I installed lutris the other day and had some problems running it, it gave me some errors and I managed to solve them the only one that remained is this one:
Please check ownership/permissions using:
cd .local/share/icons
ls -l
I get the following:
Try changing icons to default and run ? As it looks that your icons , like whatever custom icons you are using are not having certain icons/are denying lutris some permissions . I also had somewhat similar issue with Infinity Glass Icons on KDE Plasma. Sometimes not having a certain type of icon can also cause lutris to crash.
A good solution would be to stick to default icons oruse a vast well-reputed icon pack e.g papirus, qoogir,etc.
Also please cd into the .icons folder, run ls -a and post the output.
I’m using Qogir
what’s posy_cursor ? Anyways , you on KDE ?
In the icons directory , run sudo chmod -R +rw hicolor
they are a custom cursor. I’m on xfce btw.
Run the command and see if fixes lutris.
it says there is no such file or directory
Wait a sec.
So while installing lutris , it must have asked you for choosing a desktop portal package , like xdg-desktop-portal-kde, etc. Which one did you choose ?
I don’t remember it asking, sorry I just installed it through Yay
okay then , according to an old thread here : https://forums.lutris.net/t/solved-lutris-wont-start-on-manjaro-18-0-4-kde/6143
1.Try installing the appmenu-gtk-module
2.Create a directory in the icons folder named hicolor.
3.Run the command I gave you earlier after cd-ing into the icons folder.
well strange , try running sudo pacman -R xdg-desktop-portal-gnome && sudo pacman -S xdg-desktop-portal-kde kdialog
Alternatively you should run sudo pacman -R xdg-desktop-portal-gnome && sudo pacman -S xdg-desktop-portal-gtk
instead if on XFCE
remove everything before && along with && and run the second command. Along with the output .
And please paste the text output .
ok it installed the thing
[hectorm@Seren icons]$ sudo pacman -S xdg-desktop-portal-gtk
resolving dependencies...
Package (1) New Version Net Change Download Size
extra/xdg-desktop-portal-gtk 1.15.1-1 0,45 MiB 0,11 MiB
Total Download Size: 0,11 MiB
Total Installed Size: 0,45 MiB
:: Proceed with installation? [Y/n]
:: Retrieving packages...
xdg-desktop-portal-gtk-1.15.1-1-x86_64 112,4 KiB 450 KiB/s 00:00 [----------------------------------------------] 100%
(1/1) checking keys in keyring [----------------------------------------------] 100%
(1/1) checking package integrity [----------------------------------------------] 100%
(1/1) loading package files [----------------------------------------------] 100%
(1/1) checking for file conflicts [----------------------------------------------] 100%
:: Processing package changes...
(1/1) installing xdg-desktop-portal-gtk [----------------------------------------------] 100%
Optional dependencies for xdg-desktop-portal-gtk
evince: Print preview
(1/3) Reloading user manager configuration...
(2/3) Arming ConditionNeedsUpdate...
(3/3) Updating the desktop file MIME type cache...
Now try running lutris.
still the same error
[hectorm@Seren icons]$ lutris
2024-03-24 23:28:53,575: Starting Lutris 0.5.16
File "/usr/lib/python3.11/site-packages/lutris/gui/application.py", line 480, in do_command_line
init_lutris()
File "/usr/lib/python3.11/site-packages/lutris/startup.py", line 155, in init_lutris
init_dirs()
File "/usr/lib/python3.11/site-packages/lutris/startup.py", line 45, in init_dirs
create_folder(directory)
File "/usr/lib/python3.11/site-packages/lutris/util/system.py", line 401, in create_folder
os.makedirs(path, exist_ok=True)
File "<frozen os>", line 215, in makedirs
File "<frozen os>", line 225, in makedirs
PermissionError: [Errno 13] Permission denied: '/home/hectorm/.local/share/icons/hicolor/128x128'
2024-03-24 23:28:53,578: Shutting down Lutris
Perhaps try removing appmenu-gtk-module
