First of all, thank you very much for your responses. I really appreciate it.
@FLVAL
I used the version which was aviable in November 2019. XFCE and my Laptop was connected to the internet while the install.
manuel
Thanks
I will try your suggestion.
@ricklinux
I start off with the logs of the commands/links you provided me:
inxi -Fxxxc0
Summary
Host: salva-pc Kernel: 5.4.11-arch1-1 x86_64 bits: 64 compiler: gcc
v: 9.2.0 Desktop: Xfce 4.14.2 tk: Gtk 3.24.13 wm: xfwm4 dm: LightDM
Distro: EndeavourOS
Type: Laptop System: Acer product: Aspire ES1-131 v: V1.22
serial:
Mobo: Acer model: Garp_BA v: V1.22 serial:
UEFI [Legacy]: Insyde v: 1.22 date: 12/24/2015
Battery:
ID-1: BAT1 charge: 25.5 Wh condition: 25.5/38.5 Wh (66%) volts: 13.1/11.6
model: SANYO AC14B13J serial: 4442 status: Full
Topology: Quad Core model: Intel Pentium N3700 bits: 64 type: MCP
arch: Airmont rev: 3 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12805
Speed: 480 MHz min/max: 480/2400 MHz Core speeds (MHz): 1: 674 2: 697
3: 1396 4: 1085
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
Integrated Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:22b1
Display: x11 server: X.Org 1.20.6 driver: intel
unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:2284
Sound Server: ALSA v: k5.4.11-arch1-1
Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel port: 2040 bus ID: 02:00.0
chip ID: 168c:0036
IF: wlan0 state: down mac: 82:f3:a5:5c:56:b7
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 1000
bus ID: 03:00.0 chip ID: 10ec:8168
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: 54
3a:5e:e1:d7
Device-3: Lite-On Qualcomm Atheros Bluetooth type: USB driver: btusb
bus ID: 1-5:5 chip ID: 04ca:3014
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Local Storage: total: 465.76 GiB used: 24.36 GiB (5.2%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
speed: 6.0 Gb/s serial: 36ACWX0MT
ID-1: / size: 447.84 GiB used: 24.36 GiB (5.4%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 178 Uptime: 3h 22m Memory: 3.77 GiB used: 1.44 GiB (38.2%)
Init: systemd v: 244 Compilers: gcc: 9.2.0 Shell: bash v: 5.0.11
running in: xfce4-terminal inxi: 3.0.37
dmesg -rl warn,err,crit
Summary
<4>[ 0.640531] ENERGY_PERF_BIAS: Set to ‘normal’, was ‘performance’
<3>[ 1.783242] dw_dmac INTL9C60:01: Missing DT data
<4>[ 3.638470] usb 1-5: config 1 interface 1 altsetting 0 endpoint 0x83 has wMaxPacketSize 0, skipping
<4>[ 3.638479] usb 1-5: config 1 interface 1 altsetting 0 endpoint 0x3 has wMaxPacketSize 0, skipping
<3>[ 18.905544] intel-spi intel-spi: error -22 reading CR
<3>[ 18.905548] intel-spi intel-spi: error while reading configuration register
<3>[ 18.905550] intel-spi intel-spi: fail to clear block protection bits
<4>[ 18.905569] intel-spi: probe of intel-spi failed with error -22
<4>[ 19.299503] r8169 0000:03:00.0: can’t disable ASPM; OS doesn’t have ASPM control
<4>[ 21.478294] wl: loading out-of-tree module taints kernel.
<4>[ 21.478306] wl: module license ‘MIXED/Proprietary’ taints kernel.
<4>[ 21.478308] Disabling lock debugging due to kernel taint
<4>[ 21.761890] uvcvideo 1-4:1.0: Entity type for entity Extension 4 was not initialized!
<4>[ 21.761901] uvcvideo 1-4:1.0: Entity type for entity Extension 7 was not initialized!
<4>[ 21.761908] uvcvideo 1-4:1.0: Entity type for entity Processing 2 was not initialized!
<4>[ 21.761915] uvcvideo 1-4:1.0: Entity type for entity Camera 1 was not initialized!
<4>[ 24.903230] kauditd_printk_skb: 1 callbacks suppressed
<4>[ 32.215412] usb 1-5: config 1 interface 1 altsetting 0 endpoint 0x83 has wMaxPacketSize 0, skipping
<4>[ 32.215431] usb 1-5: config 1 interface 1 altsetting 0 endpoint 0x3 has wMaxPacketSize 0, skipping
<4>[ 37.915844] kauditd_printk_skb: 4 callbacks suppressed
/var/log/lightdm/lightdm.log
Summary
[+0.03s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.03s] DEBUG: Starting Light Display Manager 1.30.0, UID=0 PID=657
[+0.03s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
[+0.03s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.03s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.03s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.03s] DEBUG: Registered seat module local
[+0.03s] DEBUG: Registered seat module xremote
[+0.03s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.03s] DEBUG: _g_io_module_get_default: Found default implementation local (GLocalVfs) for ‘gio-vfs’
[+0.35s] DEBUG: Monitoring logind for seats
[+0.35s] DEBUG: New seat added from logind: seat0
[+0.35s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.35s] DEBUG: Seat seat0: Starting
[+0.35s] DEBUG: Seat seat0: Creating user session
[+3.38s] DEBUG: Loading users from org.freedesktop.Accounts
[+3.38s] DEBUG: User /org/freedesktop/Accounts/User1000 added
[+3.62s] DEBUG: Seat seat0: Creating display server of type x
[+3.62s] DEBUG: posix_spawn avoided (fd close requested)
[+3.63s] DEBUG: Could not run plymouth --ping: Failed to execute child process “plymouth” (No such file or directory)
[+3.63s] DEBUG: Using VT 7
[+3.63s] DEBUG: Seat seat0: Starting local X display on VT 7
[+3.63s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+3.63s] DEBUG: XServer 0: Writing X server authority to /run/lightdm/root/:0
[+3.63s] DEBUG: XServer 0: Launching X Server
[+3.64s] DEBUG: Launching process 766: /usr/bin/X :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+3.64s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+3.64s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+3.64s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+7.84s] DEBUG: Got signal 10 from process 766
[+7.84s] DEBUG: XServer 0: Got signal from X server :0
[+7.84s] DEBUG: XServer 0: Connecting to XServer :0
[+7.93s] DEBUG: posix_spawn avoided (fd close requested) (child_setup specified)
[+7.93s] DEBUG: Seat seat0: Display server ready, starting session authentication
[+7.93s] DEBUG: Session pid=848: Started with service ‘lightdm-autologin’, username ‘salva’
[+8.18s] DEBUG: Session pid=848: Authentication complete with return value 0: Success
[+8.18s] DEBUG: Seat seat0: Session authenticated, running command
[+8.18s] DEBUG: Registering session with bus path /org/freedesktop/DisplayManager/Session0
[+8.18s] DEBUG: posix_spawn avoided (fd close requested) (child_setup specified)
[+8.19s] DEBUG: Session pid=848: Running command /etc/lightdm/Xsession startxfce4
[+8.19s] DEBUG: Creating shared data directory /var/lib/lightdm-data/salva
[+8.19s] DEBUG: Session pid=848: Logging to .xsession-errors
[+9.35s] DEBUG: Activating VT 7
[+9.35s] DEBUG: Activating login1 session 1
[+9.36s] DEBUG: Seat seat0 changes active session to 1
[+9.36s] DEBUG: Session 1 is already active
journalctl -b -0 > /tmp/journal
Summary
an 15 17:40:32 salva-pc kernel: Linux version 5.4.11-arch1-1 (linux@archlinux) (gcc version 9.2.0 (GCC)) #1 SMP PREEMPT Sun, 12 Jan 2020 12:15:27 +0000
Jan 15 17:40:32 salva-pc kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=26117b2a-a5a3-41bf-be75-0638cf60acf3 rw quiet loglevel=3
Jan 15 17:40:32 salva-pc kernel: KERNEL supported cpus:
Jan 15 17:40:32 salva-pc kernel: Intel GenuineIntel
Jan 15 17:40:32 salva-pc kernel: AMD AuthenticAMD
Jan 15 17:40:32 salva-pc kernel: Hygon HygonGenuine
Jan 15 17:40:32 salva-pc kernel: Centaur CentaurHauls
Jan 15 17:40:32 salva-pc kernel: zhaoxin Shanghai
Jan 15 17:40:32 salva-pc kernel: x86/fpu: x87 FPU will use FXSAVE
Jan 15 17:40:32 salva-pc kernel: BIOS-provided physical RAM map:
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009e7ff] usable
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x000000000009e800-0x000000000009ffff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x0000000020200000-0x0000000074a01fff] usable
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x0000000074a02000-0x0000000074a81fff] ACPI NVS
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x0000000074a82000-0x000000007a181fff] usable
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x000000007a182000-0x000000007a581fff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x000000007a582000-0x000000007a681fff] ACPI NVS
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x000000007a682000-0x000000007a6c1fff] ACPI data
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x000000007a6c2000-0x000000007b485fff] usable
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x000000007b486000-0x000000007bd85fff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x000000007bd86000-0x000000007bffffff] usable
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x000000007c400000-0x000000007fffffff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000e3ffffff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x00000000fea00000-0x00000000feafffff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x00000000fed01000-0x00000000fed01fff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x00000000fed03000-0x00000000fed03fff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x00000000fed08000-0x00000000fed09fff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1cfff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fedbffff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x00000000ffc00000-0x00000000ffffffff] reserved
Jan 15 17:40:32 salva-pc kernel: BIOS-e820: [mem 0x0000000100000000-0x000000017fffffff] usable
Jan 15 17:40:32 salva-pc kernel: NX (Execute Disable) protection: active
Jan 15 17:40:32 salva-pc kernel: SMBIOS 2.8 present.
Jan 15 17:40:32 salva-pc kernel: DMI: Acer Aspire ES1-131/Garp_BA, BIOS V1.22 12/24/2015
Jan 15 17:40:32 salva-pc kernel: tsc: Detected 1600.000 MHz processor
Jan 15 17:40:32 salva-pc kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Jan 15 17:40:32 salva-pc kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Jan 15 17:40:32 salva-pc kernel: last_pfn = 0x180000 max_arch_pfn = 0x400000000
Jan 15 17:40:32 salva-pc kernel: MTRR default type: uncachable
Jan 15 17:40:32 salva-pc kernel: MTRR fixed ranges enabled:
Jan 15 17:40:32 salva-pc kernel: 00000-9FFFF write-back
Jan 15 17:40:32 salva-pc kernel: A0000-BFFFF uncachable
Jan 15 17:40:32 salva-pc kernel: C0000-FFFFF write-protect
Jan 15 17:40:32 salva-pc kernel: MTRR variable ranges enabled:
Jan 15 17:40:32 salva-pc kernel: 0 base 0FFC00000 mask FFFC00000 write-protect
Jan 15 17:40:32 salva-pc kernel: 1 base 000000000 mask F80000000 write-back
Jan 15 17:40:32 salva-pc kernel: 2 base 07E000000 mask FFE000000 uncachable
Jan 15 17:40:32 salva-pc kernel: 3 base 07D000000 mask FFF000000 uncachable
Jan 15 17:40:32 salva-pc kernel: 4 base 07C800000 mask FFF800000 uncachable
Jan 15 17:40:32 salva-pc kernel: 5 base 07C400000 mask FFFC00000 uncachable
Jan 15 17:40:32 salva-pc kernel: 6 base 100000000 mask F80000000 write-back
Jan 15 17:40:32 salva-pc kernel: 7 disabled
Jan 15 17:40:32 salva-pc kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
Jan 15 17:40:32 salva-pc kernel: last_pfn = 0x7c000 max_arch_pfn = 0x400000000
Jan 15 17:40:32 salva-pc kernel: check: Scanning 1 areas for low memory corruption
Jan 15 17:40:32 salva-pc kernel: BRK [0x112801000, 0x112801fff] PGTABLE
Jan 15 17:40:32 salva-pc kernel: BRK [0x112802000, 0x112802fff] PGTABLE
Jan 15 17:40:32 salva-pc kernel: BRK [0x112803000, 0x112803fff] PGTABLE
Jan 15 17:40:32 salva-pc kernel: BRK [0x112804000, 0x112804fff] PGTABLE
Jan 15 17:40:32 salva-pc kernel: BRK [0x112805000, 0x112805fff] PGTABLE
Jan 15 17:40:32 salva-pc kernel: BRK [0x112806000, 0x112806fff] PGTABLE
Jan 15 17:40:32 salva-pc kernel: BRK [0x112807000, 0x112807fff] PGTABLE
Jan 15 17:40:32 salva-pc kernel: BRK [0x112808000, 0x112808fff] PGTABLE
Jan 15 17:40:32 salva-pc kernel: BRK [0x112809000, 0x112809fff] PGTABLE
Jan 15 17:40:32 salva-pc kernel: BRK [0x11280a000, 0x11280afff] PGTABLE
Jan 15 17:40:32 salva-pc kernel: BRK [0x11280b000, 0x11280bfff] PGTABLE
Jan 15 17:40:32 salva-pc kernel: RAMDISK: [mem 0x36e11000-0x376fffff]
Jan 15 17:40:32 salva-pc kernel: ACPI: Early table checksum verification disabled
Jan 15 17:40:32 salva-pc kernel: ACPI: RSDP 0x00000000000FE020 000024 (v02 ACRSYS)
Jan 15 17:40:32 salva-pc kernel: ACPI: XSDT 0x000000007A6C1120 00009C (v01 ACRSYS ACRPRDCT 00000003 01000013)
Jan 15 17:40:32 salva-pc kernel: ACPI: FACP 0x000000007A6B8000 00010C (v05 ACRSYS ACRPRDCT 00000003 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: DSDT 0x000000007A6AA000 009011 (v02 ACRSYS ACRPRDCT 00000003 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: FACS 0x000000007A605000 000040
Jan 15 17:40:32 salva-pc kernel: ACPI: UEFI 0x000000007A6C0000 000236 (v01 ACRSYS ACRPRDCT 00000001 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: TCPA 0x000000007A6BE000 000032 (v02 ACRSYS ACRPRDCT 00000000 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: UEFI 0x000000007A6BD000 000042 (v01 ACRSYS ACRPRDCT 00000000 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: SSDT 0x000000007A6B9000 003548 (v01 ACRSYS ACRPRDCT 00001000 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: APIC 0x000000007A6B7000 000084 (v03 ACRSYS ACRPRDCT 00000003 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: MCFG 0x000000007A6B6000 00003C (v01 ACRSYS ACRPRDCT 00000003 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: SSDT 0x000000007A6B5000 00052B (v01 ACRSYS ACRPRDCT 00000003 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: SSDT 0x000000007A6B4000 0008B0 (v01 ACRSYS ACRPRDCT 00000003 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: SSDT 0x000000007A6A9000 000763 (v01 ACRSYS ACRPRDCT 00003000 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: SSDT 0x000000007A6A8000 000290 (v01 ACRSYS ACRPRDCT 00003000 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: SSDT 0x000000007A6A7000 00017A (v01 ACRSYS ACRPRDCT 00003000 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: SSDT 0x000000007A6A6000 000432 (v01 ACRSYS ACRPRDCT 00001000 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: TPM2 0x000000007A6A5000 000034 (v03 ACRSYS ACRPRDCT 00000000 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: FPDT 0x000000007A6A4000 000044 (v01 ACRSYS ACRPRDCT 00000002 1025 00040000)
Jan 15 17:40:32 salva-pc kernel: ACPI: Local APIC address 0xfee00000
Jan 15 17:40:32 salva-pc kernel: No NUMA configuration found
Jan 15 17:40:32 salva-pc kernel: Faking a node at [mem 0x0000000000000000-0x000000017fffffff]
Jan 15 17:40:32 salva-pc kernel: NODE_DATA(0) allocated [mem 0x17fffb000-0x17fffefff]
Jan 15 17:40:32 salva-pc kernel: Zone ranges:
Jan 15 17:40:32 salva-pc kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
Jan 15 17:40:32 salva-pc kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
Jan 15 17:40:32 salva-pc kernel: Normal [mem 0x0000000100000000-0x000000017fffffff]
Jan 15 17:40:32 salva-pc kernel: Device empty
Jan 15 17:40:32 salva-pc kernel: Movable zone start for each node
Jan 15 17:40:32 salva-pc kernel: Early memory node ranges
Jan 15 17:40:32 salva-pc kernel: node 0: [mem 0x0000000000001000-0x000000000009dfff]
Jan 15 17:40:32 salva-pc kernel: node 0: [mem 0x0000000000100000-0x000000001fffffff]
Jan 15 17:40:32 salva-pc kernel: node 0: [mem 0x0000000020200000-0x0000000074a01fff]
Jan 15 17:40:32 salva-pc kernel: node 0: [mem 0x0000000074a82000-0x000000007a181fff]
Jan 15 17:40:32 salva-pc kernel: node 0: [mem 0x000000007a6c2000-0x000000007b485fff]
Jan 15 17:40:32 salva-pc kernel: node 0: [mem 0x000000007bd86000-0x000000007bffffff]
Jan 15 17:40:32 salva-pc kernel: node 0: [mem 0x0000000100000000-0x000000017fffffff]
Jan 15 17:40:32 salva-pc kernel: Zeroed struct page in unavailable ranges: 20771 pages
Jan 15 17:40:32 salva-pc kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000017fffffff]
Jan 15 17:40:32 salva-pc kernel: On node 0 totalpages: 1027805
Jan 15 17:40:32 salva-pc kernel: DMA zone: 64 pages used for memmap
Jan 15 17:40:32 salva-pc kernel: DMA zone: 21 pages reserved
Jan 15 17:40:32 salva-pc kernel: DMA zone: 3997 pages, LIFO batch:0
Jan 15 17:40:32 salva-pc kernel: DMA32 zone: 7805 pages used for memmap
Jan 15 17:40:32 salva-pc kernel: DMA32 zone: 499520 pages, LIFO batch:63
Jan 15 17:40:32 salva-pc kernel: Normal zone: 8192 pages used for memmap
Jan 15 17:40:32 salva-pc kernel: Normal zone: 524288 pages, LIFO batch:63
Jan 15 17:40:32 salva-pc kernel: Reserving Intel graphics memory at [mem 0x7cc00000-0x7ebfffff]
Jan 15 17:40:32 salva-pc kernel: ACPI: PM-Timer IO Port: 0x408
Jan 15 17:40:32 salva-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high level lint[0x1])
Jan 15 17:40:32 salva-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high level lint[0x1])
Jan 15 17:40:32 salva-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high level lint[0x1])
Jan 15 17:40:32 salva-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high level lint[0x1])
Jan 15 17:40:32 salva-pc kernel: IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-114
Jan 15 17:40:32 salva-pc kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Jan 15 17:40:32 salva-pc kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Jan 15 17:40:32 salva-pc kernel: ACPI: IRQ0 used by override.
Jan 15 17:40:32 salva-pc kernel: ACPI: IRQ9 used by override.
Jan 15 17:40:32 salva-pc kernel: Using ACPI (MADT) for SMP configuration information
Jan 15 17:40:32 salva-pc kernel: smpboot: Allowing 4 CPUs, 0 hotplug CPUs
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x0009e000-0x0009efff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x20000000-0x201fffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x74a02000-0x74a81fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x7a182000-0x7a581fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x7a582000-0x7a681fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x7a682000-0x7a6c1fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x7b486000-0x7bd85fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x7c000000-0x7c3fffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x7c400000-0x7fffffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0x80000000-0xdfffffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xe0000000-0xe3ffffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xe4000000-0xfe9fffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfea00000-0xfeafffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfeb00000-0xfebfffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfec01000-0xfed00fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfed01000-0xfed01fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfed02000-0xfed02fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfed03000-0xfed03fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfed04000-0xfed07fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfed08000-0xfed09fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfed0a000-0xfed1bfff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfed1c000-0xfed1cfff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfed1d000-0xfed7ffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfed80000-0xfedbffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfedc0000-0xfedfffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xfee01000-0xffbfffff]
Jan 15 17:40:32 salva-pc kernel: PM: Registered nosave memory: [mem 0xffc00000-0xffffffff]
Jan 15 17:40:32 salva-pc kernel: [mem 0x80000000-0xdfffffff] available for PCI devices
Jan 15 17:40:32 salva-pc kernel: Booting paravirtualized kernel on bare hardware
Jan 15 17:40:32 salva-pc kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Jan 15 17:40:32 salva-pc kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
Jan 15 17:40:32 salva-pc kernel: percpu: Embedded 54 pages/cpu s184320 r8192 d28672 u524288
Jan 15 17:40:32 salva-pc kernel: pcpu-alloc: s184320 r8192 d28672 u524288 alloc=1*2097152
Jan 15 17:40:32 salva-pc kernel: pcpu-alloc: [0] 0 1 2 3
Jan 15 17:40:32 salva-pc kernel: Built 1 zonelists, mobility grouping on. Total pages: 1011723
Jan 15 17:40:32 salva-pc kernel: Policy zone: Normal
Jan 15 17:40:32 salva-pc kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=UUID=26117b2a-a5a3-41bf-be75-0638cf60acf3 rw quiet loglevel=3
Jan 15 17:40:32 salva-pc kernel: Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
Jan 15 17:40:32 salva-pc kernel: Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
Jan 15 17:40:32 salva-pc kernel: mem auto-init: stack:byref_all, heap alloc:on, heap free:off
Jan 15 17:40:32 salva-pc kernel: Calgary: detecting Calgary via BIOS EBDA area
Jan 15 17:40:32 salva-pc kernel: Calgary: Unable to locate Rio Grande table in EBDA - bailing!
Jan 15 17:40:32 salva-pc kernel: Memory: 3934728K/4111220K available (12291K kernel code, 1327K rwdata, 4036K rodata, 1656K init, 3448K bss, 176492K reserved, 0K cma-reserved)
Jan 15 17:40:32 salva-pc kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Jan 15 17:40:32 salva-pc kernel: Kernel/User page tables isolation: enabled
Jan 15 17:40:32 salva-pc kernel: ftrace: allocating 38048 entries in 149 pages
Jan 15 17:40:32 salva-pc kernel: rcu: Preemptible hierarchical RCU implementation.
Jan 15 17:40:32 salva-pc kernel: rcu: RCU dyntick-idle grace-period acceleration is enabled.
Jan 15 17:40:32 salva-pc kernel: rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
Jan 15 17:40:32 salva-pc kernel: rcu: RCU priority boosting: priority 1 delay 500 ms.
Jan 15 17:40:32 salva-pc kernel: Tasks RCU enabled.
Jan 15 17:40:32 salva-pc kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
Jan 15 17:40:32 salva-pc kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
Jan 15 17:40:32 salva-pc kernel: NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
Jan 15 17:40:32 salva-pc kernel: random: get_random_bytes called from start_kernel+0x390/0x56b with crng_init=0
Jan 15 17:40:32 salva-pc kernel: Console: colour dummy device 80x25
Jan 15 17:40:32 salva-pc kernel: printk: console [tty0] enabled
Jan 15 17:40:32 salva-pc kernel: ACPI: Core revision 20190816
Jan 15 17:40:32 salva-pc kernel: APIC: Switch to symmetric I/O mode setup
Jan 15 17:40:32 salva-pc kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x171024fa93b, max_idle_ns: 440795253189 ns
Jan 15 17:40:32 salva-pc kernel: Calibrating delay loop (skipped), value calculated using timer frequency… 3201.33 BogoMIPS (lpj=5333333)
Jan 15 17:40:32 salva-pc kernel: pid_max: default: 32768 minimum: 301
Jan 15 17:40:32 salva-pc kernel: LSM: Security Framework initializing
Jan 15 17:40:32 salva-pc kernel: Yama: becoming mindful.
Jan 15 17:40:32 salva-pc kernel: Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Jan 15 17:40:32 salva-pc kernel: Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
Jan 15 17:40:32 salva-pc kernel: *** VALIDATE tmpfs ***
Jan 15 17:40:32 salva-pc kernel: *** VALIDATE proc ***
Jan 15 17:40:32 salva-pc kernel: *** VALIDATE cgroup1 ***
Jan 15 17:40:32 salva-pc kernel: *** VALIDATE cgroup2 ***
Jan 15 17:40:32 salva-pc kernel: process: using mwait in idle threads
Jan 15 17:40:32 salva-pc kernel: Last level iTLB entries: 4KB 48, 2MB 0, 4MB 0
Jan 15 17:40:32 salva-pc kernel: Last level dTLB entries: 4KB 256, 2MB 16, 4MB 16, 1GB 0
Jan 15 17:40:32 salva-pc kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
