Not sure what you mean with that.
Use akm which is a package to install kernels.
sudo pacman -S akm
Then it will be in installed and you can install the lts kernel with headers. Reboot and see.
Is it finished? It doesn’t say it’s done.
[orbital@orbital-m32cd ~]$ sudo pacman -S akm
[sudo] password for orbital:
resolving dependencies...
Package (1) New Version Net Change Download Size
endeavouros/akm 2.9.4-1 0,02 MiB 0,02 MiB
Total Download Size: 0,02 MiB
Total Installed Size: 0,02 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
akm-2.9.4-1-any 19,0 KiB 52,5 KiB/s 00:00 [--------------------------------] 100%
(1/1) checking keys in keyring [--------------------------------] 100%
(1/1) checking package integrity [--------------------------------] 100%
(1/1) loading package files [--------------------------------] 100%
(1/1) checking for file conflicts [--------------------------------] 100%
:: Processing package changes...
(1/1) installing akm [--------------------------------] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating the desktop file MIME type cache...
So now go to the menu and find akm and launch it. Then install the lts kernel and headers and reboot after into the lts kernel.
These two options?
Yes…
The network device doesn’t show up - this is not a firewall issue.
After installing the AUR DKMS package,
the device is now showing up.
That window shows connections you have created. It does not show available access points.
That’s a different menu entirely - that’s the Network Manager system tray icon.
Also check the output of
rfkill list
/usr/bin/pacman -S core/linux-lts core/linux-lts-headers ;
Root Password:
Package (2) New Version Net Change Download Size
core/linux-lts 5.15.35-1 128,78 MiB 128,67 MiB
core/linux-lts-headers 5.15.35-1 137,20 MiB 24,84 MiB
Total Download Size: 153,52 MiB
Total Installed Size: 265,98 MiB
linux-lts-headers-5.15.35-... 24,8 MiB 2,83 MiB/s 00:09 [--------------------------------] 100%
linux-lts-5.15.35-1-x86_64 128,7 MiB 3,05 MiB/s 00:42 [--------------------------------] 100%
Total (2/2) 153,5 MiB 3,64 MiB/s 00:42 [--------------------------------] 100%
(2/2) checking keys in keyring [--------------------------------] 100%
(2/2) checking package integrity [--------------------------------] 100%
(2/2) loading package files [--------------------------------] 100%
(2/2) checking for file conflicts [--------------------------------] 100%
(1/2) installing linux-lts [--------------------------------] 100%
Optional dependencies for linux-lts
wireless-regdb: to set the correct wireless channels of your country [installed]
linux-firmware: firmware images needed for some devices [installed]
(2/2) installing linux-lts-headers [--------------------------------] 100%
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Install DKMS modules
==> dkms install --no-depmod rtl8822bu/20180723 -k 5.15.35-1-lts
Error! Bad return status for module build on kernel: 5.15.35-1-lts (x86_64)
Consult /var/lib/dkms/rtl8822bu/20180723/build/make.log for more information.
==> WARNING: `dkms install --no-depmod rtl8822bu/20180723 -k 5.15.35-1-lts' exited 10
==> dkms install --no-depmod rtl8822bu/5.8.7.4 -k 5.15.35-1-lts
Deprecated feature: REMAKE_INITRD
Consult /var/lib/dkms/rtl8822bu/5.8.7.4/build/make.log for more information.
==> WARNING: `dkms install --no-depmod rtl8822bu/5.8.7.4 -k 5.15.35-1-lts' exited 10
==> dkms install --no-depmod rtl88x2bu/5.13.1.r158.a543f24 -k 5.15.35-1-lts
==> depmod 5.15.35-1-lts
(4/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-lts.preset: 'default'
-> -k /boot/vmlinuz-linux-lts -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-lts.img
==> Starting build: 5.15.35-1-lts
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [filesystems]
-> Running build hook: [fsck]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-lts.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux-lts.preset: 'fallback'
-> -k /boot/vmlinuz-linux-lts -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-lts-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: wd719x
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qed
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-lts-fallback.img
(5/5) Update grub after installing or removing a kernel or microcode.
Generating grub configuration file ...
Found theme: /boot/grub/themes/EndeavourOS/theme.txt
Found linux image: /boot/vmlinuz-linux-lts
Found initrd image: /boot/initramfs-linux-lts.img
Found fallback initrd image(s) in /boot: initramfs-linux-lts-fallback.img
Found initrd image: /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot: initramfs-linux-fallback.img
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
Adding boot menu entry for UEFI Firmware Settings ...
done
[orbital@orbital-m32cd ~]$ rfkill list
1: phy1: Wireless LAN
Soft blocked: no
Hard blocked: no
Do you have the usb plugged into a 3.0 port?
USB 3.0 Support
You can try use modprobe 88x2bu rtw_switch_usb_mode=1
to force the adapter run under USB 3.0. But if your adapter/port/motherboard not support it, the driver will be in restart loop. Remove the parameter and reload the driver to restore. Alternatively, modprobe 88x2bu rtw_switch_usb_mode=2
let’s it run as USB 2 device.
Notice: If you had already loaded the moduel, use modprobe -r 88x2bu
to unload it first.
If you want to force a given mode permanently (even when switching the adapter across devices), create the file /etc/modprobe.d/99-RTL88x2BU.conf
with the following content: options 88x2bu rtw_switch_usb_mode=1
This means wifi should be working. It is detected and available.
What does this log file contain?
How do I check that for you?
This happened before on the regular kernel?
I will put the Wifi Adapter to another USB Port and see if it works.
Open the file and look at it.
Which bit? The build failure? In which case something isn’t working correctly - maybe 5.17 has added support for the 8822BU so there’s partial support?
[Folder 1]
[Folder 2]
This was in the log above?
Creating symlink /var/lib/dkms/rtl8822bu/20180723/source -> /usr/src/rtl8822bu-20180723
Error! Your kernel headers for kernel 5.17.3-arch1-1 cannot be found at /usr/lib/modules/5.17.3-arch1-1/build or /usr/lib/modules/5.17.3-arch1-1/source.
Please install the linux-headers-5.17.3-arch1-1 package or use the --kernelsourcedir option to tell DKMS where it's located.
error: command failed to execute correctly
(1/3) Arming ConditionNeedsUpdate...
(2/3) Install DKMS modules
==> dkms install --no-depmod rtl8822bu/20180723 -k 5.17.4-arch1-1
Error! Bad return status for module build on kernel: 5.17.4-arch1-1 (x86_64)
==> WARNING: `dkms install --no-depmod rtl8822bu/20180723 -k 5.17.4-arch1-1' exited 10
(3/3) Checking which packages need to be rebuilt
That’s a screenshot of a directory, not the contents of the log file.
You want to see this?
DKMS make.log for rtl8822bu-20180723 for kernel 5.15.35-1-lts (x86_64)
Do 21. Apr 17:38:08 CEST 2022
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/5.15.35-1-lts/build M=/var/lib/dkms/rtl8822bu/20180723/build modules
make[1]: Entering directory '/usr/lib/modules/5.15.35-1-lts/build'
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_cmd.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_security.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_debug.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_io.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_ioctl_query.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_ioctl_set.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_ieee80211.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_mlme.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_mlme_ext.o
/var/lib/dkms/rtl8822bu/20180723/build/core/rtw_mlme_ext.c: In function ‘mgt_dispatcher’:
/var/lib/dkms/rtl8822bu/20180723/build/core/rtw_mlme_ext.c:1828:38: warning: this statement may fall through [-Wimplicit-fallthrough=]
1828 | ptable->func = &OnAuthClient;
/var/lib/dkms/rtl8822bu/20180723/build/core/rtw_mlme_ext.c:1830:9: note: here
1830 | case WIFI_ASSOCREQ:
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_mi.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_wlan_util.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_vht.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_pwrctrl.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_rf.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_recv.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_sta_mgt.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_ap.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/mesh/rtw_mesh.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/mesh/rtw_mesh_pathtbl.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/mesh/rtw_mesh_hwmp.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_xmit.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_p2p.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_rson.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_tdls.o
CC [M] /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_br_ext.o
/var/lib/dkms/rtl8822bu/20180723/build/core/rtw_br_ext.c:20:18: fatal error: net/ipx.h: No such file or directory
20 | #include <net/ipx.h>
compilation terminated.
make[2]: *** [scripts/Makefile.build:277: /var/lib/dkms/rtl8822bu/20180723/build/core/rtw_br_ext.o] Error 1
make[1]: *** [Makefile:1868: /var/lib/dkms/rtl8822bu/20180723/build] Error 2
make[1]: Leaving directory '/usr/lib/modules/5.15.35-1-lts/build'
make: *** [Makefile:2001: modules] Error 2
OK, so this shows that the DKMS module doesn’t work with 5.15 at all, and it also wouldn’t be working with 5.17 either, so it’s a complete “red herring”. Remove it entirely, reboot, and see where things are then.
