cipolla
January 22, 2023, 12:17pm
1
trying to run a VM with qemu
but when I start the VM the CPU load goes always at 100% or more
it’s the same, if I use one core or more, the CPU load goes always over the top (checking with HTOP)
kvm is enabled and working
to start a VM I use for example this config:
qemu-system-x86_64 -accel kvm -cdrom EndeavourOS_Cassini_22_12.iso -boot menu=on -smp 2,sockets=1,cores=2,threads=1 -m 2G -vga virtio -display sdl,gl=on
I’ve tried a lot of options, but no way, always extremely high load for the CPU
thanks, but same results, 100% CPU load
150%, 80%
I’m considering to try virtualbox or vmware
Vmware is working well for me. Some distro’s that install don’t automatically size properly but most do so they must be missing something. I have no issue with EOS.
Virtualbox is not working correctly since a while with version 7.
thanks
I will try vmware, unfortunately I’m not able to find a solution with qemu
What are you running on it?
I can not understand why the CPU load is always so high, doing nothing in the VM
It should work well. I use vmware-workstation pro 17 and install vmware-tools. Then all you need to do is load the module. Then i add the network component. I use this one and then enable it.
Add this service to enable networking:
/etc/systemd/system/vmware-networks-server.service
[Unit]
Description=VMware Networks
Wants=vmware-networks-configuration.service
After=vmware-networks-configuration.service
[Service]
Type=forking
ExecStartPre=-/sbin/modprobe vmnet
ExecStart=/usr/bin/vmware-networks --start
ExecStop=/usr/bin/vmware-networks --stop
[Install]
WantedBy=multi-user.target
Edit: Don’t forget to enable the service.
https://wiki.archlinux.org/title/VMware
Edit: You could also load xf86-video-vmware but not sure if it’s needed? It’s an xorg driver.
What are your host specs? Curious why you’re not using virt-manager
via libvirtd
to manage your QEMU VMs. It makes setting up VMs almost as easy as VMware/VirtualBox.
cipolla
January 22, 2023, 5:53pm
12
I’m using virt-manager,
I’m trying to change the XML of the VM preferences, maybe something is going better
Here’s a current XML of my EOS VM w/Cinnamon DE: https://0x0.st/ohDa.html
My host specs:
CPU: 8-Core AMD Ryzen 7 2700X (-MT MCP-) speed/min/max: 4118/2200/3700 MHz Kernel: 6.1.7-arch1-1 x86_64 Up: 18h 50m
Mem: 10822.4/32004.2 MiB (33.8%) Storage: 5.92 TiB (41.0% used) Procs: 474 Shell: fish inxi: 3.3.04
cipolla
January 22, 2023, 6:59pm
14
thanks, but unfortunately the page is empty
Hmmm…maybe eos-sendlog
doesn’t like XML files.
<domain type='kvm'>
<name>arch-cin</name>
<uuid>06a19bee-b7c2-4b4f-a93b-7d6de7e1416b</uuid>
<title>Archlinux (EndeavourOS Cinnamon)</title>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://archlinux.org/archlinux/rolling"/>
</libosinfo:libosinfo>
</metadata>
<memory unit='KiB'>8388608</memory>
<currentMemory unit='KiB'>8388608</currentMemory>
<vcpu placement='static'>8</vcpu>
<os firmware='efi'>
<type arch='x86_64' machine='pc-q35-7.2'>hvm</type>
<bootmenu enable='yes'/>
</os>
<features>
<acpi/>
<apic/>
<vmport state='off'/>
</features>
<cpu mode='host-passthrough' check='none' migratable='on'>
<topology sockets='1' dies='1' cores='4' threads='2'/>
<cache mode='passthrough'/>
<feature policy='require' name='topoext'/>
</cpu>
<clock offset='utc'>
<timer name='rtc' tickpolicy='catchup'/>
<timer name='pit' tickpolicy='delay'/>
<timer name='hpet' present='no'/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled='no'/>
<suspend-to-disk enabled='no'/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type='file' device='cdrom'>
<driver name='qemu' type='raw'/>
<target dev='sda' bus='sata'/>
<readonly/>
<boot order='2'/>
<address type='drive' controller='0' bus='0' target='0' unit='0'/>
</disk>
<disk type='file' device='disk'>
<driver name='qemu' type='qcow2' cache='writeback' discard='unmap'/>
<source file='/home/ajgringo619/VMs/kvm-images/arch-cin.qcow2'/>
<target dev='sdb' bus='scsi'/>
<boot order='1'/>
<address type='drive' controller='0' bus='0' target='0' unit='1'/>
</disk>
<controller type='usb' index='0' model='qemu-xhci' ports='15'>
<address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
</controller>
<controller type='pci' index='0' model='pcie-root'/>
<controller type='pci' index='1' model='pcie-root-port'>
<model name='pcie-root-port'/>
<target chassis='1' port='0x10'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0' multifunction='on'/>
</controller>
<controller type='pci' index='2' model='pcie-root-port'>
<target chassis='2' port='0x11'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x1'/>
</controller>
<controller type='pci' index='3' model='pcie-root-port'>
<target chassis='3' port='0x12'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x2'/>
</controller>
<controller type='pci' index='4' model='pcie-root-port'>
<target chassis='4' port='0x13'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x3'/>
</controller>
<controller type='pci' index='5' model='pcie-root-port'>
<target chassis='5' port='0x14'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x4'/>
</controller>
<controller type='pci' index='6' model='pcie-root-port'>
<target chassis='6' port='0x15'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x5'/>
</controller>
<controller type='pci' index='7' model='pcie-root-port'>
<target chassis='7' port='0x16'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x6'/>
</controller>
<controller type='pci' index='8' model='pcie-root-port'>
<target chassis='8' port='0x17'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x7'/>
</controller>
<controller type='pci' index='9' model='pcie-root-port'>
<target chassis='9' port='0x18'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0' multifunction='on'/>
</controller>
<controller type='pci' index='10' model='pcie-root-port'>
<target chassis='10' port='0x19'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x1'/>
</controller>
<controller type='pci' index='11' model='pcie-root-port'>
<target chassis='11' port='0x1a'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x2'/>
</controller>
<controller type='pci' index='12' model='pcie-root-port'>
<target chassis='12' port='0x1b'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x3'/>
</controller>
<controller type='pci' index='13' model='pcie-root-port'>
<target chassis='13' port='0x1c'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x4'/>
</controller>
<controller type='pci' index='14' model='pcie-root-port'>
<target chassis='14' port='0x1d'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x5'/>
</controller>
<controller type='scsi' index='0' model='virtio-scsi'>
<address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
</controller>
<controller type='scsi' index='1' model='virtio-scsi'>
<address type='pci' domain='0x0000' bus='0x08' slot='0x00' function='0x0'/>
</controller>
<controller type='sata' index='0'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
</controller>
<controller type='virtio-serial' index='0'>
<address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
</controller>
<interface type='network'>
<mac address='52:54:00:d6:b6:c6'/>
<source network='default'/>
<model type='virtio'/>
<address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
</interface>
<serial type='pty'>
<target type='isa-serial' port='0'>
<model name='isa-serial'/>
</target>
</serial>
<console type='pty'>
<target type='serial' port='0'/>
</console>
<channel type='unix'>
<target type='virtio' name='org.qemu.guest_agent.0'/>
<address type='virtio-serial' controller='0' bus='0' port='1'/>
</channel>
<channel type='spicevmc'>
<target type='virtio' name='com.redhat.spice.0'/>
<address type='virtio-serial' controller='0' bus='0' port='2'/>
</channel>
<input type='tablet' bus='usb'>
<address type='usb' bus='0' port='1'/>
</input>
<input type='mouse' bus='ps2'/>
<input type='keyboard' bus='ps2'/>
<graphics type='spice' autoport='yes'>
<listen type='address'/>
<image compression='off'/>
</graphics>
<sound model='ich9'>
<address type='pci' domain='0x0000' bus='0x00' slot='0x1b' function='0x0'/>
</sound>
<audio id='1' type='spice'/>
<video>
<model type='virtio' heads='1' primary='yes'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/>
</video>
<redirdev bus='usb' type='spicevmc'>
<address type='usb' bus='0' port='2'/>
</redirdev>
<address type='usb' bus='0' port='3'/>
</redirdev>
<memballoon model='virtio'>
<address type='pci' domain='0x0000' bus='0x06' slot='0x00' function='0x0'/>
</memballoon>
<rng model='virtio'>
<backend model='random'>/dev/urandom</backend>
<address type='pci' domain='0x0000' bus='0x07' slot='0x00' function='0x0'/>
</rng>
</devices>
</domain>
cipolla
January 22, 2023, 7:31pm
16
thanks a lot
may I ask the host CPU load?
is it normal?
After logging in, the host usage is negligible.
cipolla
January 22, 2023, 7:41pm
18
thanks
I can not understand why in my PC the CPU is overloaded
but now is getting better
Would still like to see your host’s specs. 2 GB RAM is pretty low to give a VM.
cipolla
January 22, 2023, 7:45pm
20
you are right
I was using 2 GB with Alpine linux VM, and I’ve kept them
but I have in my PC 8 GB
