Problem with Steam Games Crashing
mesa 1:24.2.3-1
error: package 'lib32-vulkan-radeon' was not found error: package ‘amdvlk’ was not found rror: package ‘lib32-amdvlk’ was not found`
Alright. Please install lib32-vulkan-radeon and see what happens.
mesa 1:24.2.3-1
lib32-vulkan-radeon 1:24.2.3-1
error: package ‘lib32-amdvlk’ was not found
Great. See now if Steam games launch and work, using the normal Steam; The one that lets you install games but not launch them.
start launching and then just exit after 10 seconds
Alright. The game you presented seems to require you manually install DirectX11 for it to work. I will try something else: go to settings and then compatibility and see what proton version is present.
and in Winetricks i have installed DirectX11
Try Experimental.
same happening
Does that happen on every single game still?
yes, i have now install Subnautica, Pure Farming 2018, Metro 2033, Medal of Honor, Car Mechanic Simulator 2018
Damn… This beats me, honestly… Hopefully someone else comes up and helps out…
i tried those stuff, and this happening, i hope…
i tried now Broforce, Stardew Valley and minecraft, those 3 games are working
Try installing protonup-qt and adding the GE versions of Proton to Steam.
from Flathub or?
Whatever is your preference, it shouldn’t really matter.
I thought it matter, i will do that now
Those games are native. Seems like a Proton issue.
