Hi, I was looking to set my regional/language setting in System Settings, but could not find it there. I have seen threads by other users who do have that section in their systems, but I think it is specific to a desktop environment you use? Because I saw the section visible in e.g. KDE Plasma.
At first I thought this may have been caused by the fact that I use Hyprland with my EndeavourOS installation, but then I checked System Settings via Cinnamon on my laptop, and the section is missing there too.
When I check language settings in Firefox, it says my operating system settings are currently set to “English (United States, posix)”, so it must have been set somewhere.
Am I missing something basic? Do I need to install a package to have access to those settings?
Thank you for the reply. I currently do not have KDE Plasma installed, so I’m referring to non-compositor System Settings that open when I search for that in a launcher in Hyprland. Its UI looks like this:
It should be from Cinnamon I think? Because I still have Cinnamon installed alongside Hyprland, and the UI looks similar (identical?) to the Cinnamon System Settings from my laptop.
Oh that looks helpful, I didn’t think of looking it up there, I thought the setting would be available as GUI if everything was working correctly. Thank you, I’m going to look into that now.
