Problems in fresh install of EOS: screen freeze
Hello there.
I just tried installing the EndeavourOS on a new computer and I am having several problems. First of, I everything went fine until the reboot after the installation. I downloaded community wallpapers, but when I tried to change it, everything just freezes forever. I tried rebooting again, but screen just remained black. I already tried twice. I saw that in the past this issue was causes because of NVDIA drivers, but I have a RTX3060 and correctly chose the installation with NVDIA drivers. I chose KDE desktop with i3.
Any idea what might have caused this and how I could fix?
Welcome!
KDE with i3 has all sorts of complications you have to factor in. I’ve never (successfully) ran them together.
How did you set it up?
If you’re looking for a WM compiled into a desktop, I always recommend XFCE+i3. Please check this out if you’re interested:
Ok, I tried installing only plasma and got yet another error that did not allow the installation to finish. It says
pacman -S --neaudio pulseaudio-alsa pulseaudio-jack amd-ucode dmidecode dmraid dosfstools hdparm hwdetect intel-ucode lsscsi mtoo
returned error code 1.
What could this be? I am really lost here.
EDIT: I found the actual log and it seems that many more packages failed than the above ones, but still no solution. Full logs at: http://ix.io/3CmA
At one point during the install you were getting http 403 errors meaning your access to the Arch servers was being denied. I would suggest disabling (temporarily!) the firewall on your router and try to install plasma again. I am no expert on this but it looks like your connection to the required downloads was disrupted at some point, which would cause calamares to fail. If it’s not this then I am not sure! :sweat_smile:
Well, that did work out and the installation completed successfully, so I think you are right as my internet was unstable at that time. However, when rebooting and logging in the windows (apparently any, but notably where we find images for the background) freeze with (Not Responding) and the Window Managers windows that open do not respond too. I did another reboot and all seem to be working fine (windows, background, terminal etc). I don’t know the error, but I guess reboot for the win?
Thank you all for the help.
Yeah I did an install 2 days ago on an old spare machine (i3WM only) and it was having graphics freezing issues. After 2 reboots everything was fine. No idea why, I haven’t looked at the logs yet as that machine is unplugged at the moment :man_shrugging:
Glad you are up and running anyway :smiley:
Ok, so I am back. Everything on the last install went fine (as far as I can tell, but clearly not since there is still a bug). When I try do edit the Apperance or Window Management and click “Apply” the whole system freezes and I cannot do anything. When I reboot, the change I made is applied. I also cannot turn off the computer by the “Shut Down” button. When I run journalctl -b I do see that there is something odd with my kernel. I had to delete some of the first lines due to the limit, but here is the result. As a heads up, the last line says :
out 21 13:21:26 lucas-pc kernel: pcieport 0000:00:1b.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
`$journalctl -b`
out 21 13:21:25 lucas-pc kernel:  sda: sda1 sda2
out 21 13:21:25 lucas-pc kernel: sd 0:0:0:0: [sda] Attached SCSI disk
out 21 13:21:25 lucas-pc kernel: Freeing unused decrypted memory: 2036K
out 21 13:21:25 lucas-pc kernel: Freeing unused kernel image (initmem) memory: 1804K
out 21 13:21:25 lucas-pc kernel: Write protecting the kernel read-only data: 26624k
out 21 13:21:25 lucas-pc kernel: Freeing unused kernel image (text/rodata gap) memory: 2036K
out 21 13:21:25 lucas-pc kernel: Freeing unused kernel image (rodata/data gap) memory: 884K
out 21 13:21:25 lucas-pc kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
out 21 13:21:25 lucas-pc kernel: rodata_test: all tests were successful
out 21 13:21:25 lucas-pc kernel: Run /init as init process
out 21 13:21:25 lucas-pc kernel:   with arguments:
out 21 13:21:25 lucas-pc kernel:     /init
out 21 13:21:25 lucas-pc kernel:   with environment:
out 21 13:21:25 lucas-pc kernel:     HOME=/
out 21 13:21:25 lucas-pc kernel:     TERM=linux
out 21 13:21:25 lucas-pc kernel:     BOOT_IMAGE=/boot/vmlinuz-linux
out 21 13:21:25 lucas-pc kernel: fbcon: Taking over console
out 21 13:21:25 lucas-pc kernel: Console: switching to colour frame buffer device 128x48
out 21 13:21:25 lucas-pc kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
out 21 13:21:25 lucas-pc kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
out 21 13:21:25 lucas-pc kernel: xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000109810
out 21 13:21:25 lucas-pc kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
out 21 13:21:25 lucas-pc kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
out 21 13:21:25 lucas-pc kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.14
out 21 13:21:25 lucas-pc kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
out 21 13:21:25 lucas-pc kernel: usb usb1: Product: xHCI Host Controller
out 21 13:21:25 lucas-pc kernel: usb usb1: Manufacturer: Linux 5.14.14-arch1-1 xhci-hcd
out 21 13:21:25 lucas-pc kernel: usb usb1: SerialNumber: 0000:00:14.0
out 21 13:21:25 lucas-pc kernel: hub 1-0:1.0: USB hub found
out 21 13:21:25 lucas-pc kernel: hub 1-0:1.0: 12 ports detected
out 21 13:21:25 lucas-pc kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.14
out 21 13:21:25 lucas-pc kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
out 21 13:21:25 lucas-pc kernel: usb usb2: Product: xHCI Host Controller
out 21 13:21:25 lucas-pc kernel: usb usb2: Manufacturer: Linux 5.14.14-arch1-1 xhci-hcd
out 21 13:21:25 lucas-pc kernel: usb usb2: SerialNumber: 0000:00:14.0
out 21 13:21:25 lucas-pc kernel: hub 2-0:1.0: USB hub found
out 21 13:21:25 lucas-pc kernel: hub 2-0:1.0: 8 ports detected
out 21 13:21:25 lucas-pc kernel: usb 1-1: new full-speed USB device number 2 using xhci_hcd
out 21 13:21:25 lucas-pc kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
out 21 13:21:25 lucas-pc kernel: usb 1-1: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
out 21 13:21:25 lucas-pc kernel: usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
out 21 13:21:25 lucas-pc kernel: usb 1-1: Product: USB Receiver
out 21 13:21:25 lucas-pc kernel: usb 1-1: Manufacturer: Logitech
out 21 13:21:25 lucas-pc kernel: random: fast init done
out 21 13:21:25 lucas-pc systemd[1]: systemd 249.5-2-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OP>
out 21 13:21:25 lucas-pc systemd[1]: Detected architecture x86-64.
out 21 13:21:25 lucas-pc systemd[1]: Hostname set to <lucas-pc>.
out 21 13:21:25 lucas-pc kernel: tsc: Refined TSC clocksource calibration: 3791.998 MHz
out 21 13:21:25 lucas-pc kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6d51a1f9672, max_idle_ns: 881590864124 ns
out 21 13:21:25 lucas-pc kernel: clocksource: Switched to clocksource tsc
out 21 13:21:25 lucas-pc kernel: usb 1-2: new high-speed USB device number 3 using xhci_hcd
out 21 13:21:25 lucas-pc kernel: random: lvmconfig: uninitialized urandom read (4 bytes read)
out 21 13:21:25 lucas-pc systemd[1]: Queued start job for default target Graphical Interface.
out 21 13:21:25 lucas-pc systemd[1]: Created slice Slice /system/getty.
out 21 13:21:25 lucas-pc systemd[1]: Created slice Slice /system/modprobe.
out 21 13:21:25 lucas-pc systemd[1]: Created slice Slice /system/systemd-fsck.
out 21 13:21:25 lucas-pc systemd[1]: Created slice User and Session Slice.
out 21 13:21:25 lucas-pc systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
out 21 13:21:25 lucas-pc systemd[1]: Started Forward Password Requests to Wall Directory Watch.
out 21 13:21:25 lucas-pc systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
out 21 13:21:25 lucas-pc systemd[1]: Reached target Local Encrypted Volumes.
out 21 13:21:25 lucas-pc systemd[1]: Reached target Login Prompts.
out 21 13:21:25 lucas-pc systemd[1]: Reached target Path Units.
out 21 13:21:25 lucas-pc systemd[1]: Reached target Remote File Systems.
out 21 13:21:25 lucas-pc systemd[1]: Reached target Slice Units.
out 21 13:21:25 lucas-pc systemd[1]: Reached target Swaps.
out 21 13:21:25 lucas-pc systemd[1]: Reached target Local Verity Integrity Protected Volumes.
out 21 13:21:25 lucas-pc systemd[1]: Listening on Device-mapper event daemon FIFOs.
out 21 13:21:25 lucas-pc systemd[1]: Listening on LVM2 poll daemon socket.
out 21 13:21:25 lucas-pc systemd[1]: Listening on Process Core Dump Socket.
out 21 13:21:25 lucas-pc systemd[1]: Listening on Journal Audit Socket.
out 21 13:21:25 lucas-pc systemd[1]: Listening on Journal Socket (/dev/log).
out 21 13:21:25 lucas-pc systemd[1]: Listening on Journal Socket.
out 21 13:21:25 lucas-pc systemd[1]: Listening on udev Control Socket.
out 21 13:21:25 lucas-pc systemd[1]: Listening on udev Kernel Socket.
out 21 13:21:25 lucas-pc systemd[1]: Mounting Huge Pages File System...
out 21 13:21:25 lucas-pc systemd[1]: Mounting POSIX Message Queue File System...
out 21 13:21:25 lucas-pc systemd[1]: Mounting Kernel Debug File System...
out 21 13:21:25 lucas-pc systemd[1]: Mounting Kernel Trace File System...
out 21 13:21:25 lucas-pc systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
out 21 13:21:25 lucas-pc systemd[1]: Mounting Temporary Directory /tmp...
out 21 13:21:25 lucas-pc systemd[1]: Starting Create List of Static Device Nodes...
out 21 13:21:25 lucas-pc systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
out 21 13:21:25 lucas-pc systemd[1]: Starting Load Kernel Module configfs...
out 21 13:21:25 lucas-pc systemd[1]: Starting Load Kernel Module drm...
out 21 13:21:25 lucas-pc systemd[1]: Starting Load Kernel Module fuse...
out 21 13:21:25 lucas-pc systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
out 21 13:21:25 lucas-pc systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
out 21 13:21:25 lucas-pc kernel: random: lvm: uninitialized urandom read (4 bytes read)
out 21 13:21:25 lucas-pc systemd[1]: Starting Journal Service...
out 21 13:21:25 lucas-pc systemd[1]: Starting Load Kernel Modules...
out 21 13:21:25 lucas-pc systemd[1]: Starting Remount Root and Kernel File Systems...
out 21 13:21:25 lucas-pc systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
out 21 13:21:25 lucas-pc systemd[1]: Starting Coldplug All udev Devices...
out 21 13:21:25 lucas-pc systemd[1]: Mounted Huge Pages File System.
out 21 13:21:25 lucas-pc systemd[1]: Mounted POSIX Message Queue File System.
out 21 13:21:25 lucas-pc systemd[1]: Mounted Kernel Debug File System.
out 21 13:21:25 lucas-pc systemd[1]: Mounted Kernel Trace File System.
out 21 13:21:25 lucas-pc systemd[1]: Mounted Temporary Directory /tmp.
out 21 13:21:25 lucas-pc systemd[1]: Finished Create List of Static Device Nodes.
out 21 13:21:25 lucas-pc systemd[1]: modprobe@configfs.service: Deactivated successfully.
out 21 13:21:25 lucas-pc systemd[1]: Finished Load Kernel Module configfs.
out 21 13:21:25 lucas-pc kernel: fuse: init (API version 7.34)
out 21 13:21:25 lucas-pc systemd[1]: Mounting Kernel Configuration File System...
out 21 13:21:25 lucas-pc systemd[1]: modprobe@fuse.service: Deactivated successfully.
out 21 13:21:25 lucas-pc systemd[1]: Finished Load Kernel Module fuse.
out 21 13:21:25 lucas-pc kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: (null). Quota mode: none.
out 21 13:21:25 lucas-pc systemd[1]: Mounting FUSE Control File System...
out 21 13:21:25 lucas-pc systemd[1]: Finished Remount Root and Kernel File Systems.
out 21 13:21:25 lucas-pc systemd[1]: Mounted Kernel Configuration File System.
out 21 13:21:25 lucas-pc systemd[1]: Condition check resulted in First Boot Wizard being skipped.
out 21 13:21:25 lucas-pc systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
out 21 13:21:25 lucas-pc systemd[1]: Starting Load/Save Random Seed...
out 21 13:21:25 lucas-pc kernel: Asymmetric key parser 'pkcs8' registered
out 21 13:21:25 lucas-pc systemd[1]: Starting Create System Users...
out 21 13:21:25 lucas-pc systemd[1]: Finished Load Kernel Modules.
out 21 13:21:25 lucas-pc systemd[1]: Mounted FUSE Control File System.
out 21 13:21:25 lucas-pc systemd[1]: Starting Apply Kernel Variables...
out 21 13:21:25 lucas-pc systemd[1]: modprobe@drm.service: Deactivated successfully.
out 21 13:21:25 lucas-pc systemd[1]: Finished Load Kernel Module drm.
out 21 13:21:25 lucas-pc systemd[1]: Finished Apply Kernel Variables.
out 21 13:21:25 lucas-pc kernel: audit: type=1130 audit(1634833285.614:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="syst>
out 21 13:21:25 lucas-pc systemd[1]: Finished Create System Users.
out 21 13:21:25 lucas-pc kernel: audit: type=1130 audit(1634833285.617:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysusers comm="sy>
out 21 13:21:25 lucas-pc systemd[1]: Starting Create Static Device Nodes in /dev...
out 21 13:21:25 lucas-pc systemd-journald[326]: Journal started
out 21 13:21:25 lucas-pc systemd-journald[326]: Runtime Journal (/run/log/journal/9cc18090d7f041608e211345657ad4cc) is 8.0M, max 795.9M, 787.9M free.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd>
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/syste>
out 21 13:21:25 lucas-pc systemd-modules-load[327]: Inserted module 'crypto_user'
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/syste>
out 21 13:21:25 lucas-pc systemd-modules-load[327]: Inserted module 'pkcs8_key_parser'
out 21 13:21:25 lucas-pc systemd-random-seed[334]: Kernel entropy pool is not initialized yet, waiting until it is.
out 21 13:21:25 lucas-pc systemd[1]: Starting Flush Journal to Persistent Storage...
out 21 13:21:25 lucas-pc systemd-journald[326]: Time spent on flushing to /var/log/journal/9cc18090d7f041608e211345657ad4cc is 3.520ms for 805 entries.
out 21 13:21:25 lucas-pc systemd-journald[326]: System Journal (/var/log/journal/9cc18090d7f041608e211345657ad4cc) is 3.8G, max 4.0G, 103.8M free.
out 21 13:21:25 lucas-pc systemd[1]: Started Journal Service.
out 21 13:21:25 lucas-pc kernel: audit: type=1130 audit(1634833285.627:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="sy>
out 21 13:21:25 lucas-pc kernel: audit: type=1130 audit(1634833285.630:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-de>
out 21 13:21:25 lucas-pc kernel: audit: type=1334 audit(1634833285.630:6): prog-id=14 op=LOAD
out 21 13:21:25 lucas-pc kernel: audit: type=1334 audit(1634833285.630:7): prog-id=15 op=LOAD
out 21 13:21:25 lucas-pc kernel: audit: type=1334 audit(1634833285.630:8): prog-id=16 op=LOAD
out 21 13:21:25 lucas-pc kernel: audit: type=1130 audit(1634833285.640:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm>
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr>
out 21 13:21:25 lucas-pc audit: BPF prog-id=14 op=LOAD
out 21 13:21:25 lucas-pc audit: BPF prog-id=15 op=LOAD
out 21 13:21:25 lucas-pc audit: BPF prog-id=16 op=LOAD
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/s>
out 21 13:21:25 lucas-pc systemd[1]: Finished Create Static Device Nodes in /dev.
out 21 13:21:25 lucas-pc systemd[1]: Starting Rule-based Manager for Device Events and Files...
out 21 13:21:25 lucas-pc systemd[1]: Finished Coldplug All udev Devices.
out 21 13:21:25 lucas-pc systemd[1]: Finished Flush Journal to Persistent Storage.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/>
out 21 13:21:25 lucas-pc kernel: audit: type=1130 audit(1634833285.657:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush co>
out 21 13:21:25 lucas-pc systemd[1]: Started Rule-based Manager for Device Events and Files.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/>
out 21 13:21:25 lucas-pc systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/s>
out 21 13:21:25 lucas-pc systemd[1]: Reached target Preparation for Local File Systems.
out 21 13:21:25 lucas-pc systemd[1]: Condition check resulted in Virtual Machine and Container Storage (Compatibility) being skipped.
out 21 13:21:25 lucas-pc systemd[1]: Mounting Mount unit for bare, revision 5...
out 21 13:21:25 lucas-pc systemd[1]: Mounting Mount unit for core18, revision 2128...
out 21 13:21:25 lucas-pc systemd[1]: Mounting Mount unit for discord, revision 130...
out 21 13:21:25 lucas-pc systemd[1]: Mounting Mount unit for gnome-3-28-1804, revision 161...
out 21 13:21:25 lucas-pc systemd[1]: Mounting Mount unit for gtk-common-themes, revision 1519...
out 21 13:21:25 lucas-pc systemd[1]: Mounting Mount unit for snapd, revision 13270...
out 21 13:21:25 lucas-pc systemd[1]: Mounting Mount unit for spotify, revision 53...
out 21 13:21:25 lucas-pc kernel: loop: module loaded
out 21 13:21:25 lucas-pc kernel: loop2: detected capacity change from 0 to 8
out 21 13:21:25 lucas-pc kernel: loop5: detected capacity change from 0 to 337424
out 21 13:21:25 lucas-pc kernel: loop0: detected capacity change from 0 to 133552
out 21 13:21:25 lucas-pc kernel: loop4: detected capacity change from 0 to 66368
out 21 13:21:25 lucas-pc kernel: loop3: detected capacity change from 0 to 169760
out 21 13:21:25 lucas-pc kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
out 21 13:21:25 lucas-pc systemd[1]: Mounted Mount unit for bare, revision 5.
out 21 13:21:25 lucas-pc systemd[1]: Mounted Mount unit for gnome-3-28-1804, revision 161.
out 21 13:21:25 lucas-pc systemd[1]: Mounted Mount unit for discord, revision 130.
out 21 13:21:25 lucas-pc systemd[1]: Mounted Mount unit for gtk-common-themes, revision 1519.
out 21 13:21:25 lucas-pc systemd[1]: Mounted Mount unit for snapd, revision 13270.
out 21 13:21:25 lucas-pc systemd[1]: Mounted Mount unit for core18, revision 2128.
out 21 13:21:25 lucas-pc kernel: loop6: detected capacity change from 0 to 331880
out 21 13:21:25 lucas-pc kernel: loop1: detected capacity change from 0 to 113536
out 21 13:21:25 lucas-pc systemd[1]: Mounted Mount unit for spotify, revision 53.
out 21 13:21:25 lucas-pc kernel: random: tlp-readconfs: uninitialized urandom read (4 bytes read)
out 21 13:21:25 lucas-pc systemd[1]: Found device ADATA SX6000LNP NO_LABEL.
out 21 13:21:25 lucas-pc systemd[1]: Starting File System Check on /dev/disk/by-uuid/0634-5C3C...
out 21 13:21:25 lucas-pc systemd-fsck[425]: fsck.fat 4.2 (2021-01-31)
out 21 13:21:25 lucas-pc systemd-fsck[425]: /dev/nvme0n1p1: 6 files, 74/130812 clusters
out 21 13:21:25 lucas-pc systemd[1]: Finished File System Check on /dev/disk/by-uuid/0634-5C3C.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-0634\x2d5C3C comm=>
out 21 13:21:25 lucas-pc systemd[1]: Mounting /boot/efi...
out 21 13:21:25 lucas-pc kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
out 21 13:21:25 lucas-pc kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
out 21 13:21:25 lucas-pc kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
out 21 13:21:25 lucas-pc kernel: e1000e: Intel(R) PRO/1000 Network Driver
out 21 13:21:25 lucas-pc kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
out 21 13:21:25 lucas-pc kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
out 21 13:21:25 lucas-pc kernel: i801_smbus 0000:00:1f.4: SPD Write Disable is set
out 21 13:21:25 lucas-pc kernel: i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
out 21 13:21:25 lucas-pc kernel: e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
out 21 13:21:25 lucas-pc kernel: i2c i2c-0: 1/4 memory slots populated (from DMI)
out 21 13:21:25 lucas-pc kernel: mei_me 0000:00:16.0: enabling device (0000 -> 0002)
out 21 13:21:25 lucas-pc kernel: i2c i2c-0: Successfully instantiated SPD at 0x53
out 21 13:21:25 lucas-pc systemd[1]: Mounted /boot/efi.
out 21 13:21:25 lucas-pc systemd[1]: Reached target Local File Systems.
out 21 13:21:25 lucas-pc systemd[1]: Starting Rebuild Dynamic Linker Cache...
out 21 13:21:25 lucas-pc systemd[1]: Starting Create Volatile Files and Directories...
out 21 13:21:25 lucas-pc kernel: input: PC Speaker as /devices/platform/pcspkr/input/input3
out 21 13:21:25 lucas-pc kernel: snd_hda_intel 0000:00:1f.3: enabling device (0400 -> 0402)
out 21 13:21:25 lucas-pc kernel: snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
out 21 13:21:25 lucas-pc kernel: snd_hda_intel 0000:01:00.1: Disabling MSI
out 21 13:21:25 lucas-pc kernel: snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
out 21 13:21:25 lucas-pc kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
out 21 13:21:25 lucas-pc kernel: RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
out 21 13:21:25 lucas-pc kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
out 21 13:21:25 lucas-pc kernel: RAPL PMU: hw unit of domain package 2^-14 Joules
out 21 13:21:25 lucas-pc kernel: RAPL PMU: hw unit of domain dram 2^-14 Joules
out 21 13:21:25 lucas-pc kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
out 21 13:21:25 lucas-pc systemd[1]: Finished Create Volatile Files and Directories.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib>
out 21 13:21:25 lucas-pc systemd[1]: Starting Rebuild Journal Catalog...
out 21 13:21:25 lucas-pc audit: BPF prog-id=17 op=LOAD
out 21 13:21:25 lucas-pc systemd[1]: Starting Network Time Synchronization...
out 21 13:21:25 lucas-pc systemd[1]: Starting Record System Boot/Shutdown in UTMP...
out 21 13:21:25 lucas-pc audit[457]: SYSTEM_BOOT pid=457 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/syst>
out 21 13:21:25 lucas-pc systemd[1]: Finished Record System Boot/Shutdown in UTMP.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/sy>
out 21 13:21:25 lucas-pc systemd[1]: Finished Rebuild Journal Catalog.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-catalog-update comm="systemd" exe=">
out 21 13:21:25 lucas-pc kernel: usb 1-2: New USB device found, idVendor=046d, idProduct=0825, bcdDevice= 5.62
out 21 13:21:25 lucas-pc kernel: usb 1-2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
out 21 13:21:25 lucas-pc kernel: usb 1-2: Product: C270 HD WEBCAM
out 21 13:21:25 lucas-pc systemd[1]: Started Network Time Synchronization.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/syst>
out 21 13:21:25 lucas-pc systemd[1]: Reached target System Time Set.
out 21 13:21:25 lucas-pc kernel: nvidia: loading out-of-tree module taints kernel.
out 21 13:21:25 lucas-pc kernel: nvidia: module license 'NVIDIA' taints kernel.
out 21 13:21:25 lucas-pc kernel: Disabling lock debugging due to kernel taint
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/syste>
out 21 13:21:25 lucas-pc systemd[1]: Finished Rebuild Dynamic Linker Cache.
out 21 13:21:25 lucas-pc systemd[1]: Starting Update is Completed...
out 21 13:21:25 lucas-pc systemd[1]: Finished Update is Completed.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/sy>
out 21 13:21:25 lucas-pc systemd[1]: Reached target System Initialization.
out 21 13:21:25 lucas-pc systemd[1]: Started Daily rotation of log files.
out 21 13:21:25 lucas-pc systemd[1]: Started Daily man-db regeneration.
out 21 13:21:25 lucas-pc systemd[1]: Started Monthly clean packages cache.
out 21 13:21:25 lucas-pc systemd[1]: Started Daily verification of password and group files.
out 21 13:21:25 lucas-pc systemd[1]: Started Daily Cleanup of Temporary Directories.
out 21 13:21:25 lucas-pc systemd[1]: Started Daily locate database update.
out 21 13:21:25 lucas-pc systemd[1]: Reached target Timer Units.
out 21 13:21:25 lucas-pc systemd[1]: Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
out 21 13:21:25 lucas-pc systemd[1]: Listening on D-Bus System Message Bus Socket.
out 21 13:21:25 lucas-pc systemd[1]: Starting Socket activation for snappy daemon...
out 21 13:21:25 lucas-pc systemd[1]: Listening on Socket activation for snappy daemon.
out 21 13:21:25 lucas-pc systemd[1]: Reached target Socket Units.
out 21 13:21:25 lucas-pc systemd[1]: Reached target Basic System.
out 21 13:21:25 lucas-pc systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
out 21 13:21:25 lucas-pc systemd[1]: Started D-Bus System Message Bus.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" >
out 21 13:21:25 lucas-pc systemd[1]: Starting Network Manager...
out 21 13:21:25 lucas-pc systemd[1]: Starting Snap Daemon...
out 21 13:21:25 lucas-pc audit: BPF prog-id=18 op=LOAD
out 21 13:21:25 lucas-pc audit: BPF prog-id=19 op=LOAD
out 21 13:21:25 lucas-pc audit: BPF prog-id=20 op=LOAD
out 21 13:21:25 lucas-pc systemd[1]: Starting User Login Management...
out 21 13:21:25 lucas-pc avahi-daemon[461]: Found user 'avahi' (UID 975) and group 'avahi' (GID 975).
out 21 13:21:25 lucas-pc avahi-daemon[461]: Successfully dropped root privileges.
out 21 13:21:25 lucas-pc avahi-daemon[461]: avahi-daemon 0.8 starting up.
out 21 13:21:25 lucas-pc NetworkManager[463]: <info>  [1634833285.9221] NetworkManager (version 1.32.12-1) is starting... (for the first time)
out 21 13:21:25 lucas-pc NetworkManager[463]: <info>  [1634833285.9221] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
out 21 13:21:25 lucas-pc kernel: cryptd: max_cpu_qlen set to 1000
out 21 13:21:25 lucas-pc kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
out 21 13:21:25 lucas-pc kernel: AVX2 version of gcm_enc/dec engaged.
out 21 13:21:25 lucas-pc kernel: AES CTR mode by8 optimization enabled
out 21 13:21:25 lucas-pc systemd-logind[466]: Watching system buttons on /dev/input/event2 (Power Button)
out 21 13:21:25 lucas-pc systemd-logind[466]: Watching system buttons on /dev/input/event1 (Power Button)
out 21 13:21:25 lucas-pc systemd-logind[466]: Watching system buttons on /dev/input/event0 (Sleep Button)
out 21 13:21:25 lucas-pc systemd-logind[466]: New seat seat0.
out 21 13:21:25 lucas-pc kernel: snd_hda_codec_realtek hdaudioC0D0: ALCS1200A: SKU not ready 0x00000000
out 21 13:21:25 lucas-pc kernel: snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALCS1200A: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
out 21 13:21:25 lucas-pc kernel: snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
out 21 13:21:25 lucas-pc kernel: snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
out 21 13:21:25 lucas-pc kernel: snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
out 21 13:21:25 lucas-pc kernel: snd_hda_codec_realtek hdaudioC0D0:    dig-out=0x11/0x0
out 21 13:21:25 lucas-pc kernel: snd_hda_codec_realtek hdaudioC0D0:    inputs:
out 21 13:21:25 lucas-pc kernel: snd_hda_codec_realtek hdaudioC0D0:      Front Mic=0x19
out 21 13:21:25 lucas-pc kernel: snd_hda_codec_realtek hdaudioC0D0:      Rear Mic=0x18
out 21 13:21:25 lucas-pc kernel: snd_hda_codec_realtek hdaudioC0D0:      Line=0x1a
out 21 13:21:25 lucas-pc systemd[1]: Started User Login Management.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd>
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/s>
out 21 13:21:25 lucas-pc systemd[1]: Started Avahi mDNS/DNS-SD Stack.
out 21 13:21:25 lucas-pc avahi-daemon[461]: Successfully called chroot().
out 21 13:21:25 lucas-pc avahi-daemon[461]: Successfully dropped remaining capabilities.
out 21 13:21:25 lucas-pc avahi-daemon[461]: No service file found in /etc/avahi/services.
out 21 13:21:25 lucas-pc avahi-daemon[461]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
out 21 13:21:25 lucas-pc avahi-daemon[461]: New relevant interface lo.IPv6 for mDNS.
out 21 13:21:25 lucas-pc avahi-daemon[461]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
out 21 13:21:25 lucas-pc avahi-daemon[461]: New relevant interface lo.IPv4 for mDNS.
out 21 13:21:25 lucas-pc avahi-daemon[461]: Network interface enumeration completed.
out 21 13:21:25 lucas-pc avahi-daemon[461]: Registering new address record for ::1 on lo.*.
out 21 13:21:25 lucas-pc avahi-daemon[461]: Registering new address record for 127.0.0.1 on lo.IPv4.
out 21 13:21:25 lucas-pc systemd[1]: Started Network Manager.
out 21 13:21:25 lucas-pc NetworkManager[463]: <info>  [1634833285.9346] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
out 21 13:21:25 lucas-pc systemd[1]: Reached target Network.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd>
out 21 13:21:25 lucas-pc systemd[1]: Starting Permit User Sessions...
out 21 13:21:25 lucas-pc NetworkManager[463]: <info>  [1634833285.9373] manager[0x55701cd94010]: monitoring kernel firmware directory '/lib/firmware'.
out 21 13:21:25 lucas-pc dbus-daemon[462]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1>
out 21 13:21:25 lucas-pc systemd[1]: Finished Permit User Sessions.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/>
out 21 13:21:25 lucas-pc systemd[1]: Started Simple Desktop Display Manager.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" >
out 21 13:21:25 lucas-pc audit: BPF prog-id=21 op=LOAD
out 21 13:21:25 lucas-pc audit: BPF prog-id=22 op=LOAD
out 21 13:21:25 lucas-pc audit: BPF prog-id=23 op=LOAD
out 21 13:21:25 lucas-pc kernel: nvidia-nvlink: Nvlink Core is being initialized, major device number 234
out 21 13:21:25 lucas-pc kernel: nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
out 21 13:21:25 lucas-pc systemd[1]: Starting Hostname Service...
out 21 13:21:25 lucas-pc snapd[465]: AppArmor status: apparmor not enabled
out 21 13:21:25 lucas-pc kernel: input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input4
out 21 13:21:25 lucas-pc kernel: input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input5
out 21 13:21:25 lucas-pc kernel: input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input6
out 21 13:21:25 lucas-pc kernel: input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input7
out 21 13:21:25 lucas-pc kernel: input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input8
out 21 13:21:25 lucas-pc kernel: input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input9
out 21 13:21:25 lucas-pc kernel: input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input10
out 21 13:21:25 lucas-pc kernel: input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
out 21 13:21:25 lucas-pc kernel: input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
out 21 13:21:25 lucas-pc kernel: input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
out 21 13:21:25 lucas-pc kernel: input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
out 21 13:21:25 lucas-pc kernel: input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
out 21 13:21:25 lucas-pc kernel: intel_tcc_cooling: Programmable TCC Offset detected
out 21 13:21:25 lucas-pc kernel: usb 1-3: new full-speed USB device number 4 using xhci_hcd
out 21 13:21:25 lucas-pc sddm[497]: Initializing...
out 21 13:21:25 lucas-pc sddm[497]: Starting...
out 21 13:21:25 lucas-pc sddm[497]: Logind interface found
out 21 13:21:25 lucas-pc snapd[465]: daemon.go:242: started snapd/2.53-1 (series 16; classic; devmode) endeavouros/ (amd64) linux/5.14.14-arch1-1.
out 21 13:21:25 lucas-pc dbus-daemon[462]: [system] Successfully activated service 'org.freedesktop.hostname1'
out 21 13:21:25 lucas-pc systemd[1]: Started Hostname Service.
out 21 13:21:25 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/syst>
out 21 13:21:25 lucas-pc kernel: e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
out 21 13:21:25 lucas-pc kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module  470.74  Mon Sep 13 23:09:15 UTC 2021
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0011] hostname: hostname: using hostnamed
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0011] hostname: hostname changed from (none) to "lucas-pc"
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0012] dns-mgr[0x55701cd4d250]: init: dns=default,systemd-resolved rc-manager=symlink
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0014] manager[0x55701cd94010]: rfkill: Wi-Fi hardware radio set enabled
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0014] manager[0x55701cd94010]: rfkill: WWAN hardware radio set enabled
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0081] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.32.12-1/libnm-dev>
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0088] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.32.12-1/libnm-devic>
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0093] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.32.12-1/libnm-devi>
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0096] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.32.12-1/libnm-devic>
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0099] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.32.12-1/libnm-devi>
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0137] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.32.12-1/libnm-devi>
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0139] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0139] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0139] manager: Networking is enabled by state file
out 21 13:21:26 lucas-pc kernel: loop7: detected capacity change from 0 to 8
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0145] dhcp-init: Using DHCP client 'internal'
out 21 13:21:26 lucas-pc dbus-daemon[462]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-di>
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0148] settings: Loaded settings plugin: keyfile (internal)
out 21 13:21:26 lucas-pc systemd[1]: Starting Network Manager Script Dispatcher Service...
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0165] device (lo): carrier: link connected
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0167] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0182] ovsdb: Could not connect: No such file or directory
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0183] ovsdb: disconnected from ovsdb
out 21 13:21:26 lucas-pc dbus-daemon[462]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
out 21 13:21:26 lucas-pc systemd[1]: Started Network Manager Script Dispatcher Service.
out 21 13:21:26 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/>
out 21 13:21:26 lucas-pc snapd[465]: daemon.go:335: adjusting startup timeout by 1m5s (pessimistic estimate of 30s plus 5s per snap)
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0512] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
out 21 13:21:26 lucas-pc kernel: e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) fc:34:97:7a:b3:61
out 21 13:21:26 lucas-pc kernel: e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
out 21 13:21:26 lucas-pc kernel: e1000e 0000:00:1f.6 eth0: MAC: 12, PHY: 12, PBA No: FFFFFF-0FF
out 21 13:21:26 lucas-pc systemd[1]: Started Snap Daemon.
out 21 13:21:26 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd">
out 21 13:21:26 lucas-pc systemd[1]: Reached target Multi-User System.
out 21 13:21:26 lucas-pc systemd[1]: Reached target Graphical Interface.
out 21 13:21:26 lucas-pc systemd[1]: Starting TLP system startup/shutdown...
out 21 13:21:26 lucas-pc kernel: nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  470.74  Mon Sep 13 22:59:50 UTC 2021
out 21 13:21:26 lucas-pc kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
out 21 13:21:26 lucas-pc kernel: [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
out 21 13:21:26 lucas-pc kernel: rtl8188ee 0000:02:00.0: enabling device (0000 -> 0003)
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0801] device (wlan0): driver supports Access Point (AP) mode
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.0805] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Device>
out 21 13:21:26 lucas-pc kernel: rtl8188ee: rtl8188ee: FW Power Save off (module option)
out 21 13:21:26 lucas-pc kernel: rtl8188ee: Using firmware rtlwifi/rtl8188efw.bin
out 21 13:21:26 lucas-pc kernel: ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
out 21 13:21:26 lucas-pc kernel: rtlwifi: rtlwifi: wireless switch is on
out 21 13:21:26 lucas-pc kernel: usb 1-3: New USB device found, idVendor=046d, idProduct=c542, bcdDevice= 3.02
out 21 13:21:26 lucas-pc kernel: usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
out 21 13:21:26 lucas-pc kernel: usb 1-3: Product: Wireless Receiver
out 21 13:21:26 lucas-pc kernel: usb 1-3: Manufacturer: Logitech
out 21 13:21:26 lucas-pc systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
out 21 13:21:26 lucas-pc systemd[1]: Starting Load/Save RF Kill Switch Status...
out 21 13:21:26 lucas-pc kernel: iTCO_vendor_support: vendor-support=0
out 21 13:21:26 lucas-pc kernel: asus_wmi: ASUS WMI generic driver loaded
out 21 13:21:26 lucas-pc kernel: ee1004 0-0053: 512 byte EE1004-compliant SPD EEPROM, read-only
out 21 13:21:26 lucas-pc kernel: asus_wmi: Initialization: 0x0
out 21 13:21:26 lucas-pc kernel: asus_wmi: BIOS WMI version: 0.9
out 21 13:21:26 lucas-pc kernel: asus_wmi: SFUN value: 0x0
out 21 13:21:26 lucas-pc kernel: eeepc-wmi eeepc-wmi: Detected ASUSWMI, use DCTS
out 21 13:21:26 lucas-pc kernel: input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input16
out 21 13:21:26 lucas-pc kernel: iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
out 21 13:21:26 lucas-pc kernel: iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
out 21 13:21:26 lucas-pc tlp[537]: Applying power save settings...done.
out 21 13:21:26 lucas-pc tlp[537]: Setting battery charge thresholds...done.
out 21 13:21:26 lucas-pc systemd[1]: Finished TLP system startup/shutdown.
out 21 13:21:26 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" h>
out 21 13:21:26 lucas-pc kernel: usb 1-11: new high-speed USB device number 5 using xhci_hcd
out 21 13:21:26 lucas-pc systemd[1]: Starting Save/Restore Sound Card State...
out 21 13:21:26 lucas-pc systemd[1]: Condition check resulted in Manage Sound Card State (restore and store) being skipped.
out 21 13:21:26 lucas-pc alsactl[704]: alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA Intel PCH at 0x4012020000 irq 138)
out 21 13:21:26 lucas-pc alsactl[704]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:0 use case configuration -6
out 21 13:21:26 lucas-pc alsactl[704]: alsa-lib parser.c:242:(error_node) UCM is not supported for this HDA model (HDA NVidia at 0x92080000 irq 17)
out 21 13:21:26 lucas-pc alsactl[704]: alsa-lib main.c:1405:(snd_use_case_mgr_open) error: failed to import hw:1 use case configuration -6
out 21 13:21:26 lucas-pc systemd[1]: Finished Save/Restore Sound Card State.
out 21 13:21:26 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/s>
out 21 13:21:26 lucas-pc systemd[1]: Reached target Sound Card.
out 21 13:21:26 lucas-pc systemd-udevd[406]: Using default interface naming scheme 'v249'.
out 21 13:21:26 lucas-pc kernel: e1000e 0000:00:1f.6 eno1: renamed from eth0
out 21 13:21:26 lucas-pc systemd-udevd[395]: Using default interface naming scheme 'v249'.
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.2746] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1b.0/00>
out 21 13:21:26 lucas-pc systemd[1]: Started Load/Save RF Kill Switch Status.
out 21 13:21:26 lucas-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd>
out 21 13:21:26 lucas-pc sddm[497]: Adding new display on vt 1 ...
out 21 13:21:26 lucas-pc sddm[497]: Loading theme configuration from ""
out 21 13:21:26 lucas-pc sddm[497]: Display server starting...
out 21 13:21:26 lucas-pc sddm[497]: Adding cookie to "/var/run/sddm/{28c43a88-da5a-4747-a27c-e05780d5c524}"
out 21 13:21:26 lucas-pc kernel: intel_rapl_common: Found RAPL domain package
out 21 13:21:26 lucas-pc kernel: intel_rapl_common: Found RAPL domain core
out 21 13:21:26 lucas-pc kernel: intel_rapl_common: Found RAPL domain dram
out 21 13:21:26 lucas-pc sddm[497]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{28c43a88-da5a-4747-a27c-e0578>
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.2843] device (eth0): interface index 2 renamed iface from 'eth0' to 'eno1'
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.2867] device (eno1): state change: unmanaged -> unavailable (reason 'managed', sys-ifac>
out 21 13:21:26 lucas-pc systemd-udevd[382]: Using default interface naming scheme 'v249'.
out 21 13:21:26 lucas-pc kernel: usb 1-11: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=60.90
out 21 13:21:26 lucas-pc kernel: usb 1-11: New USB device strings: Mfr=0, Product=1, SerialNumber=0
out 21 13:21:26 lucas-pc kernel: usb 1-11: Product: USB2.0 Hub
out 21 13:21:26 lucas-pc kernel: hub 1-11:1.0: USB hub found
out 21 13:21:26 lucas-pc kernel: hub 1-11:1.0: 4 ports detected
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.4749] settings: (eno1): created default wired connection 'Wired connection 1'
out 21 13:21:26 lucas-pc NetworkManager[463]: <info>  [1634833286.4755] device (wlan0): state change: unmanaged -> unavailable (reason 'managed', sys-ifa>
out 21 13:21:26 lucas-pc kernel: usb 1-11.3: new full-speed USB device number 6 using xhci_hcd
out 21 13:21:26 lucas-pc kernel: pcieport 0000:00:1b.0: AER: Corrected error received: 0000:00:1b.0
out 21 13:21:26 lucas-pc kernel: pcieport 0000:00:1b.0:   device [8086:a3e9] error status/mask=00000001/00002000
out 21 13:21:26 lucas-pc kernel: pcieport 0000:00:1b.0:    [ 0] RxErr                  (First)
out 21 13:21:26 lucas-pc kernel: pcieport 0000:00:1b.0: AER: can't find device of ID00d8
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 9 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 12 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 11 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 10 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 8 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 14 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 7 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 15 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 13 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 16 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 6 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 18 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 17 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 20 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 4 kernel messages
out 21 13:21:26 lucas-pc systemd-journald[326]: Missed 2 kernel messages
My only guess is that the install had some error cause by my internet on the kernel part, but I am really clueless here. Again, any help would be wonderful as I really wanted do keep EOS, but I am getting kind of frustrated.
if this would say not corrected I would bet on hardware issue… but afaik this will be something software sided…
Not caused by a faulty install, as installer would simply fail if it can not install a package.
I would like to see the system, specs:
So we can see what device is connected to the PCIe port that is having issues… it could be the GPU card.
And is may be related to the current kernel and/or nvidia driver packages, or an issue with your Bios and latest kernel.
I dedicated some time to discovering the issue and I have done some progress. @joekampdrad is right. The port 0000:00:1b.0 is having problem as shown by the crowd journalctl that I have saying this:
or
kernel: pcieport 0000:00:1b.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, >
It is generating so much logs that it is consuming a LOT of my cpu power. When I run lspci -tv I get:
-[0000:00]-+-00.0  Intel Corporation Device 9b43
           +-01.0-[01]--+-00.0  NVIDIA Corporation GA106 [GeForce RTX 3060 Lite Hash Rate]
           |            \-00.1  NVIDIA Corporation Device 228e
           +-14.0  Intel Corporation Comet Lake PCH-V USB Controller
           +-16.0  Intel Corporation Device a3ba
           +-17.0  Intel Corporation 400 Series Chipset Family SATA AHCI Controller
           +-1b.0-[02]----00.0  Realtek Semiconductor Co., Ltd. RTL8188EE Wireless Network Adapter
           +-1b.4-[03]----00.0  Realtek Semiconductor Co., Ltd. Device 5765
           +-1c.0-[04]--
           +-1d.0-[05]--
           +-1f.0  Intel Corporation Device a3c8
           +-1f.2  Intel Corporation Memory controller
           +-1f.3  Intel Corporation Device a3f0
           +-1f.4  Intel Corporation Comet Lake PCH-V SMBus Host Controller
           \-1f.6  Intel Corporation Ethernet Connection (12) I219-V
So it seems to be something with my RTL8188EE Wireless Network Adapter. The wifi is working, though very slow with some frequent disconnects. Is there a way to find if it is a problem with the hardware itself or some driver? Well, this at least explains the problems I had with the install, it really had a bad internet access.
`inxi -Fxxc0z | eos-sendlog`
System:    Kernel: 5.14.14-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.23.1
           tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM Distro: EndeavourOS base: Arch Linux
Machine:   Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
           Mobo: ASUSTeK model: TUF GAMING B460M-PLUS v: Rev 1.xx serial: <filter> UEFI: American Megatrends
           v: 1101 date: 01/15/2021
Battery:   Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter>
           charge: 55% (should be ignored) status: Discharging
CPU:       Info: 8-Core model: Intel Core i7-10700KF bits: 64 type: MT MCP arch: Comet Lake rev: 5 cache:
           L2: 16 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 121639
           Speed: 4811 MHz min/max: 800/5100 MHz Core speeds (MHz): 1: 4811 2: 4740 3: 4892 4: 4877 5: 4887
           6: 4806 7: 4778 8: 4774 9: 4894 10: 4854 11: 4892 12: 4728 13: 4879 14: 4783 15: 4801 16: 4860
Graphics:  Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] driver: nvidia v: 470.74 bus-ID: 01:00.0
           chip-ID: 10de:2504
           Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-2:3
           chip-ID: 046d:0825
           Display: x11 server: X.org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia
           resolution: <missing: xdpyinfo>
Audio:     Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a3f0
           Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:228e
           Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-2:3
           chip-ID: 046d:0825
           Sound Server-1: ALSA v: k5.14.14-arch1-1 running: yes
           Sound Server-2: JACK v: 1.9.19 running: no
           Sound Server-3: PulseAudio v: 15.0 running: yes
           Sound Server-4: PipeWire v: 0.3.38 running: no
Network:   Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: efa0 bus-ID: 00:1f.6
           chip-ID: 8086:0d55
           IF: eno1 state: down mac: <filter>
           Device-2: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee v: kernel port: 3000
           bus-ID: 02:00.0 chip-ID: 10ec:8179
Drives:    Local Storage: total: 1.39 TiB used: 14.09 GiB (1.0%)
           ID-1: /dev/nvme0n1 vendor: A-Data model: SX6000LNP size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
           serial: <filter> temp: 33.9 C
           ID-2: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB speed: 6.0 Gb/s
           serial: <filter>
           ID-3: /dev/sdb type: USB vendor: SanDisk model: Cruzer Blade size: 14.32 GiB serial: <filter>
Partition: ID-1: / size: 467.88 GiB used: 14.09 GiB (3.0%) fs: ext4 dev: /dev/nvme0n1p2
           ID-2: /boot/efi size: 511 MiB used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1
Swap:      Alert: No swap data was found.
Sensors:   System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 32 C
           Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
Info:      Processes: 293 Uptime: 21m Memory: 15.55 GiB used: 2.14 GiB (13.8%) Init: systemd v: 249 Compilers:
           gcc: 11.1.0 Packages: 1029 pacman: 1022 snap: 7 Shell: Bash v: 5.1.8 running-in: konsole
           inxi: 3.3.06
EDIT: I tried booting from the pendrive into Manjaro and Ubuntu and the error persists there, so I am pretty much sure it is something hardware problem, related with the wifi adapter.
You have r8168 driver installed?
You should uninstal it. It is causing strange issues currently. And could be other Distros using the same.
If the WiFi is a plugged can d you could try removing it.
If not possible to deactivate it in Bios.
How do I know if this driver is installed? I tried lspci -v and it says
Kernel driver is use: rtl8188ee
Kernel modules: rtl8188ee
but I am not sure if this is what you wanted. And if I do uninstall it, I suppose I would not be able to use the wifi adapter as well, which would not be ideal, as I am currently using only wifi.
this will show if this one is installed pacman -Qs r8168
In this case, yes, it is installed.
I read that using r8169 may solve the problem as per https://forum.endeavouros.com/t/solved-installation-realtek-modules-r8168-and-r8169/5658, but I have no idea how to even do that and if it will help or not.
Simple by uninstalling r8168 package… If installed it blacklist r8169
and you can load unload the modules:
unloading:
sudo rmmod r8168
loading:
sudo modprobe r8169
You don’t have r8168 card, so you can safely uninstall r8168:
sudo pacman -Rsn r8168
and reboot.
Then, with command
lsmod | grep "r816"
you can see if the machine has r8168/r8169 related kernel modules.
Your chip doesn’t use r8168 or r8169 kernel module. It uses module rtl8188ee kernel module.
Edit: You should be able to remove the r8168 as stated
yes i do start mentioning the r8168 driver only because it seems that having it installed interfere to some other realtek drivers/cards/chipsets
the two threads are a bit mixed up… Problem with Realtek RTL8188EE Wireless Adapter and r8168 - #3 by ricklinux
