I installed 580xx driver from the AUR and it seems to work very well. Much better than nouveau. Nouveau mostly works but is much slower than 580xx.
Xfce seems to be the problem now, Plasma works well.
It is hard to tell how long 580xx will be usable, but I’d guess a few years from now.
The Arch team has published this just a few minutes ago related to the 590.* driver series, I thought it won’t hurt to create an official announcement for those being affected, as it would require manual intervention.
I was going to try to do a new GNOME install with the GTX 1060 Haswell mini tower, have only used KDE in the past with old Intel integrated laptops, so hopefully it will work, will need to report back, just to try something different
I assume with the install media, I should pick the default non-Nvidia option, then install nvidia-inst and the 580 drivers from the AUR afterwards?
just for your info :
all video nvidia card series 900 / 1000 will stay with this 580 version that just ended with a serie of bug
they cant use after nvidia-open because that concerns
only serie 1650 or more nvidia cards
only wayland
so nvidia prove that they cannot freeze on end a version driver stable for a long term
they are many desktop & laptops with theses series cards
