Trying to get my Dell XPS 8700’s Realtek RTS5182 Card Reader to work, as it doesn’t detect any cards put into it
these are the results from lspci
these are the results from lsusb
Not sure if this helps?
https://wiki.archlinux.org/title/Smartcards
No need to be sorry I may be confused with the link i sent you.
Edit: I think it’s correct? Have another look at it.
Note: The package ccid provides a generic USB interface driver for smart card reader. If the smart card at hand is not supported by the generic driver or simply it needs a specific one, feel free to install the best for that device. ![]()
Maybe it’s for smart card access?
So you are right … my link is for access type smart card readers.
It does show the card reader as being detected. So what happens when you try to put a disc in it?
Bus 002 Device 005 ID 0bda:0184 Realtek Semiconductor Corp. RTS5182 Card Reader
When I put a card in, nothing changes. When I was still using Windows a while ago there would be an indicator light, showing that it was reading it, but nothing lights up
Are you dual booting with windows?
No.
Does the device show up in the file manager if you put a card in it?
Edit: I have card readers in my laptops and they work. I can use a program to flash an ISO to them when needed.
Edit: So we are talking about sd card readers. ![]()
PC came with windows, but a few months ago i switched to EOS
No
It doesn’t even show that theres any media
I would check sudo dmesg without a card in it and then with a card put in it. See if it shows anything.
Nothing updates.
So if you put a card in it and run lsblk in the terminal it doesn’t show it?
correct
You may need to see what module it may be using or is supposed to use and remove it and reload it with the proper commands.
Se what it shows with lsmod
Maybe you can determine that. It might be rtsx_pci or something else.
Module Size Used by
sdhci_pci 118784 0
sdhci_uhs2 36864 1 sdhci_pci
sdhci 106496 2 sdhci_uhs2,sdhci_pci
cqhci 45056 1 sdhci_pci
mmc_core 294912 4 sdhci_uhs2,sdhci,cqhci,sdhci_pci
udf 147456 0
crc_itu_t 12288 1 udf
vfat 24576 1
fat 110592 1 vfat
cdc_acm 49152 0
snd_seq_dummy 12288 0
snd_seq_midi 20480 0
snd_hrtimer 12288 1
snd_seq_midi_event 16384 1 snd_seq_midi
snd_seq 131072 9 snd_seq_midi,snd_seq_midi_event,snd_seq_dummy
nft_fib_inet 12288 1
nft_fib_ipv4 12288 1 nft_fib_inet
nft_fib_ipv6 12288 1 nft_fib_inet
nft_fib 12288 3 nft_fib_ipv6,nft_fib_ipv4,nft_fib_inet
nft_reject_inet 12288 10
nf_reject_ipv4 12288 1 nft_reject_inet
nf_reject_ipv6 20480 1 nft_reject_inet
nft_reject 12288 1 nft_reject_inet
nft_ct 28672 8
nft_chain_nat 12288 3
nf_nat 61440 1 nft_chain_nat
nf_conntrack 200704 2 nf_nat,nft_ct
nf_defrag_ipv6 24576 1 nf_conntrack
nf_defrag_ipv4 12288 1 nf_conntrack
nf_tables 389120 256 nft_ct,nft_reject_inet,nft_fib_ipv6,nft_fib_ipv4,nft_chain_nat,nft_reject,nft_fib,nft_fib_inet
libcrc32c 12288 3 nf_conntrack,nf_nat,nf_tables
bnep 36864 2
btusb 77824 0
btrtl 32768 1 btusb
btintel 69632 1 btusb
btbcm 24576 1 btusb
btmtk 32768 1 btusb
bluetooth 1097728 15 btrtl,btmtk,btintel,btbcm,bnep,btusb
snd_usb_audio 557056 0
mousedev 24576 0
snd_usbmidi_lib 49152 1 snd_usb_audio
snd_ump 40960 1 snd_usb_audio
snd_rawmidi 57344 3 snd_seq_midi,snd_usbmidi_lib,snd_ump
snd_seq_device 16384 4 snd_seq,snd_seq_midi,snd_ump,snd_rawmidi
mc 90112 1 snd_usb_audio
snd_hda_codec_realtek 212992 1
snd_hda_codec_hdmi 98304 1
snd_hda_codec_generic 114688 1 snd_hda_codec_realtek
intel_rapl_msr 20480 0
intel_rapl_common 53248 1 intel_rapl_msr
snd_hda_scodec_component 20480 1 snd_hda_codec_realtek
snd_hda_intel 65536 4
x86_pkg_temp_thermal 16384 0
intel_powerclamp 20480 0
coretemp 20480 0
snd_intel_dspcfg 40960 1 snd_hda_intel
snd_intel_sdw_acpi 16384 1 snd_intel_dspcfg
snd_hda_codec 212992 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
kvm_intel 425984 0
snd_hda_core 147456 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
kvm 1384448 1 kvm_intel
snd_hwdep 20480 2 snd_usb_audio,snd_hda_codec
snd_pcm 200704 6 snd_hda_codec_hdmi,snd_hda_intel,snd_usb_audio,snd_hda_codec,snd_hda_core
spi_nor 167936 0
snd_timer 57344 3 snd_seq,snd_hrtimer,snd_pcm
r8169 126976 0
mtd 110592 3 spi_nor
at24 28672 0
i2c_i801 45056 0
i2c_smbus 20480 1 i2c_i801
i2c_mux 16384 1 i2c_i801
spi_intel_platform 12288 0
snd 155648 23 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_usb_audio,snd_usbmidi_lib,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_ump,snd_pcm,snd_rawmidi
realtek 45056 1
soundcore 16384 1 snd
iTCO_wdt 16384 0
mdio_devres 12288 1 r8169
intel_pmc_bxt 16384 1 iTCO_wdt
iTCO_vendor_support 12288 1 iTCO_wdt
spi_intel 36864 1 spi_intel_platform
libphy 229376 3 r8169,mdio_devres,realtek
dell_pc 12288 0
mei_pxp 20480 0
dell_smbios 36864 1 dell_pc
dell_wmi_descriptor 20480 1 dell_smbios
mei_hdcp 28672 0
platform_profile 12288 1 dell_pc
mei_me 57344 2
dcdbas 20480 1 dell_smbios
lpc_ich 32768 0
dell_smm_hwmon 28672 0
mei 204800 5 mei_hdcp,mei_pxp,mei_me
rapl 20480 0
intel_cstate 20480 0
intel_uncore 266240 0
pcspkr 12288 0
mac_hid 12288 0
dm_mod 225280 0
loop 45056 3
nfnetlink 20480 3 nf_tables
ip_tables 36864 0
x_tables 65536 1 ip_tables
8821au 3461120 0
pkcs8_key_parser 12288 0
ums_realtek 24576 0
hid_generic 12288 0
uas 36864 0
usb_storage 90112 5 uas,ums_realtek
usbhid 86016 0
nvidia_uvm 3878912 0
nvidia_drm 135168 10
nvidia_modeset 1822720 23 nvidia_drm
ext4 1155072 1
crc32c_generic 12288 0
crc16 12288 2 bluetooth,ext4
mbcache 16384 1 ext4
jbd2 208896 1 ext4
nvidia 96903168 304 nvidia_uvm,nvidia_modeset
crct10dif_pclmul 12288 1
crc32_pclmul 12288 0
crc32c_intel 12288 3
wl 6516736 0
polyval_clmulni 12288 0
polyval_generic 12288 1 polyval_clmulni
ghash_clmulni_intel 16384 0
sha512_ssse3 49152 0
sha256_ssse3 36864 0
sha1_ssse3 32768 0
aesni_intel 122880 0
cfg80211 1392640 2 wl,8821au
gf128mul 16384 2 polyval_generic,aesni_intel
sr_mod 28672 0
crypto_simd 16384 1 aesni_intel
drm_ttm_helper 16384 2 nvidia_drm
cdrom 81920 2 udf,sr_mod
cryptd 28672 2 crypto_simd,ghash_clmulni_intel
ttm 106496 1 drm_ttm_helper
rfkill 40960 6 bluetooth,cfg80211
video 81920 1 nvidia_modeset
wmi 32768 4 video,dell_smm_hwmon,dell_smbios,dell_wmi_descriptor
sg 53248 0
crypto_user 20480 0
