Everything looks correct. I forgot it was a usb. So is it now working?
Module is loaded so not sure what the problem is?
[Apollo] Now it looks like this. Not showing any wireless connections.
[Artlantis neo] Last time after we’ve found the solution it looked like this:
Click on auto ethernet?
I have the same thing not sure what you are showing? So the connection is there?
Maybe because wlan state is down ?
Device-2: TP-Link Archer T3U [Realtek RTL8812BU] type: USB
driver: rtl88x2bu bus-ID: 3-2:3 chip-ID: 2357:012d class-ID: 0000
serial: <filter>
Right now I have internet with my ethernet cable.
I just noticed it doesn’t have anything in the box under device.
Example:
I was wondering why you were showing me this? That’s the ethernet…
Edit: So if you left click on the network icon it doesn’t show you anything for the WiFi?
I didn’t knew what auto ethernet was so I thought I show you a picture of the settings. Sorry.
Yes I can actually pick a device but it doesn’t change anything once I save the settings.
No it doesn’t show me wireless connections like in your picture.
So you installed
yay - S rtl88x2bu-dkms-git
I think so:
[orbital@orbital-m32cd ~]$ yay -S rtl88x2bu-dkms-git
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:1] rtl88x2bu-dkms-git-5.13.1.r149.7f96b19-1
1 rtl88x2bu-dkms-git (Installed) (Build Files Exist)
==> Packages to cleanBuild?
==> A
:: Deleting (1/1): /home/orbital/.cache/yay/rtl88x2bu-dkms-git
:: (1/1) Downloaded PKGBUILD: rtl88x2bu-dkms-git
==> Diffs to show?
:: (1/1) Parsing SRCINFO: rtl88x2bu-dkms-git
==> Making package: rtl88x2bu-dkms-git 5.13.1.r149.7f96b19-1 (Do 21 Apr 2022 17:13:48 CEST)
==> Retrieving sources...
-> Cloning RTL88x2BU-Linux-Driver git repo...
Cloning into bare repository '/home/orbital/.cache/yay/rtl88x2bu-dkms-git/RTL88x2BU-Linux-Driver'...
remote: Enumerating objects: 2681, done.
remote: Counting objects: 100% (1311/1311), done.
remote: Compressing objects: 100% (801/801), done.
remote: Total 2681 (delta 747), reused 809 (delta 503), pack-reused 1370
Receiving objects: 100% (2681/2681), 10.50 MiB | 2.02 MiB/s, done.
Resolving deltas: 100% (1523/1523), done.
==> Validating source files with sha256sums...
RTL88x2BU-Linux-Driver ... Skipped
==> Making package: rtl88x2bu-dkms-git 5.13.1.r149.7f96b19-1 (Do 21 Apr 2022 17:13:57 CEST)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
-> Updating RTL88x2BU-Linux-Driver git repo...
Fetching origin
==> Removing existing $srcdir/ directory...
==> Extracting sources...
-> Creating working copy of RTL88x2BU-Linux-Driver git repo...
Cloning into 'RTL88x2BU-Linux-Driver'...
done.
==> Starting pkgver()...
==> Updated version: rtl88x2bu-dkms-git 5.13.1.r158.a543f24-1
==> Sources are ready.
==> Making package: rtl88x2bu-dkms-git 5.13.1.r158.a543f24-1 (Do 21 Apr 2022 17:14:02 CEST)
==> WARNING: Using existing $srcdir/ tree
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "rtl88x2bu-dkms-git"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: rtl88x2bu-dkms-git 5.13.1.r158.a543f24-1 (Do 21 Apr 2022 17:14:07 CEST)
==> Cleaning up...
-> Found git repo: github.com/RinCat/RTL88x2BU-Linux-Driver.git
[sudo] password for orbital:
loading packages...
warning: rtl88x2bu-dkms-git-5.13.1.r158.a543f24-1 is up to date -- reinstalling
resolving dependencies...
Package (1) Old Version New Version Net Change
rtl88x2bu-dkms-git 5.13.1.r158.a543f24-1 5.13.1.r158.a543f24-1 0,00 MiB
Total Installed Size: 27,26 MiB
Net Upgrade Size: 0,00 MiB
:: Proceed with installation? [Y/n]
(1/1) checking keys in keyring [--------------------------------] 100%
(1/1) checking package integrity [--------------------------------] 100%
(1/1) loading package files [--------------------------------] 100%
(1/1) checking for file conflicts [--------------------------------] 100%
:: Running pre-transaction hooks...
(1/1) Remove upgraded DKMS modules
==> dkms remove --no-depmod rtl88x2bu/5.13.1.r158.a543f24 -k 5.17.4-arch1-1
:: Processing package changes...
(1/1) reinstalling rtl88x2bu-dkms-git [--------------------------------] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Install DKMS modules
==> dkms install --no-depmod rtl88x2bu/5.13.1.r158.a543f24 -k 5.17.4-arch1-1
==> depmod 5.17.4-arch1-1
(3/3) Checking which packages need to be rebuilt
Did you just reinstall it?
Yes.
Still nothing?
Still no wifi connections.
Well the module shows it’s there so I don’t know. Have you tried the lts kernel with lts headers?
