967295
VkPhysicalDeviceVulkan11Properties:
        deviceNodeMask                    = 1
        subgroupSize                      = 32
        subgroupSupportedStages: count = 8
                SHADER_STAGE_ALL
        subgroupSupportedOperations: count = 9
        subgroupQuadOperationsInAllStages = true
VkPhysicalDeviceVulkan12Properties:
        driverName                                           = NVIDIA
        driverInfo                                           = 450.66
        framebufferIntegerColorSampleCounts: count = 4
                SAMPLE_COUNT_1_BIT
                SAMPLE_COUNT_2_BIT
                SAMPLE_COUNT_4_BIT
                SAMPLE_COUNT_8_BIT
Device Extensions: count = 82
        VK_EXT_blend_operation_advanced           : extension revision 2
        VK_EXT_buffer_device_address              : extension revision 2
        VK_EXT_calibrated_timestamps              : extension revision 1
        VK_EXT_conditional_rendering              : extension revision 2
        VK_EXT_custom_border_color                : extension revision 11
        VK_EXT_depth_clip_enable                  : extension revision 1
        VK_EXT_depth_range_unrestricted           : extension revision 1
        VK_EXT_descriptor_indexing                : extension revision 2
        VK_EXT_discard_rectangles                 : extension revision 1
        VK_EXT_display_control                    : extension revision 1
        VK_EXT_global_priority                    : extension revision 2
        VK_EXT_host_query_reset                   : extension revision 1
        VK_EXT_index_type_uint8                   : extension revision 1
        VK_EXT_inline_uniform_block               : extension revision 1
        VK_EXT_line_rasterization                 : extension revision 1
        VK_EXT_memory_budget                      : extension revision 1
        VK_EXT_pci_bus_info                       : extension revision 2
        VK_EXT_pipeline_creation_feedback         : extension revision 1
        VK_EXT_scalar_block_layout                : extension revision 1
        VK_EXT_separate_stencil_usage             : extension revision 1
        VK_EXT_shader_demote_to_helper_invocation : extension revision 1
        VK_EXT_shader_subgroup_ballot             : extension revision 1
        VK_EXT_shader_subgroup_vote               : extension revision 1
        VK_EXT_subgroup_size_control              : extension revision 2
        VK_EXT_texel_buffer_alignment             : extension revision 1
        VK_EXT_tooling_info                       : extension revision 1
        VK_EXT_transform_feedback                 : extension revision 1
        VK_EXT_vertex_attribute_divisor           : extension revision 3
        VK_EXT_ycbcr_image_arrays                 : extension revision 1
        VK_KHR_16bit_storage                      : extension revision 1
        VK_KHR_8bit_storage                       : extension revision 1
        VK_KHR_bind_memory2                       : extension revision 1
        VK_KHR_buffer_device_address              : extension revision 1
        VK_KHR_create_renderpass2                 : extension revision 1
        VK_KHR_dedicated_allocation               : extension revision 3
        VK_KHR_depth_stencil_resolve              : extension revision 1
        VK_KHR_descriptor_update_template         : extension revision 1
        VK_KHR_device_group                       : extension revision 4
        VK_KHR_draw_indirect_count                : extension revision 1
        VK_KHR_driver_properties                  : extension revision 1
        VK_KHR_external_fence                     : extension revision 1
        VK_KHR_external_fence_fd                  : extension revision 1
        VK_KHR_external_memory                    : extension revision 1
        VK_KHR_external_memory_fd                 : extension revision 1
        VK_KHR_external_semaphore                 : extension revision 1
        VK_KHR_external_semaphore_fd              : extension revision 1
        VK_KHR_get_memory_requirements2           : extension revision 1
        VK_KHR_image_format_list                  : extension revision 1
        VK_KHR_imageless_framebuffer              : extension revision 1
        VK_KHR_maintenance1                       : extension revision 2
        VK_KHR_maintenance2                       : extension revision 1
        VK_KHR_maintenance3                       : extension revision 1
        VK_KHR_multiview                          : extension revision 1
        VK_KHR_pipeline_executable_properties     : extension revision 1
        VK_KHR_push_descriptor                    : extension revision 2
        VK_KHR_relaxed_block_layout               : extension revision 1
        VK_KHR_sampler_mirror_clamp_to_edge       : extension revision 3
        VK_KHR_sampler_ycbcr_conversion           : extension revision 14
        VK_KHR_separate_depth_stencil_layouts     : extension revision 1
        VK_KHR_shader_atomic_int64                : extension revision 1
        VK_KHR_shader_clock                       : extension revision 1
        VK_KHR_shader_draw_parameters             : extension revision 1
        VK_KHR_shader_float16_int8                : extension revision 1
        VK_KHR_shader_float_controls              : extension revision 4
        VK_KHR_shader_non_semantic_info           : extension revision 1
        VK_KHR_shader_subgroup_extended_types     : extension revision 1
        VK_KHR_spirv_1_4                          : extension revision 1
        VK_KHR_storage_buffer_storage_class       : extension revision 1
        VK_KHR_swapchain                          : extension revision 70
        VK_KHR_swapchain_mutable_format           : extension revision 1
        VK_KHR_timeline_semaphore                 : extension revision 2
        VK_KHR_uniform_buffer_standard_layout     : extension revision 1
        VK_KHR_variable_pointers                  : extension revision 1
        VK_KHR_vulkan_memory_model                : extension revision 3
        VK_NVX_device_generated_commands          : extension revision 3
        VK_NVX_multiview_per_view_attributes      : extension revision 1
        VK_NV_dedicated_allocation                : extension revision 1
        VK_NV_dedicated_allocation_image_aliasing : extension revision 1
        VK_NV_device_diagnostic_checkpoints       : extension revision 2
        VK_NV_device_diagnostics_config           : extension revision 1
        VK_NV_shader_sm_builtins                  : extension revision 1
        VK_NV_shader_subgroup_partitioned         : extension revision 1
VkQueueFamilyProperties:
        queueProperties[0]:
                minImageTransferGranularity = (1,1,1)
                queueCount                  = 16
                queueFlags                  = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
                timestampValidBits          = 64
                present support             = true
        queueProperties[1]:
                queueCount                  = 1
                queueFlags                  = QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
                present support             = false
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 3
        memoryHeaps[0]:
                size   = 2147483648 (0x80000000) (2.00 GiB)
                budget = 2097545216 (0x7d060000) (1.95 GiB)
                usage  = 0 (0x00000000) (0.00 B)
                flags: count = 1
                        MEMORY_HEAP_DEVICE_LOCAL_BIT
        memoryHeaps[1]:
                size   = 12527102976 (0x2eaac6c00) (11.67 GiB)
                budget = 12527102976 (0x2eaac6c00) (11.67 GiB)
                flags: count = 0
                        None
        memoryHeaps[2]:
                size   = 257949696 (0x0f600000) (246.00 MiB)
                budget = 256376832 (0x0f480000) (244.50 MiB)
                usage  = 1572864 (0x00180000) (1.50 MiB)
                flags: count = 1
memoryTypes: count = 11
        memoryTypes[0]:
                heapIndex     = 1
                propertyFlags = 0x0000: count = 0
                        None
                usable for:
                        IMAGE_TILING_OPTIMAL:
                                None
                        IMAGE_TILING_LINEAR:
                                color images
                                (non-sparse, non-transient)
        memoryTypes[1]:
                heapIndex     = 1
                        None
                usable for:
                                color images
                                (non-sparse)
                                None
        memoryTypes[2]:
                heapIndex     = 1
                        None
                usable for:
                                FORMAT_D16_UNORM
                                (non-sparse)
                                None
        memoryTypes[3]:
                heapIndex     = 1
                        None
                usable for:
                                FORMAT_X8_D24_UNORM_PACK32
                                FORMAT_D24_UNORM_S8_UINT
                                (non-sparse)
                                None
        memoryTypes[4]:
                heapIndex     = 1
                        None
                usable for:
                                FORMAT_D32_SFLOAT
                                (non-sparse)
                                None
        memoryTypes[5]:
                heapIndex     = 1
                        None
                usable for:
                                FORMAT_D32_SFLOAT_S8_UINT
                                (non-sparse)
                                None
        memoryTypes[6]:
                heapIndex     = 1
                        None
                usable for:
                                None
                                None
        memoryTypes[7]:
                heapIndex     = 0
                propertyFlags = 0x0001: count = 1
                        MEMORY_PROPERTY_DEVICE_LOCAL_BIT
                usable for:
                                color images
                                FORMAT_D16_UNORM
                                FORMAT_D32_SFLOAT
                                (non-sparse)
                                color images
        memoryTypes[8]:
                heapIndex     = 1
                propertyFlags = 0x0006: count = 2
                        MEMORY_PROPERTY_HOST_VISIBLE_BIT
                        MEMORY_PROPERTY_HOST_COHERENT_BIT
                usable for:
                                None
                                color images
        memoryTypes[9]:
                heapIndex     = 1
                propertyFlags = 0x000e: count = 3
                        MEMORY_PROPERTY_HOST_CACHED_BIT
                usable for:
                                None
                                color images
        memoryTypes[10]:
                heapIndex     = 2
                propertyFlags = 0x0007: count = 3
                usable for:
                                None
                                None
VkPhysicalDeviceFeatures:
        robustBufferAccess                      = true
        fullDrawIndexUint32                     = true
        imageCubeArray                          = true
        independentBlend                        = true
        geometryShader                          = true
        tessellationShader                      = true
        sampleRateShading                       = true
        dualSrcBlend                            = true
        logicOp                                 = true
        multiDrawIndirect                       = true
        drawIndirectFirstInstance               = true
        depthClamp                              = true
        depthBiasClamp                          = true
        fillModeNonSolid                        = true
        depthBounds                             = true
        wideLines                               = true
        largePoints                             = true
        alphaToOne                              = true
        multiViewport                           = true
        samplerAnisotropy                       = true
        textureCompressionETC2                  = false
        textureCompressionASTC_LDR              = false
        textureCompressionBC                    = true
        occlusionQueryPrecise                   = true
        pipelineStatisticsQuery                 = true
        vertexPipelineStoresAndAtomics          = true
        fragmentStoresAndAtomics                = true
        shaderTessellationAndGeometryPointSize  = true
        shaderImageGatherExtended               = true
        shaderStorageImageExtendedFormats       = true
        shaderStorageImageMultisample           = true
        shaderStorageImageReadWithoutFormat     = true
        shaderStorageImageWriteWithoutFormat    = true
        shaderUniformBufferArrayDynamicIndexing = true
        shaderSampledImageArrayDynamicIndexing  = true
        shaderStorageBufferArrayDynamicIndexing = true
        shaderStorageImageArrayDynamicIndexing  = true
        shaderClipDistance                      = true
        shaderCullDistance                      = true
        shaderFloat64                           = true
        shaderInt64                             = true
        shaderInt16                             = true
        shaderResourceResidency                 = false
        shaderResourceMinLod                    = false
        sparseBinding                           = true
        sparseResidencyBuffer                   = false
        sparseResidencyImage2D                  = false
        sparseResidencyImage3D                  = false
        sparseResidency2Samples                 = false
        sparseResidency4Samples                 = false
        sparseResidency8Samples                 = false
        sparseResidency16Samples                = false
        sparseResidencyAliased                  = false
        variableMultisampleRate                 = true
        inheritedQueries                        = true
VkPhysicalDevice16BitStorageFeatures:
        storageBuffer16BitAccess           = true
        uniformAndStorageBuffer16BitAccess = true
        storagePushConstant16              = true
        storageInputOutput16               = false
VkPhysicalDevice8BitStorageFeatures:
        storageBuffer8BitAccess           = true
        uniformAndStorageBuffer8BitAccess = true
        storagePushConstant8              = true
VkPhysicalDeviceBlendOperationAdvancedFeaturesEXT:
        advancedBlendCoherentOperations = true
VkPhysicalDeviceBufferDeviceAddressFeatures:
        bufferDeviceAddress              = true
        bufferDeviceAddressCaptureReplay = false
        bufferDeviceAddressMultiDevice   = true
VkPhysicalDeviceBufferDeviceAddressFeaturesEXT:
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
        conditionalRendering          = true
        inheritedConditionalRendering = true
VkPhysicalDeviceCustomBorderColorFeaturesEXT:
        customBorderColors             = true
        customBorderColorWithoutFormat = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
        depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
        shaderInputAttachmentArrayDynamicIndexing          = true
        shaderUniformTexelBufferArrayDynamicIndexing       = true
        shaderStorageTexelBufferArrayDynamicIndexing       = true
        shaderUniformBufferArrayNonUniformIndexing         = true
        shaderSampledImageArrayNonUniformIndexing          = true
        shaderStorageBufferArrayNonUniformIndexing         = true
        shaderStorageImageArrayNonUniformIndexing          = true
        shaderInputAttachmentArrayNonUniformIndexing       = true
        shaderUniformTexelBufferArrayNonUniformIndexing    = true
        shaderStorageTexelBufferArrayNonUniformIndexing    = true
        descriptorBindingUniformBufferUpdateAfterBind      = false
        descriptorBindingSampledImageUpdateAfterBind       = true
        descriptorBindingStorageImageUpdateAfterBind       = true
        descriptorBindingStorageBufferUpdateAfterBind      = true
        descriptorBindingUniformTexelBufferUpdateAfterBind = true
        descriptorBindingStorageTexelBufferUpdateAfterBind = true
        descriptorBindingUpdateUnusedWhilePending          = true
        descriptorBindingPartiallyBound                    = true
        descriptorBindingVariableDescriptorCount           = true
        runtimeDescriptorArray                             = true
VkPhysicalDeviceHostQueryResetFeatures:
        hostQueryReset = true
VkPhysicalDeviceImagelessFramebufferFeatures:
        imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
        indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeaturesEXT:
        inlineUniformBlock                                 = true
        descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
        rectangularLines         = true
        bresenhamLines           = true
        smoothLines              = true
        stippledRectangularLines = true
        stippledBresenhamLines   = true
        stippledSmoothLines      = true
VkPhysicalDeviceMultiviewFeatures:
        multiview                   = true
        multiviewGeometryShader     = true
        multiviewTessellationShader = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
        pipelineExecutableInfo = true
VkPhysicalDeviceProtectedMemoryFeatures:
        protectedMemory = false
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
        samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
        scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
        separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicInt64Features:
        shaderBufferInt64Atomics = true
        shaderSharedInt64Atomics = true
VkPhysicalDeviceShaderClockFeaturesKHR:
        shaderSubgroupClock = true
        shaderDeviceClock   = true
VkPhysicalDeviceShaderDemoteToHelperInvocationFeaturesEXT:
        shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
        shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
        shaderFloat16 = false
        shaderInt8    = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
        shaderSubgroupExtendedTypes = true
VkPhysicalDeviceSubgroupSizeControlFeaturesEXT:
        subgroupSizeControl  = true
        computeFullSubgroups = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
        texelBufferAlignment = true
VkPhysicalDeviceTimelineSemaphoreFeatures:
        timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
        transformFeedback = true
        geometryStreams   = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
        uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
        variablePointersStorageBuffer = true
        variablePointers              = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
        vertexAttributeInstanceRateDivisor     = true
        vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVulkan11Features:
        multiview                          = true
VkPhysicalDeviceVulkan12Features:
        samplerMirrorClampToEdge                           = true
        drawIndirectCount                                  = true
        shaderInt8                                         = true
        descriptorIndexing                                 = true
        samplerFilterMinmax                                = false
        vulkanMemoryModel                                  = true
        vulkanMemoryModelDeviceScope                       = true
        vulkanMemoryModelAvailabilityVisibilityChains      = true
        shaderOutputViewportIndex                          = false
        shaderOutputLayer                                  = false
        subgroupBroadcastDynamicId                         = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
        ycbcrImageArrays = true
Found no “Sync to Vblank”
Screenshot_20200917_232106 Screenshot_20200917_232303
That is just an info app. You can’t make any changes with that. First type in the following in terminal to see which gpu is active. The one with ‘controller’ at the end will be the active one.
lspci -vnnn | perl -lne 'print if /^\d+\:.+(\[\S+\:\S+\])/' | grep VGA
So you must be running a laptop with hybrid graphics. Intel i915 and Nvidia GeForce 940 Mobile. It looks to me like you are basically running on Intel graphics and nouveau is loaded for the Nvidia although it doesn’t look like you have the hybrid graphics set up to switch back and forth. Do you get any other graphics anomalies of the flickering besides the right click?
$ lspci -vnnn | perl -lne 'print if /^\d+\:.+(\[\S+\:\S+\])/' | grep VGA
00:02.0 VGA compatible controller [0300]: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller [8086:0416] (rev 06) (prog-if 00 [VGA controller])
It just show intel control. Didn’t show nvidia controller. I wonder what does that mean ?
No, no other glitches nor flicker ever noticed.
Darn it, so my laptop does not have dedicated nvidia 940m… got tricked… i thought it is a dedicated graphic laptop.
Do you think it could be dual graphic card (nvidia and onboard intel) ? So the os can be set to choose one graphic card that work best ? :upside_down_face:
You should try the method above that @RodneyCK posted and see if it solves the problem first.
Edit: https://wiki.archlinux.org/index.php/intel_graphics#Troubleshooting
Then that means you using strickly open-sourse Intel GPU drivers. You would have to reconfigure your setup and again, I am not the one to ask about hybrid setups. I would refer you to;
Here for hybrid setup or look on the forum.
Here for strictly Nvidia driver setup.
I think properly setting up your drivers will fix your flicker issue.
@andrew_ysk
If you want to run a test. Show the output of this.
nvidia-installer-dkms -b -t
What can be learn from this log ?
I have no idea what i am looking at. Just know it is a test installation of Nvidia driver..
$ nvidia-installer-dkms -b -t
2020-09-18 21:18:34 [INFO]: EndeavourOS Nvidia Installer v3.3.8
2020-09-18 21:18:34 [INFO]: All logs will be stored in /tmp/nvidia-installer.log
2020-09-18 21:18:34 [INFO]: Running the installer in testing mode...
2020-09-18 21:18:34 [INFO]: Updating Nvidia graphics cards database...
2020-09-18 21:18:34 [INFO]: nvidia-installer-update-db --tmpdb
Fetching NVIDIA graphics card ids from nvidia.com ...
Adding NVIDIA graphics card ids to a temporary local database.
2020-09-18 21:18:36 [INFO]: Installing bumblebee driver...
2020-09-18 21:18:36 [INFO]: Removing conflicting packages...
2020-09-18 21:18:36 [INFO]: Downloading and installing driver packages, please wait as this may take a few minutes...
2020-09-18 21:18:36 [INFO]: pacman -Sqy --noconfirm --noprogressbar bumblebee mesa xf86-video-intel nvidia-dkms virtualgl nvidia-settings bbswitch-dkms lib32-nvidia-utils lib32-virtualgl lib32-mesa
2020-09-18 21:18:36 [INFO]: Adding user enos-andrew to bumblebee group...
2020-09-18 21:18:36 [INFO]: gpasswd -a enos-andrew bumblebee
2020-09-18 21:18:36 [INFO]: Adding user enos-andrew to video group...
2020-09-18 21:18:36 [INFO]: gpasswd -a enos-andrew video
2020-09-18 21:18:36 [INFO]: Patching /usr/share/applications/nvidia-settings.desktop...
2020-09-18 21:18:36 [INFO]: /usr/bin/sed -i s|Exec=/usr/bin/nvidia-settings|Exec=optirun -b none /usr/bin/nvidia-settings -c :8| /usr/share/applications/nvidia-settings.desktop
2020-09-18 21:18:36 [INFO]: /etc/X11/xorg.conf.d/20-nvidia.conf not found. That's ok.
2020-09-18 21:18:36 [INFO]: Installation finished. Nothing has been modified as testing mode was ON.
So it looks like the test runs okay for installing the nvidia-dkms with bumblebee. But I’m not an expert on the hybrid set up. So you can have it with just bumblebee or you can set it up with optimus which I think most do. I think you are on KDE plasma? So this was just a test install to see if there are any errors. There are other steps first of all to install it. Then if that goes okay then there are more steps to install optimus. My concern is you don’t have enough experience and if it goes wrong? Everything doesn’t always go right so I need to think about a few things. I’m also not sure how you want to use the laptop. Do you understand the hybrid graphics and it’s use and purpose? You should read up on it a bit. The idea is to be able to switch back & forth between Nvidia and intel. Nvidia is better graphics all around & for gaming but uses more power. Just giving you information for now.
