Hello,
I am at my wits end with this issue. It’s been an ongoing issue through multiple distros. The goal is running League of Legends on my dGPU.
I am running EOS on an Asus laptop with an Intel UHD 620 integrated graphics + GeForce MX150 combo, but I cannot get the switching to work. I’ve tried multiple approaches:
- Installing drivers thorugh
nvidia-instand bumblebee, later disabling that and installingoptimus-manager, i.e., this guide. - Tried installing
nvidia-dkmsby itself and running withoptimus-manager. - Tried the above methods but with
envycontrolinstead. This lead to my laptop display being turned off completely (no backlight). - I even tried asking ChatGPT who told me to install
nvidiaandnvidia-utilsand run withoptimus-manager(this was the closest to actually work).
So what are my issues?
When trying to switch to nvidia graphics through optimus-manager and relogging, LightDM failes to start. I can only see a cursor blinking and there might be a failure in Xorg.
When trying the ChatGPT route I can actually log in and by running glxinfo | grep 'renderer string' I can see that the Nvidia card is being used. However, after some time, the whole laptop is frozen and I have to choke it to reboot.
Output from inxi -Ga:
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: HDMI-A-2,eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: ASUSTeK driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d10 class-ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 13d3:5694 class-ID: 0e02 serial: 0x0001
Display: x11 server: X.Org v: 21.1.6 compositor: Picom v: git-b700a
driver: X: loaded: modesetting dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-2 mapped: HDMI-2 pos: right model: HP E233
serial: CNC8520YSK built: 2018 res: 1920x1080 hz: 60 dpi: 96 gamma: 1.2
size: 509x286mm (20.04x11.26") diag: 584mm (23") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: eDP-1 pos: primary,left model: BOE Display 0x0718 built: 2016
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) direct render: Yes
uname -r:
6.0.12-arch1-1
pacman -Qs nvidia:
local/egl-wayland 2:1.1.11-2
EGLStream-based Wayland external platform
local/lib32-nvidia-utils 525.60.11-1
NVIDIA drivers utilities (32-bit)
local/libvdpau 1.5-1
Nvidia VDPAU library
local/libxnvctrl 525.60.11-2
NVIDIA NV-CONTROL X extension
local/nvidia 525.60.11-3
NVIDIA drivers for linux
local/nvidia-inst 1.8-1
Script to setup nvidia drivers (dkms version) in EndeavourOS
local/nvidia-installer-common 1.7-2
Common scripts for nvidia-installer-dkms and nvidia-inst
local/nvidia-utils 525.60.11-1
Just let me know if you want any more information,
Thanks!
