Possible Kernel/Grub/systemd Shutdown Error Message
No shutdown issues on my Nvidia :wink:
https://clbin.com/27eWl
Hi Rick,
Did you run ā€œjournalctl -e -b-1ā€ to capture the shutdown logs?
Thanks.
yes…
Generally in my case (no Nvidia) the system only hangs on shutdown if i have a long kernel boot time. Otherwise my laptop shutsdown gracefully.
I’m not confident Nvidia is related to what @Scotty_Trees is experiencing.
It’s more than likely related to systemd
More than likely it’s Gnome thing! :laughing: Touche’
It’s probably because I have a bunch of KDE packages install!
:wink:
What you converted? :scream:
To put an end to this eternal DE feud, there should be a new DE: Knome or Glasma or some such :stuck_out_tongue_winking_eye:
No feud. It’s just a little bit oh fun! :wink: :innocent:
So to recap, we all agree Gnome is okay and this shutdown error is more than likely systemd related :wink:
There’s not much else to do or try right now, but if any new systemd updates fix this issue, I’ll be sure to let this thread know.
Hello!
First of all, sorry for raising this thread.
I also had the same problem when shutting down the OS.
I use the latest version of Endeavouros+Kde-Plasma and sometimes I get these messages when shutting down.
My computer does not have NVDIA graphics card, do you know why this can happen?
Attached is this photo with evidence of the shutdown.
Failshutdown
Regards
I’m not sure how having an Nvidia card is related? My shutdown log on kde.
[ricklinux@kde-plasma ~]$ journalctl -e -b-1
Oct 09 13:08:48 kde-plasma systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
Oct 09 13:08:48 kde-plasma systemd[1]: systemd-timesyncd.service: Deactivated successfully.
Oct 09 13:08:48 kde-plasma systemd[1]: Stopped Network Time Synchronization.
Oct 09 13:08:48 kde-plasma audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=system>
Oct 09 13:08:48 kde-plasma audit[14291]: SYSTEM_SHUTDOWN pid=14291 uid=0 auid=4294967295 ses=4294967295 msg='>
Oct 09 13:08:48 kde-plasma systemd[1]: systemd-update-utmp.service: Deactivated successfully.
Oct 09 13:08:48 kde-plasma systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
Oct 09 13:08:48 kde-plasma systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
Oct 09 13:08:48 kde-plasma systemd[1]: Stopped Create Volatile Files and Directories.
Oct 09 13:08:48 kde-plasma systemd[1]: Stopped target Local File Systems.
Oct 09 13:08:48 kde-plasma systemd[1]: Unmounting /boot/efi...
Oct 09 13:08:48 kde-plasma systemd[1]: Unmounting /home...
Oct 09 13:08:48 kde-plasma systemd[1]: Unmounting /run/credentials/systemd-sysusers.service...
Oct 09 13:08:48 kde-plasma systemd[1]: Unmounting Temporary Directory /tmp...
Oct 09 13:08:48 kde-plasma systemd[1]: Unmounting /var/cache...
Oct 09 13:08:48 kde-plasma systemd[1]: Stopping Flush Journal to Persistent Storage...
Oct 09 13:08:48 kde-plasma systemd[1]: boot-efi.mount: Deactivated successfully.
Oct 09 13:08:48 kde-plasma systemd[1]: Unmounted /boot/efi.
Oct 09 13:08:48 kde-plasma systemd[1]: home.mount: Deactivated successfully.
Oct 09 13:08:48 kde-plasma systemd[1]: Unmounted /home.
Oct 09 13:08:48 kde-plasma systemd[1]: run-credentials-systemd\x2dsysusers.service.mount: Deactivated success>
Oct 09 13:08:48 kde-plasma systemd[1]: Unmounted /run/credentials/systemd-sysusers.service.
Oct 09 13:08:48 kde-plasma systemd[1]: tmp.mount: Deactivated successfully.
Oct 09 13:08:48 kde-plasma systemd[1]: Unmounted Temporary Directory /tmp.
Oct 09 13:08:48 kde-plasma systemd[1]: var-cache.mount: Deactivated successfully.
Oct 09 13:08:48 kde-plasma systemd[1]: Unmounted /var/cache.
Oct 09 13:08:48 kde-plasma systemd[1]: Stopped target Swaps.
Hello,
In my case the shutdown stays frozen, I have to press the button to turn it off.
