Can you use code tags around the output?
I see here message.
Dec 24 19:17:29 kiran-81w4 cupsd[544]: pam_unix(cups:auth): check pass; user unknown
Dec 24 19:17:29 kiran-81w4 cupsd[544]: pam_unix(cups:auth): authentication failure; logname= uid=0
euid=0 tty=cups ruser= rhost=localhost```
Try running these each one line at a time.
sudo pacman -S avahi --needed
sudo systemctl start avahi-daemon
sudo systemctl enable avahi-daemon
[sudo] password for kiran:
Sorry, try again.
warning: avahi-0.8+22+gfd482a7-3 is up to date -- skipping
there is nothing to do
[kiran@kiran-81w4 ~]$ sudo systemctl start avahi-daemon
[kiran@kiran-81w4 ~]$ sudo systemctl enable avahi-daemon
Check if running
systemctl status avahi-daemon
Loaded: loaded (/usr/lib/systemd/system/avahi-daemon.service; enabled; preset: disabled)
Active: active (running) since Sat 2022-12-24 18:58:01 EST; 42min ago
TriggeredBy: ● avahi-daemon.socket
Main PID: 490 (avahi-daemon)
Status: "avahi-daemon 0.8 starting up."
Tasks: 2 (limit: 8732)
Memory: 2.1M
CPU: 446ms
CGroup: /system.slice/avahi-daemon.service
├─490 "avahi-daemon: running [kiran-81w4.local]"
└─496 "avahi-daemon: chroot helper"
Dec 24 18:58:07 kiran-81w4 avahi-daemon[490]: New relevant interface wlan0.IPv6 for mDNS.
Dec 24 18:58:07 kiran-81w4 avahi-daemon[490]: Registering new address record for fe80::b985:dc91:45e5:9641 on wlan0.*.
Dec 24 18:58:07 kiran-81w4 avahi-daemon[490]: Joining mDNS multicast group on interface wlan0.IPv4 with address 10.0.0.27.
Dec 24 18:58:07 kiran-81w4 avahi-daemon[490]: New relevant interface wlan0.IPv4 for mDNS.
Dec 24 18:58:07 kiran-81w4 avahi-daemon[490]: Registering new address record for 10.0.0.27 on wlan0.IPv4.
Dec 24 18:58:09 kiran-81w4 avahi-daemon[490]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::b985:dc91:45e5:9641.
Dec 24 18:58:09 kiran-81w4 avahi-daemon[490]: Joining mDNS multicast group on interface wlan0.IPv6 with address 2607:fa49:5c40:c700:89c3:7184:41cd:108e.
Dec 24 18:58:09 kiran-81w4 avahi-daemon[490]: Registering new address record for 2607:fa49:5c40:c700:89c3:7184:41cd:108e on wlan0.*.
Dec 24 18:58:09 kiran-81w4 avahi-daemon[490]: Withdrawing address record for fe80::b985:dc91:45e5:9641 on wlan0.
Dec 24 18:58:09 kiran-81w4 avahi-daemon[490]: Registering new address record for 2607:fa49:5c40:c700::6198 on wlan0.*.
Check this also
pacman -Qs nss-mdn
local/nss-mdns 0.15.1-1
glibc plugin providing host name resolution via mDNS
at this point i might just connect it to my moms windows computer
Did you edit the file in /etc/nsswitch.conf
no
# See nsswitch.conf(5) for details.
passwd: files systemd
group: files [SUCCESS=merge] systemd
shadow: files systemd
gshadow: files systemd
publickey: files
hosts: mymachines resolve [!UNAVAIL=return] files myhostname dns
networks: files
protocols: files
services: files
ethers: files
rpc: files
netgroup: files```
yeah i think ill just send it to windows
Like this.
Edit: Then restart the service
sudo systemctl restart avahi-daemon NetworkManager
Edit2: Then try the printer setup again.
You may have to make one more setting for the firewall if it’s blocking mdns. It’s on the page in the wiki i posted. Just follow that and should work.
My computer wont boot now. I ended up just connecting to a windows pc and doing it. thanks for the help
Don’t know why that would be? ![]()
