I’m trying to play games, I start a game and just crash
Game start launching and just crash, I don’t know how to fix it, i’m new to arch linux and with, I’m trying to learn.
Firstly, how did you install Steam?
Secondly, please send the output of the command inxi -Fxxc0z
Thirdly, what game(s)?
Are you using Proton?
I’m using proton 9.0.3. downloaded via steam
Kernel: 6.6.52-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop System: Gigabyte product: N/A v: N/A
serial: Chassis: type: 3 serial:
Mobo: Gigabyte model: H61M-HD2 v: x.x serial:
BIOS: American Megatrends v: F3 date: 04/17/2013
Info: quad core model: Intel Core i7-3770 bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 1597 min/max: 1600/3900 cores: 1: 1597 2: 1597 3: 1597
4: 1597 5: 1597 6: 1597 7: 1597 8: 1597 bogomips: 54296
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
470/480/570/570X/580/580X/590] vendor: Sapphire driver: amdgpu v: kernel
arch: GCN-4 pcie: speed: 8 GT/s lanes: 16 ports: active: DVI-D-1,HDMI-A-1
empty: DP-1 bus-ID: 01:00.0 chip-ID: 1002:67df temp: 49.0 C
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_wayland driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3840x1080
display-ID: 0
Monitor-1: DVI-D-1 pos: right res: 1920x1080 size: N/A
Monitor-2: HDMI-A-1 pos: primary,left res: 1920x1080 size: N/A
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast
gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11:
drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 570 Series (radeonsi
polaris10 LLVM 18.1.8 DRM 3.54 6.6.52-1-lts) device-ID: 1002:67df
display-ID: :1.0
API: Vulkan v: 1.3.295 surfaces: xcb,xlib,wayland device: 0
type: discrete-gpu driver: mesa radv device-ID: 1002:67df
Device-1: Intel 6 Series/C200 Series Family High Definition Audio
vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20
Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon
RX 470/480 / 570/580/590] vendor: Sapphire driver: snd_hda_intel v: kernel
pcie: speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0
API: ALSA v: k6.6.52-1-lts status: kernel-api
Server-1: PipeWire v: 1.2.4 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Gigabyte driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac:
Local Storage: total: 1.71 TiB used: 146.51 GiB (8.4%)
ID-1: /dev/sda vendor: Kingston model: SKC600256G size: 238.47 GiB
speed: 3.0 Gb/s serial:
ID-2: /dev/sdb vendor: Western Digital model: WD10EZRX-00A8LB0
size: 931.51 GiB speed: 3.0 Gb/s serial:
ID-3: /dev/sdc vendor: Kingston model: SA400S37120G size: 111.79 GiB
ID-4: /dev/sdd vendor: Hitachi model: HDS721050CLA362 size: 465.76 GiB
ID-1: / size: 233.67 GiB used: 56.32 GiB (24.1%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 39.0 C mobo: N/A gpu: amdgpu temp: 49.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 1468
I installed steam with console
I tried to play: Car Mechanic Simulator 2018, Castle Flipper, Medal of Honor, Metro 2033, Pure Farming 2018.
Before EndeavourOS i had Linux Mint Cinnamon, and those games worked on Mint.
I have installed the flatpak version of Steam:
and my games run
i had a problem with flatpack version, i cannot add other HDD and SSD on steam and if connect i got ‘‘Disk Write Error’’
Try using flatseal to grant permission to the steam flatpack for your other drives
now steam won’t open
That’s not very descriptive, to be honest. When you installed Steam, what command of these two did you use:
sudo pacman -S steamflatpak install steam
both, but with flatpack version have problem loading 2 HDD and 1 SSD on steam
sudo pacman -S steam with this command i can install games but can not play it
Can you please show the output of the following the command:
pacman -Q vulkan-radeon
I was about to say that could this be Vulkan related.
It’s possible he picked the wrong 32-bit Vulkan package or that doesn’t even have the Vulkan related packages installed. Let’s see if my hunch is correct and pray we can help him.
it’s showing me only
vulkan-radeon 1:24.2.3-1
I’m hoping we all can figure to fix this, tbh i’m sick of windows and windows stutering everyday
Good. pacman -Q shows the version of a package if it is installed. Now, what’s the output of this:
pacman -Q mesa lib32-vulkan-radeon amdvlk lib32-amdvlk
I hope I can help out.
