HP Linux Imaging and Printing System (ver. 3.22.10)
Printer/Fax Setup Utility ver. 9.0
Copyright (c) 2001-18 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
(Note: Defaults for each question are maked with a ‘*’. Press to accept the default.)
SELECT CONNECTION (I/O) TYPE
Num Connection Description
Type
0* usb Universal Serial Bus (USB)
1 net Network/Ethernet/Wireless (direct connection or JetDirect)
2 par Parallel Port (LPT:)
Enter number 0…2 for connection type (q=quit, enter=usb*) ? 1
Using connection type: net
error: No device selected/specified or that supports this functionality.
[kiran@kiran-81w4 ~]$
There’s two options. I wasn’t sure of the HP printing option as i never used it before. I always select printing which installs cups and related packages.
Edit: I guess it probably installs printing support geared towards HP?
I’m sure it’s just a matter of how one goes through the setup to install the printer. Hp is a little different so i hear. I use brother and a canon but both are usb not network printers.
Well as I said I’m not sure what gets installed when you select the HP printer support on the installer. I am assuming it installs hplip? Or is it just installing the HP setup utility?
I’m trying to setup a priter with the print settings ui, and it gives me this cups server error. I have hplip and cups installed. Are there any logs I can give for this?
