Problems with upgrading
yay -Syu
→ /var/lib/pacman/db.lck is present.
→ There may be another Pacman instance running. Waiting…
  1. Cancel operation
  2. Clean lck:
    sudo rm /var/lib/pacman/db.lck
  3. Update again
Thanks
If/when your issue is resolved, please check the solution box under the post pointing out the solution.
:enos_flag:
you can simply update with yay, you don’t need -Syu
Also for reference:
https://wiki.archlinux.org/title/Pacman#%22Failed_to_init_transaction_(unable_to_lock_database)%22_error
