Problems with latte dock
I have problems using latte dock. The background won’t turn to transparant, the animations when going over the icons with the mouse won’t work. Does anyone have this problem before?
Screenshot_20201014_170831
It usually means your compositor isn’t running.
Either it crashed, is disabled or is being blocked by an application.
What do you mean, like game or something?
I haven’t seen that with kwin though, it’s more like Gnome behaviour…
Typically it would be a game but you can use window rules to have any window block the compositor.
I think most full screen games block the compositor by default.
Where can I find the settings for the compositer?
Found the compositer. This was swithed off. Thanks. Is working again.
