Problem with NM-PPTP
Fresh install system. Just create a new VPN connection with NetworkManager PPTP using KDE interface.
My journalctl after trying to connect, what problem it can be?
авг 02 22:43:39 rnw-pc plasmashell[1287]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for>
авг 02 22:43:38 rnw-pc pptp[8785]: nm-pptp-service-8768 log[ctrlp_disp:pptp_ctrl.c:938]: Outgoing call established (call ID 26838, peer's call ID 320).
авг 02 22:43:38 rnw-pc pptp[8785]: nm-pptp-service-8768 log[ctrlp_disp:pptp_ctrl.c:900]: Received Outgoing Call Reply.
авг 02 22:43:38 rnw-pc pptp[8785]: nm-pptp-service-8768 log[ctrlp_rep:pptp_ctrl.c:258]: Sent control packet type is 7 'Outgoing-Call-Request'
авг 02 22:43:37 rnw-pc pptp[8785]: nm-pptp-service-8768 log[ctrlp_disp:pptp_ctrl.c:815]: Client connection established.
авг 02 22:43:37 rnw-pc pptp[8785]: nm-pptp-service-8768 log[ctrlp_disp:pptp_ctrl.c:781]: Received Start Control Connection Reply
авг 02 22:43:37 rnw-pc pptp[8785]: nm-pptp-service-8768 log[ctrlp_rep:pptp_ctrl.c:258]: Sent control packet type is 1 'Start-Control-Connection-Request'
авг 02 22:43:37 rnw-pc pptp[8778]: nm-pptp-service-8768 log[main:pptp.c:353]: The synchronous pptp option is NOT activated
авг 02 22:43:37 rnw-pc NetworkManager[1026]: <info>  [1691005417.0656] manager: (ppp0): new Ppp device (/org/freedesktop/NetworkManager/Devices/30)
авг 02 22:43:37 rnw-pc NetworkManager[8774]: Connect: ppp0 <--> /dev/pts/2
авг 02 22:43:37 rnw-pc pppd[8774]: Connect: ppp0 <--> /dev/pts/2
авг 02 22:43:37 rnw-pc NetworkManager[8774]: Using interface ppp0
авг 02 22:43:37 rnw-pc pppd[8774]: Using interface ppp0
авг 02 22:43:37 rnw-pc pppd[8774]: pppd 2.4.9 started by root, uid 0
авг 02 22:43:37 rnw-pc NetworkManager[8774]: Plugin /usr/lib/pppd/2.4.9/nm-pptp-pppd-plugin.so loaded.
авг 02 22:43:37 rnw-pc pppd[8774]: Plugin /usr/lib/pppd/2.4.9/nm-pptp-pppd-plugin.so loaded.
авг 02 22:43:37 rnw-pc kded5[1246]: org.kde.plasma.nm.kded: Unhandled VPN connection state change:  NetworkManager::VpnConnection::Connecting
авг 02 22:43:37 rnw-pc kdeconnectd[1437]: "Объект по пути «/org/freedesktop/NetworkManager/ActiveConnection/2» не существует"
авг 02 22:43:37 rnw-pc kded5[1246]: "Объект по пути «/org/freedesktop/NetworkManager/ActiveConnection/2» не существует"
авг 02 22:43:37 rnw-pc kded5[1246]: org.kde.plasma.nm.kded: Unhandled VPN connection state change:  NetworkManager::VpnConnection::NeedAuth
авг 02 22:43:37 rnw-pc NetworkManager[1026]: <info>  [1691005417.0483] audit: op="connection-activate" uuid="8ac38004-0a5e-4b66-93c7-0b16d448298a" name="Но>
@RinWate
Welcome! Please try to use code tags around the output you post to make it easier to decipher.
Oh sorry, ok!
Not sure i can help yo with that. I don’t use any vpn. It looks like it needs authentication?
I also thought so, but I set the authorization data in the connection settings. I came to Endeavor OS from Debian KDE. In Debian, the same problem was due to the fact that I had ufw enabled. In Endeavour OS i don’t have ufw installed :frowning:
And i thought i have problems with routing, or port forwarding, idk
P.S. My language is not perfect, cause English is not my main language, sorry for that…
In this topic: Failing to connect to windows-based VPN (PPTP/L2TP)
User is fixed that problem, but i can’t figure out how he do this
EndeavourOS does have a firewall so you may need to set the settings to allow the vpn access.
https://discovery.endeavouros.com/applications/firewalld/2022/03/
Oh my god, thank you so much! Problem was in settings of firewalld…
This solution is helped: https://serverok.in/allow-pptp-vpn-connection-on-firewalld
