Problems with connecting to Internet after having deleted contents of /var/cache/pacman/pkg/, orphans and more "uneeded packages"
Hello!
With a really bad mentality, i was trying to save some space on my disks and stupidly (after reading this I manually erased the following:
  • Everything under the
    /var/cache/pacman/pkg/ location
  • Executed the command
pacman -Qdtq | pacman -Rns -
  • Also the command
pacman -Qqd | pacman -Rsu -
And now while i can connect to internet, i can’t connect to most websites due to “certificate” error codes.
Also “Welcome” applet can’t connect to internet, can’t update mirrors (arch or endeavouros) and couldn’t sync with package databases (I managed to fix core/extra/multilib by editing the /etc/pacman.d/mirrorlist with some servers, but could not do the same for endeavouros-mirrorlist.
Any suggestions on how to fix this thing and maybe restore something else that i accidently broke?
I tried
  • booting on a live usb (in order to copy the pkg contents of its pacman to mine) but unfortunately it gets stuck on uevents and never loads to my pc.
Tried unsuccessfully these:
Yes, unneeded packages are not packages you don’t need. They are packages that pacman doesn’t define as needed. Also, even the wiki tells you to use print with that second command. If you just blindly remove all the packages, you will end up in a bad spot as you found out.
Your internet problems are maybe caused by removing ca-certificates-mozilla. Try reinstalling that package. You might need to download it manually and then install it with sudo pacman -U.
Then you go through /var/log/pacman.log and see what packages you removed and reinstall them.
Yeap you are absolutely right about this! I firstly executed the command with print, “checked” that there wasn’t something important and re-executed the command without it (you can’t beat stupidity :frowning: )
These are the today’s pacman.log logs, i should install them all one by one right?
[2024-08-15T13:15:11+0300] [ALPM] running '30-systemd-update.hook'...
[2024-08-15T13:41:58+0300] [PACMAN] Running 'pacman -Rsu -'
[2024-08-15T13:42:00+0300] [ALPM] transaction started
[2024-08-15T13:42:01+0300] [ALPM] removed yarn (1.22.22-2)
[2024-08-15T13:42:01+0300] [ALPM] removed xorg-xwayland (24.1.2-1)
[2024-08-15T13:42:01+0300] [ALPM] removed xorg-xhost (1.0.9-2)
[2024-08-15T13:42:01+0300] [ALPM] removed wlroots (0.18.0-1)
[2024-08-15T13:42:01+0300] [ALPM] removed xcb-util-errors (1.0.1-2)
[2024-08-15T13:42:01+0300] [ALPM] removed webrtc-audio-processing (0.3.1-5)
[2024-08-15T13:42:01+0300] [ALPM] removed vala (0.56.17-1)
[2024-08-15T13:42:01+0300] [ALPM] removed unarchiver (1.10.8-2)
[2024-08-15T13:42:01+0300] [ALPM] removed threadweaver5 (5.116.0-1)
[2024-08-15T13:42:01+0300] [ALPM] removed syntax-highlighting5 (5.116.0-1)
[2024-08-15T13:42:01+0300] [ALPM] removed superproductivity-bin-debug (9.0.5-1)
[2024-08-15T13:42:01+0300] [ALPM] removed seatd (0.8.0-2)
[2024-08-15T13:42:01+0300] [ALPM] removed scdoc (1.11.3-1)
[2024-08-15T13:42:01+0300] [ALPM] removed riseup-vpn-git-debug (0.24.6.rc.1.r10.g4ee5fba6-1)
[2024-08-15T13:42:01+0300] [ALPM] removed qt5-xmlpatterns (5.15.14-1)
[2024-08-15T13:42:01+0300] [ALPM] removed qt5-webengine (5.15.17-6)
[2024-08-15T13:42:01+0300] [ALPM] removed qt5-webchannel (5.15.14+kde+r3-1)
[2024-08-15T13:42:01+0300] [ALPM] removed qt5-tools (5.15.14+kde+r4-2)
[2024-08-15T13:42:01+0300] [ALPM] removed qt5-location (5.15.14+kde+r7-1)
[2024-08-15T13:42:01+0300] [ALPM] removed python-xlib (0.33-3)
[2024-08-15T13:42:01+0300] [ALPM] removed python-wxpython (1:4.2.1-2)
[2024-08-15T13:42:01+0300] [ALPM] removed python-wheel (0.44.0-1)
[2024-08-15T13:42:01+0300] [ALPM] removed python-ujson (5.10.0-1)
[2024-08-15T13:42:01+0300] [ALPM] removed python-toolz (0.12.1-2)
[2024-08-15T13:42:01+0300] [ALPM] removed python-pytest-cov (5.0.0-1)
[2024-08-15T13:42:01+0300] [ALPM] removed python-pytest (1:8.3.2-1)
[2024-08-15T13:42:01+0300] [ALPM] removed python-pytaglib-debug (3.0.0-1)
[2024-08-15T13:42:01+0300] [ALPM] removed python-pyrate-limiter (3.6.0-2)
[2024-08-15T13:42:01+0300] [ALPM] removed python-ply (3.11-13)
[2024-08-15T13:42:02+0300] [ALPM] removed python-opengl (3.1.7-1)
[2024-08-15T13:42:02+0300] [ALPM] removed python-nose (1.3.7-16)
[2024-08-15T13:42:02+0300] [ALPM] removed python-installer (0.7.0-8)
[2024-08-15T13:42:02+0300] [ALPM] removed python-iniconfig (2.0.0-5)
[2024-08-15T13:42:02+0300] [ALPM] removed python-inflect (7.3.1-1)
[2024-08-15T13:42:02+0300] [ALPM] removed python-typeguard (4.3.0-1)
[2024-08-15T13:42:02+0300] [ALPM] removed python-hatchling (1.24.2-1)
[2024-08-15T13:42:02+0300] [ALPM] removed python-pluggy (1.5.0-1)
[2024-08-15T13:42:02+0300] [ALPM] removed python-pathspec (0.12.1-2)
[2024-08-15T13:42:02+0300] [ALPM] removed python-filelock (3.13.3-2)
[2024-08-15T13:42:02+0300] [ALPM] removed python-editables (0.5-3)
[2024-08-15T13:42:02+0300] [ALPM] removed python-coverage (7.6.1-1)
[2024-08-15T13:42:02+0300] [ALPM] removed python-build (1.2.1-3)
[2024-08-15T13:42:02+0300] [ALPM] removed python-pyproject-hooks (1.1.0-1)
[2024-08-15T13:42:02+0300] [ALPM] removed purpose5 (5.116.0-1)
[2024-08-15T13:42:02+0300] [ALPM] removed prison5 (5.116.0-1)
[2024-08-15T13:42:02+0300] [ALPM] removed poppler-qt5 (24.08.0-1)
[2024-08-15T13:42:02+0300] [ALPM] removed phonon-qt5 (4.12.0-4)
[2024-08-15T13:42:02+0300] [ALPM] removed phonon-qt5-gstreamer (4.10.0-4)
[2024-08-15T13:42:02+0300] [ALPM] removed pamac-classic-debug (7.3.0-3)
[2024-08-15T13:42:02+0300] [ALPM] removed openvr (2.5.1-1)
[2024-08-15T13:42:02+0300] [ALPM] removed openmpi (5.0.5-1)
[2024-08-15T13:42:02+0300] [ALPM] removed prrte (3.0.6-1)
[2024-08-15T13:42:02+0300] [ALPM] removed openucx (1.17.0-1)
[2024-08-15T13:42:02+0300] [ALPM] removed openpmix (5.0.3-1)
[2024-08-15T13:42:02+0300] [ALPM] removed ndctl (79-1)
[2024-08-15T13:42:02+0300] [ALPM] removed meson (1.5.1-1)
[2024-08-15T13:42:02+0300] [ALPM] removed python-tqdm (4.66.5-1)
[2024-08-15T13:42:02+0300] [ALPM] removed ninja (1.12.1-1)
[2024-08-15T13:42:02+0300] [ALPM] removed libwpg (0.3.4-2)
[2024-08-15T13:42:02+0300] [ALPM] removed libtracefs (1.8.1-1)
[2024-08-15T13:42:02+0300] [ALPM] removed libtraceevent (1:1.8.3-1)
[2024-08-15T13:42:02+0300] [ALPM] removed libportal-gtk3 (0.7.1-3)
[2024-08-15T13:42:02+0300] [ALPM] removed libliftoff (0.5.0-1)
[2024-08-15T13:42:02+0300] [ALPM] removed libkate (0.4.1-10)
[2024-08-15T13:42:02+0300] [ALPM] removed libical (3.0.18-2)
[2024-08-15T13:42:02+0300] [ALPM] removed libfabric (1.22.0-1)
[2024-08-15T13:42:02+0300] [ALPM] removed numactl (2.0.18-1)
[2024-08-15T13:42:02+0300] [ALPM] removed libelectron-debug (1.0.24-1)
[2024-08-15T13:42:02+0300] [ALPM] removed libelectron (1.0.24-1)
[2024-08-15T13:42:02+0300] [ALPM] removed npm (10.8.2-1)
[2024-08-15T13:42:03+0300] [ALPM] removed node-gyp (10.2.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed semver (7.6.3-1)
[2024-08-15T13:42:03+0300] [ALPM] removed nodejs-nopt (7.2.0-2)
[2024-08-15T13:42:03+0300] [ALPM] removed nodejs (22.6.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed libngtcp2 (1.6.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed libdmtx (0.7.7-2)
[2024-08-15T13:42:03+0300] [ALPM] removed libdisplay-info (0.2.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed lib32-vulkan-radeon (1:24.1.5-2)
[2024-08-15T13:42:03+0300] [ALPM] removed lib32-xcb-util-keysyms (0.4.1-1)
[2024-08-15T13:42:03+0300] [ALPM] removed lib32-libvpx (1.14.1-1)
[2024-08-15T13:42:03+0300] [ALPM] removed lib32-libcanberra (1:0.30+r2+gc0620e4-2)
[2024-08-15T13:42:03+0300] [ALPM] removed lib32-tdb (1.4.12-1)
[2024-08-15T13:42:03+0300] [ALPM] removed lib32-libltdl (2.5.0+1+g38c166c8-1)
[2024-08-15T13:42:03+0300] [ALPM] removed lib32-attr (2.5.2-1)
[2024-08-15T13:42:03+0300] [ALPM] removed ldns (1.8.3-2)
[2024-08-15T13:42:03+0300] [ALPM] removed kpty5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kparts5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kitemmodels (6.4.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kirigami2 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed qt5-quickcontrols2 (5.15.14+kde+r5-1)
[2024-08-15T13:42:03+0300] [ALPM] removed qt5-graphicaleffects (5.15.14-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kio-fuse (5.1.0-3)
[2024-08-15T13:42:03+0300] [ALPM] removed kio-extras (24.05.2-1)
[2024-08-15T13:42:03+0300] [ALPM] removed syntax-highlighting (6.4.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kdsoap-ws-discovery-client (0.4.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kdsoap-qt6 (2.2.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kdsoap-qt5 (2.2.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kdnssd5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kdnssd (6.4.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kcmutils5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kdeclarative5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kpackage5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kio5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed solid5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kwallet5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed qca-qt5 (2.3.9-2)
[2024-08-15T13:42:03+0300] [ALPM] removed knotifications5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed libdbusmenu-qt5 (0.9.3+16.04.20160218-7)
[2024-08-15T13:42:03+0300] [ALPM] removed ktextwidgets5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed sonnet5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed qt5-speech (5.15.14+kde+r1-1)
[2024-08-15T13:42:03+0300] [ALPM] removed qt5-multimedia (5.15.14+kde+r2-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kcompletion5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kjobwidgets5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kded5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kservice5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kdbusaddons5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kcrash5 (5.116.0-1)
[2024-08-15T13:42:03+0300] [ALPM] removed kbookmarks5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kxmlgui5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kitemviews5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kiconthemes5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kconfigwidgets5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kwidgetsaddons5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed ki18n5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kguiaddons5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed qt5-wayland (5.15.14+kde+r59-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kcodecs5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kglobalaccel5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kwindowsystem5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kauth5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed polkit-qt5 (0.200.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed karchive5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kactivities-stats5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kactivities5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kcoreaddons5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed kconfig5 (5.116.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed jre11-openjdk-headless (11.0.24.u8-1)
[2024-08-15T13:42:04+0300] [ALPM] removed iniparser (4.2.4-1)
[2024-08-15T13:42:04+0300] [ALPM] removed gtk-doc (1.34.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed google-glog (0.7.1-1)
[2024-08-15T13:42:04+0300] [ALPM] removed gobject-introspection (1.80.1-3)
[2024-08-15T13:42:04+0300] [ALPM] removed python-setuptools (1:69.5.1-1)
[2024-08-15T13:42:04+0300] [ALPM] removed python-validate-pyproject (0.18-1)
[2024-08-15T13:42:04+0300] [ALPM] removed python-trove-classifiers (2024.7.2-1)
[2024-08-15T13:42:04+0300] [ALPM] removed python-fastjsonschema (2.20.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed python-tomli (2.0.1-4)
[2024-08-15T13:42:04+0300] [ALPM] removed python-platformdirs (4.2.2-1)
[2024-08-15T13:42:04+0300] [ALPM] removed python-ordered-set (4.1.0-5)
[2024-08-15T13:42:04+0300] [ALPM] removed python-jaraco.text (4.0.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed python-jaraco.functools (4.0.2-1)
[2024-08-15T13:42:04+0300] [ALPM] removed python-more-itertools (10.3.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed python-jaraco.context (5.3.0-1)
[2024-08-15T13:42:04+0300] [ALPM] removed python-autocommand (2.2.2-6)
[2024-08-15T13:42:04+0300] [ALPM] removed python-mako (1.3.5-1)
[2024-08-15T13:42:04+0300] [ALPM] removed python-markupsafe (2.1.5-2)
[2024-08-15T13:42:05+0300] [ALPM] removed go (2:1.22.6-1)
[2024-08-15T13:42:05+0300] [ALPM] removed gnustep-base (1.29.0-4)
[2024-08-15T13:42:05+0300] [ALPM] removed glm (1.0.1-1)
[2024-08-15T13:42:05+0300] [ALPM] removed glib2-docs (2.80.4-1)
[2024-08-15T13:42:05+0300] [ALPM] removed gflags (2.2.2-5)
[2024-08-15T13:42:05+0300] [ALPM] removed geoip (1.6.12-3)
[2024-08-15T13:42:05+0300] [ALPM] removed geoip-database (20240720-1)
[2024-08-15T13:42:05+0300] [ALPM] removed flake8 (1:7.1.1-1)
[2024-08-15T13:42:05+0300] [ALPM] removed python-pyflakes (3.2.0-2)
[2024-08-15T13:42:05+0300] [ALPM] removed python-pycodestyle (2.11.1-2)
[2024-08-15T13:42:05+0300] [ALPM] removed python-mccabe (0.7.0-7)
[2024-08-15T13:42:05+0300] [ALPM] removed python-entrypoints (0.4-4)
[2024-08-15T13:42:05+0300] [ALPM] removed electron29 (1:29.4.5-1)
[2024-08-15T13:42:05+0300] [ALPM] removed electron28 (28.3.3-2)
[2024-08-15T13:42:05+0300] [ALPM] removed electron27 (27.3.11-6)
[2024-08-15T13:42:05+0300] [ALPM] removed re2 (1:20240702-2)
[2024-08-15T13:42:05+0300] [ALPM] removed dwarfs-bin-debug (0.9.9-1)
[2024-08-15T13:42:05+0300] [ALPM] removed docbook-xsl (1.79.2-8)
[2024-08-15T13:42:05+0300] [ALPM] removed docbook-xml (4.5-10)
[2024-08-15T13:42:06+0300] [ALPM] removed ddcutil (2.1.4-1)
[2024-08-15T13:42:06+0300] [ALPM] removed i2c-tools (4.3-6)
[2024-08-15T13:42:06+0300] [ALPM] removed db (6.2.32-1)
[2024-08-15T13:42:06+0300] [ALPM] removed cython (3.0.10-5)
[2024-08-15T13:42:06+0300] [ALPM] removed cpuid-debug (20240409-1)
[2024-08-15T13:42:06+0300] [ALPM] removed cmake (3.30.2-1)
[2024-08-15T13:42:06+0300] [ALPM] removed rhash (1.4.4-1)
[2024-08-15T13:42:06+0300] [ALPM] removed jsoncpp (1.9.5-3)
[2024-08-15T13:42:06+0300] [ALPM] removed cppdap (1.58.0-2)
[2024-08-15T13:42:06+0300] [ALPM] removed chafa (1.14.2-1)
[2024-08-15T13:42:06+0300] [ALPM] removed botan (3.5.0-1)
[2024-08-15T13:42:06+0300] [ALPM] removed argyllcms (3.2.0-1)
[2024-08-15T13:42:06+0300] [ALPM] removed appstream-glib (0.8.3-1)
[2024-08-15T13:42:06+0300] [ALPM] removed ca-certificates (20240618-1)
[2024-08-15T13:42:06+0300] [ALPM] removed ca-certificates-mozilla (3.103-1)
[2024-08-15T13:42:06+0300] [ALPM] transaction completed
[2024-08-15T13:42:07+0300] [ALPM] running '30-systemd-daemon-reload-system.hook'...
[2024-08-15T13:42:08+0300] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2024-08-15T13:42:08+0300] [ALPM] running '30-systemd-udev-reload.hook'...
[2024-08-15T13:42:09+0300] [ALPM] running '30-systemd-update.hook'...
[2024-08-15T13:42:09+0300] [ALPM] running '30-update-mime-database.hook'...
[2024-08-15T13:42:09+0300] [ALPM] running '40-update-ca-trust.hook'...
[2024-08-15T13:42:10+0300] [ALPM] running 'dbus-reload.hook'...
[2024-08-15T13:42:10+0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-08-15T13:42:10+0300] [ALPM] running 'update-desktop-database.hook'...
[2024-08-15T13:47:16+0300] [PACMAN] Running 'pacman -Sy'
[2024-08-15T13:47:16+0300] [PACMAN] synchronizing package lists
[2024-08-15T13:48:56+0300] [PACMAN] Running 'pacman -Sy'
[2024-08-15T13:48:56+0300] [PACMAN] synchronizing package lists
[2024-08-15T13:49:25+0300] [PACMAN] Running 'pacman -Syuy'
[2024-08-15T13:49:25+0300] [PACMAN] synchronizing package lists
[2024-08-15T13:51:26+0300] [PACMAN] Running 'pacman -S -y --config /etc/pacman.conf --'
[2024-08-15T13:51:26+0300] [PACMAN] synchronizing package lists
[2024-08-15T13:57:14+0300] [PACMAN] Running 'pacman -Sy'
[2024-08-15T13:57:14+0300] [PACMAN] synchronizing package lists
[2024-08-15T13:59:11+0300] [PACMAN] Running 'pacman -Syuw'
[2024-08-15T13:59:11+0300] [PACMAN] synchronizing package lists
[2024-08-15T14:00:21+0300] [PACMAN] Running 'pacman -Syuw'
[2024-08-15T14:00:21+0300] [PACMAN] synchronizing package lists
[2024-08-15T14:02:32+0300] [PACMAN] Running 'pacman -Syyu'
[2024-08-15T14:02:32+0300] [PACMAN] synchronizing package lists
[2024-08-15T14:23:38+0300] [PACMAN] Running 'pacman -Sy'
[2024-08-15T14:23:38+0300] [PACMAN] synchronizing package lists
[2024-08-15T14:25:31+0300] [PACMAN] Running 'pacman -Syy archlinux-keyring endeavouros-keyring'
[2024-08-15T14:25:31+0300] [PACMAN] synchronizing package lists
[2024-08-15T14:25:44+0300] [PACMAN] Running 'pacman -Syy archlinux-keyring'
[2024-08-15T14:25:44+0300] [PACMAN] synchronizing package lists
[2024-08-15T14:38:28+0300] [PACMAN] Running 'pacman -Sy'
[2024-08-15T14:38:28+0300] [PACMAN] synchronizing package lists
[2024-08-15T14:43:19+0300] [PACMAN] Running 'pacman -Syu'
[2024-08-15T14:43:19+0300] [PACMAN] synchronizing package lists
[2024-08-15T14:44:53+0300] [PACMAN] Running 'pacman -Sc'
[2024-08-15T14:45:16+0300] [PACMAN] Running 'pacman -Syu'
[2024-08-15T14:45:16+0300] [PACMAN] synchronizing package lists
[2024-08-15T19:58:10+0300] [PACMAN] Running 'pacman -Sy'
[2024-08-15T19:58:10+0300] [PACMAN] synchronizing package lists
Btw THANK YOU! By downloading the ca-certificates-mozilla package and running
sudo pacman -U my_download_location/ca-certificates-mozilla-3.103-1-x86_64.pkg.tar
solved the issue of the internet problems! Onward to fix the rest of potential problems i caused!
Most of the packages you removed don’t look needed to me.
I would see if anything else isn’t working at this point.
I did a full system update and installed a bunch of these, not everything, and everything seems to be in order!
Again thank you very much!
