[Realtek RTL8812BU] TP-Link Archer T3U Wi-Fi Adapter not working after Apollo Install
Hello, I just installed EndeavourOS Apollo XFCE but my Wifi Adapter (TP-Link Archer T3U AC1300) won’t find anything in the NetworkManager Applet.
I already tried the solution from this Topic Wi-Fi Adapter not working after Atlantis Neo Install which had worked before.
[orbital@orbital-m32cd ~]$ inxi -Fxxxaz
  Kernel: 5.17.3-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-linux
    root=UUID=e6643e06-5081-4c8b-aa87-30eb8eb78491 rw loglevel=3 nowatchdog
    nvme_load=YES
  Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: EndeavourOS base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: M32CD v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 0501
    date: 08/28/2015
  Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
    family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0x23
  Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache:
    L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 900 min/max: 800/4000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
    8: 900 bogomips: 54417
  Vulnerabilities:
  Type: itlb_multihit status: KVM: VMX disabled
  Type: l1tf
    mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
    SMT vulnerable
  Type: spec_store_bypass status: Vulnerable
  Type: spectre_v1
  Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
  Type: srbds status: Vulnerable: No microcode
  Type: tsx_async_abort status: Vulnerable: Clear CPU buffers attempted, no
    microcode; SMT vulnerable
  Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: ASUSTeK driver: nouveau
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-I-1
    bus-ID: 01:00.0 chip-ID: 10de:1401 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver:
    X: loaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nouveau
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22")
    s-diag: 582mm (22.93")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Samsung C27F390
    serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  OpenGL: renderer: NV126 v: 4.3 Mesa 22.0.1 direct render: Yes
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
    class-ID: 0403
  Device-2: NVIDIA GM206 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fba
    class-ID: 0403
  Sound Server-1: ALSA v: k5.17.3-arch1-1 running: yes
  Sound Server-2: PulseAudio v: 15.0 running: no
  Sound Server-3: PipeWire v: 0.3.50 running: yes
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 1.82 TiB used: 7.26 GiB (0.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 033 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
    model: WD Elements 25A2 size: 931.48 GiB block-size: physical: 512 B
    logical: 512 B type: N/A serial: <filter> rev: 1021 scheme: GPT
  ID-1: / raw-size: 931.01 GiB size: 915.32 GiB (98.31%)
    used: 7.26 GiB (0.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
    used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 36.0 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 744
  Processes: 218 Uptime: 38m wakeups: 0 Memory: 15.55 GiB
  used: 1.37 GiB (8.8%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 Packages: pacman: 856 lib: 212 flatpak: 0 Shell: Bash v: 5.1.16
  running-in: xfce4-terminal inxi: 3.3.15
@ricklinux @anon53396576 @pebcak
[orbital@orbital-m32cd ~]$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 2357:012d TP-Link Archer T3U [Realtek RTL8812BU]
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 1058:25a2 Western Digital Technologies, Inc. Elements 25A2
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 046d:c069 Logitech, Inc. M-U0007 [Corded Mouse M500]
Bus 001 Device 003: ID 046d:c31c Logitech, Inc. Keyboard K120
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Did you get any error messages executing yay -S rtl88x2bu-dkms-git?
May I ask why did you do a fresh install?, did you run into troubles with your Atlantis installation?
Have you tried
yay -S rtl8822bu-dkms-git
I tried some other operating systems but at the end endeavour is still my favorite.
[orbital@orbital-m32cd ~]$ yay -S rtl88882bu-dkms-git
 -> Could not find all required packages:
	rtl88882bu-dkms-git (Target)
[orbital@orbital-m32cd ~]$ yay -S rtl8822bu-dkms-git
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:1]  rtl8822bu-dkms-git-20180723-12
  1 rtl8822bu-dkms-git               (Installed) (Build Files Exist)
==> Packages to cleanBuild?
==> A
:: Deleting (1/1): /home/orbital/.cache/yay/rtl8822bu-dkms-git
:: (1/1) Downloaded PKGBUILD: rtl8822bu-dkms-git
==> Diffs to show?
:: (1/1) Parsing SRCINFO: rtl8822bu-dkms-git
==> Making package: rtl8822bu-dkms-git 20180723-12 (Do 21 Apr 2022 12:32:30 CEST)
==> Retrieving sources...
  -> Cloning rtl8822bu git repo...
Cloning into bare repository '/home/orbital/.cache/yay/rtl8822bu-dkms-git/rtl8822bu'...
remote: Enumerating objects: 2348, done.
remote: Counting objects: 100% (11/11), done.
remote: Compressing objects: 100% (11/11), done.
remote: Total 2348 (delta 1), reused 2 (delta 0), pack-reused 2337
Receiving objects: 100% (2348/2348), 8.31 MiB | 4.19 MiB/s, done.
Resolving deltas: 100% (1438/1438), done.
  -> Found dkms.conf
==> Validating source files with sha256sums...
    rtl8822bu ... Skipped
    dkms.conf ... Passed
==> Making package: rtl8822bu-dkms-git 20180723-12 (Do 21 Apr 2022 12:32:34 CEST)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
  -> Updating rtl8822bu git repo...
Fetching origin
  -> Found dkms.conf
==> Removing existing $srcdir/ directory...
==> Extracting sources...
  -> Creating working copy of rtl8822bu git repo...
Cloning into 'rtl8822bu'...
done.
==> Starting prepare()...
==> Sources are ready.
==> Making package: rtl8822bu-dkms-git 20180723-12 (Do 21 Apr 2022 12:32:37 CEST)
==> WARNING: Using existing $srcdir/ tree
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
  -> Removing libtool files...
  -> Purging unwanted files...
  -> Removing static library files...
  -> Stripping unneeded symbols from binaries and libraries...
  -> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "rtl8822bu-dkms-git"...
  -> Generating .PKGINFO file...
  -> Generating .BUILDINFO file...
  -> Adding install file...
  -> Generating .MTREE file...
  -> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: rtl8822bu-dkms-git 20180723-12 (Do 21 Apr 2022 12:32:42 CEST)
==> Cleaning up...
 -> Found git repo: github.com/Mephysto666/rtl8822bu.git
[sudo] password for orbital:
loading packages...
warning: rtl8822bu-dkms-git-20180723-12 is up to date -- reinstalling
resolving dependencies...
Package (1)         Old Version  New Version  Net Change
rtl8822bu-dkms-git  20180723-12  20180723-12    0,00 MiB
Total Installed Size:  22,78 MiB
Net Upgrade Size:       0,00 MiB
:: Proceed with installation? [Y/n]
(1/1) checking keys in keyring                               [--------------------------------] 100%
(1/1) checking package integrity                             [--------------------------------] 100%
(1/1) loading package files                                  [--------------------------------] 100%
(1/1) checking for file conflicts                            [--------------------------------] 100%
:: Running pre-transaction hooks...
(1/1) Remove upgraded DKMS modules
==> dkms remove rtl8822bu/20180723
:: Processing package changes...
Error! The module/version combo: rtl8822bu-20180723 is not located in the DKMS tree.
error: command failed to execute correctly
(1/1) reinstalling rtl8822bu-dkms-git                        [--------------------------------] 100%
Creating symlink /var/lib/dkms/rtl8822bu/20180723/source -> /usr/src/rtl8822bu-20180723
Error! Your kernel headers for kernel 5.17.3-arch1-1 cannot be found at /usr/lib/modules/5.17.3-arch1-1/build or /usr/lib/modules/5.17.3-arch1-1/source.
Please install the linux-headers-5.17.3-arch1-1 package or use the --kernelsourcedir option to tell DKMS where it's located.
(1/3) Arming ConditionNeedsUpdate...
(2/3) Install DKMS modules
==> dkms install --no-depmod rtl8822bu/20180723 -k 5.17.4-arch1-1
Error! Bad return status for module build on kernel: 5.17.4-arch1-1 (x86_64)
Consult /var/lib/dkms/rtl8822bu/20180723/build/make.log for more information.
==> WARNING: `dkms install --no-depmod rtl8822bu/20180723 -k 5.17.4-arch1-1' exited 10
(3/3) Checking which packages need to be rebuilt
so the “atlantis” worked before? Do you still have that on a stick or have a copy of that .iso? If so, just install that and apply the fix you did before as an easy fix. Anything arch based is rolling so both the atlantis and apollo installs will update to the same system in the end, only difference is a couple of thing get automatically installed with apollo like firewalld, and not like firefox etc but any difference can be added/removed after atlantis named .iso.
Disable firwald and see if it works.
Yes the solutions I got from the forum worked on atlantis and I could use wifi connection but I don’t have the old iso anymore.
How do I turn the Firewall off?
Screenshot_2022-04-21_16-18-30
[orbital@orbital-m32cd ~]$ systemctl status firewalld
● firewalld.service - firewalld - dynamic firewall daemon
     Loaded: loaded (/usr/lib/systemd/system/firewalld.service; enabled; vendor preset: disabled)
     Active: active (running) since Thu 2022-04-21 16:14:07 CEST; 14min ago
       Docs: man:firewalld(1)
   Main PID: 404 (firewalld)
      Tasks: 3 (limit: 19093)
     Memory: 50.3M
        CPU: 789ms
     CGroup: /system.slice/firewalld.service
             └─404 /usr/bin/python /usr/bin/firewalld --nofork --nopid
Apr 21 16:14:07 orbital-m32cd systemd[1]: Starting firewalld - dynamic firewall daemon...
Apr 21 16:14:07 orbital-m32cd systemd[1]: Started firewalld - dynamic firewall daemon.
sudo systemctl stop firewalld
sudo systemctl disable firewalld
shouldn't start on next boot, just remove it if you don't want it usual way.
It still doesn’t show me the wireless connections. :thinking:
[orbital@orbital-m32cd ~]$ sudo systemctl disable firrwalld
Failed to disable unit: Unit file firrwalld.service does not exist.
○ firewalld.service - firewalld - dynamic firewall daemon
     Active: inactive (dead) since Thu 2022-04-21 16:32:25 CEST; 1min 27s ago
    Process: 404 ExecStart=/usr/bin/firewalld --nofork --nopid $FIREWALLD_ARGS (code=exited, status>
   Main PID: 404 (code=exited, status=0/SUCCESS)
        CPU: 830ms
you spell " firewalld " wrong
There is a new kernel now? So have you updated because the error showed no headers?
How do I update the Kernel?
You said the atlantis point release .iso worked for you and you could fix it from there? Is that not so then? (apollo installs firewalld by default, not atlantis, so you haven’t the atlantis .iso around?..)
Standard updating! What kernel is installed?
uname -a
What does your network show?
inxi -Na
Upadate now
sudo pacman -Syu
back then this was the solution:
and then everything worked.
[orbital@orbital-m32cd ~]$ uname -a
Linux orbital-m32cd 5.17.4-arch1-1 #1 SMP PREEMPT Wed, 20 Apr 2022 18:29:28 +0000 x86_64 GNU/Linux
[orbital@orbital-m32cd ~]$ inxi -Na
    vendor: ASUSTeK driver: r8168 v: 8.049.02-NAPI modules: r8169 pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Device-2: TP-Link Archer T3U [Realtek RTL8812BU] type: USB
    driver: rtl88x2bu bus-ID: 3-2:2 chip-ID: 2357:012d class-ID: 0000
    serial: 123456
[orbital@orbital-m32cd ~]$ sudo pacman -Syu
 core                            158,2 KiB   396 KiB/s 00:00 [--------------------------------] 100%
 extra                          1704,0 KiB  1535 KiB/s 00:01 [--------------------------------] 100%
 community                         6,6 MiB  2,78 MiB/s 00:02 [--------------------------------] 100%
 multilib is up to date
 endeavouros                      31,8 KiB  46,2 KiB/s 00:01 [--------------------------------] 100%
Package (1)                  Old Version  New Version  Net Change  Download Size
endeavouros/eos-bash-shared  1.10.41-1    1.10.42-1      0,00 MiB       0,04 MiB
Total Download Size:   0,04 MiB
Total Installed Size:  0,09 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
 eos-bash-shared-1.10.42-1-any    39,8 KiB   299 KiB/s 00:00 [--------------------------------] 100%
(1/1) upgrading eos-bash-shared                              [--------------------------------] 100%
(2/3) Checking which packages need to be rebuilt
(3/3) Updating the desktop file MIME type cache...
[orbital@orbital-m32cd ~]$ ^C
 core is up to date
 extra is up to date
 community is up to date
 endeavouros is up to date
 there is nothing to do
